Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Using reg detergent in Cabrio He cause problems?
Will using regular washing detergent and not He mess up my washer? My Dh did laundry and intead of putting the detergent into the despinser he put on top of the clothes like "the old washer we had" before. i have also noticed my washer is much noiser than before. It is a Cabrio and it sounds like a motorcycle that is a street away. During the rinse cycle it is also loud.
  • 318 Answers
Yes you do need to use HE soap in your unit. the he type soap is a low sudsing and the reg soap will cause the unit to not rinse out and could cause it to not spin properly. the noise you are hearing is probably something n the pump and if it doesnt go away after a few loads, then you should try to check the drain line going into the drain pump. it could have something causing the noise.
otherwise you could have a spin bearing making noise. its not as likely but could happen after a year or two of using the wrong soap. the wrong soap will ruin the seals and let water into the tub bearings and that will cause them to wear and make noise.
keep running it and get back to us if you still need more help.
thanks tzweeb
Posted on Feb 03, 2009
    President:
  • 1,214 Answers
The manual says to use only high efficiency detergent. There is a procedure to flush the unit given in the manual as well.
I just reviewed a copy of the manual for another asker at managemyhome.com. They had a "Sd" error showing on their washer.
Please reply if you need further information or help.
What is HE detergents
Special low sud detergent designed for high efeciency HE machines.
Feb 08, 2013 | Maytag NFW7200TW Front Load Washer
I have a frontload he washer. My question is, will using a regular laundry detergent instead of he laundry detergent cause problems with the washer.
top load detergent will suds a lot and detergents made for from load washers wont suds very much at all, suds ina front loader will cause it to not spin or drain very well while i know it is more expensive you should always use detergents with the HE logo on the package
Jul 25, 2011 | Washing Machines
If someone uses wrong washing power and puts front loader washing power in a top loader can that do or cause any sort problems
That's no big deal. It won't harm a top load washer. Just try to use the proper stuff next time.
However, you should never use regular top load laundry detergent (non HE) in a front loading machine though, because that can quickly cause problems.
http://www.myefficientplanet.com/tag/too-much-foam-wrong-detergent-front-loader-washing-machine/
Good luck.
Mar 05, 2011 | Fisher and Paykel GWL11 Top Load Washer
Water will not spin out. Code says 5d
The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
Dec 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Cabrio washer is showing a 5d error and not spinning or draining well. What is the problem?
Sep 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Foul odor when I start a load of laundry
Obviously this problem exists on this manufactured machine (Cabrio). It has to do with the design of the machine and the HE detergent required to be used. We are on city water and the smell is sewage gas. Hence, do your whites last with lots of Clorox/bleach, cause the detergent isn't strong enoug to kill the bacteria growing in the pipes. That being said, P
Jul 12, 2009 | Whirlpool Cabrio WTW6600SBK
Le code appears during normal cycle
LG recommends unplugging the washer for 15 - 20
minutes to reset the microprocessor.
The most common cause for the LE error code is over-sudsing in the machine from using regular detergent instead of a high efficiency detergent. The HE detergents are designed for lower suds levels and enhanced cleaning performance in front-loading washers.
Overloading the wash with too much laundry may also cause the LE error code. LG recommends loading the washer until the clothes in the drum are no more than three-fourths of the way up the window of the door. This will allow them sufficient room for tumbling.
http://tclaundryrepair.com/
Feb 26, 2009 | LG WM1814CW Front Load Washer
How much detergent that is not HE can I use?
It is strongly recommended that you DO NOT use regular detergent in an HE washer. The regular detergent is formulated for a wash tub capacity of 35 gallons. A High Efficiency washer, such as yours, only uses 5 to 7 gallons of water per load. You can potentially cause premature failure of the gaskets and seals, as well as drain pump problems by using a higher concentration of detergent. In addition, you may end up with residual soap left retained in your clothing which can cause skin irritation. So...if you do the math, you would have to use about 1/5th the amount of soap you would normally use. However, if this is a new washer, you will void the manufacturers warranty if it discovered that you purposely used improper detergent. There is a disclaimer in the Owner/Operators Manual that should explain this. I hope you find this information helpful.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LAUNDRY DETERGENT
Greetings MOMMA2,
Typically it is recommended to use only HE (High Efficiency) in your front loading units. The difference between HE soaps and normal detergents is that they are low sudsing soaps. HE Machines need low sudsing detergents and if regular detergent is used, the excess suds could lead to washer problems. Unfortunately just using a smaller amount of regular detergent does not fix the issue. Only the use of HE detergent assures the proper performance of your unit.
Due to this, it is NOT recommended using Dreft in HE machines.
One recommendation out there is to look for 2x Ultra Tide HE Free, which is made without dyes or perfumes.
Thank you,
Dorothy
Go Ahead. Use Us.
May 24, 2008 | LG WM-2277HW Front Load Washer
What to use in my washer?
If your washer is rated for HE detergent, then you're supposed to use HE detergent. The reason being is that HE detergent is concentrated and specifically made for washing machines that use LESS water than conventional washers. Regular detergents are formulated for machines that use about 35 gallons of water for a full wash tub. If you use that same soap in a washer that only uses 5 to 7 gallons of water, you are in affect putting a higher concentration of soap in your new washer. Originally, manufacturers of HE machines stated that you could use regular detergents as long as you cut back on the amount. They later retracted that statement, because regular detergents were damaging the HE washers. You should review your warranty closely. Most newer models now have a disclaimer that states if you use the wrong detergent in your new washer, the warranty becomes null and void. I hope this answers any questions you may have.
Feb 28, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
701 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
