Question about Bosch Axxis WFL 2060 Front Load Washer
Over loaded the washer and now the door won't open
I jammed a bed cover in the washer and now the front door won't open, it might have not gone through the entire wash cycle.  How do I get it out?
  • lynn903 Feb 04, 2009
    that worked!!!!  thank you
Lynn903:
If you turn the knob to "Drain" the door should open.
Posted on Feb 03, 2009
  • thebyron Feb 04, 2009
    Glad I could help. :)
Electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
Door will not open on my Maytag MAH2400A front load washer
Here is a tip that I wrote about how to get your washing machine door opened...
Washing Machine Door Jammed
heatman101
Feb 18, 2011 | Maytag MAH2400A Front Load Washer
Door wont open
Here is a tip that will tell you how you can get your washing machine unlocked manually...
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
May 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine door on a front load washer will not open
If you are experiencing a door jam the following link explains how to access the manual release:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
If you continue to have problems, please post back and let me know. I hope this helps you.
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It won;t power up at all, clothes... Solve It won;t power up at all, clothes are locked inside, no lights on the panel. Plug in is working, I... (More) It won;t power up at all, clothes are locked inside,...
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2009 | Kenmore HE2 Plus Front Load Washer
When machine is not in use, with door open, tub will have water
You have a faulty fill valve
If you want to check which one, try turning off the cold supply only before you go to bed
If the washer has water in it next morning it is the hot valve that has gone faulty if it is dry then it is the cold one
They are easy to change and can be bought from a number of suppliers
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door won't close after opening during cycle
door latch needs replacement.its cracked.so the door is not closing.as you said it was moving vigoursly.that means its the motor problem too.that was blocked so it was moving the washer.
May 06, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front load he washer
try to unplug the unit and open the door manually by pulling a plastic ring attached to the door lock.
you can access the ring if you open the top cover of the unit and feel the ring where the door lock is and pull it down.
if you were able to open the door, you can check the clothes and remove the one that was jammed on the door. then test the unit for normal operation.
tnx 4 using fixya,
drcool
Oct 19, 2008 | Kenmore Elite 45986 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
137 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
