Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Have to hold the button untill door is all the way down
I have a genie 2020L. i recieved it as a gift and it came with no sensors. (not installed yet) when i push the wall button (to make the door go up) the glide will come back fine, but when i push the wall button (to make the door go down) the glide will only go all the way out if i hold the button down untill it is all the way out (untill it stops.) why won't it go all the way out with the single press of a button? (if i don't hold the button down it will come right back up.)
    President:
  • 1,214 Answers
The sensors are required as a part of a safety system. If they are not installed, then the down function can be overridden by holding the button down. Holding it down assumes you are watching the door and no one will be trapped underneath it.
Buy and install sensors, and the door will work correctly.
Reply if you have any further questions.
Posted on Feb 03, 2009
Garage door opener not working
Sensor must show steady light to close circuit and let opener work. If aligned, then there is a loose or broken wire. Try reaiming first to get steady light. Then check all wires . Another way to test and prove that is the issue is if u hold down the wired button at ur back door and the opener closes, then it is sensor issue. Good luck.
Apr 11, 2015 | Genie Company Genie Garage Door Opener...
How to sync garage door on 2014 rav4
The system on your toyota is called homelink. The process depends on the year/ make of your opener. To program remote to car, first press and hold button on car until light begins to flash slowly. This may be immediate or it may take 20-30 seconds. Without releasing that button, press the button on the remote while holding it > 3" from the button on the car and release when the light on the car button begins to flash rapidly. The next step can be tricky. If the opener is a genie or overhead door brand, press the learn button on the opener once. Then within 30 seconds, press the button on the car 3 times slowly. The door should move. You may have to do this step more than once as these brands have a touchy reciever system. If the opener brand is chaimberlain, craftsman, liftmaster, raynor aviator/pilot, follow the same steps as for the genie, except pressing the button twice, slowly. The door should move. For marantec openers, this step is not necessary. If you have and older style opener with dip-switch pairing, read manual, its complicated and would be too difficult to help on this site. Good luck!
Aug 27, 2014 | Building Materials
Have a Genie 2020L garage door opener. Door start to go down then stop and return. Tried cleaner old sensors. Same. Noticed red light on sensor 3blinks then off....repeat constantly. Replaced sensors -...
The lower sensors on the garage door rail are not aligned. Make certain you make an adjustment of the two sensors so they face each other in a strait line.
Feb 11, 2018 | Vacuums
How do i program my car to open the door? i have built into my new car. everytime i try to program it, it will not work. what am i doing wrong?
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxilary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
I am not able to program my Homelink (car) opener using the Learn button on my Liftmaster Formula I. I used the Rolling Code program. I went through all the steps, indicator light flashed rapidly, I...
If this doesn't work your car and homelink may not be compatible.
Nov 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Homelink wireless remote is stuck on fast flashing red light. I can't seem to clear my remote to program any of the buttons to my garage door opener. This is the second one I purchased, I had no...
Try this.
HOMELINK PROGRAMMING
Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Genie 2020L - Garage door does not close using remote/pad
You have loose wire(s). After speaking with Genie Customer Service, they had me disconect a few of the wires and try operating the unit, to no avail. I noticed when reconnecting the wires that several other wires on the same row of connections were loose. I tightened all wire connections and VOILA, it works.
1.Open plastic cover in front of the Unit.
2. Look on upper right corner for a row of screws. Model 2020L has a verticle row of (6) connection screws numbered from top to bottom, 1-6. These screws connet to a green circuit board. Looks kind of like a video card from a computer.
3. Tighten all these screws top to bottom assuring good connection of all wires.
My contention is this. As the motor runs, it causes a vibration that tends to loosen those screws causing a faulty connection to the circuit board. Hope this works for you.
Delta Dan
Nov 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Genie excelerator/
Check to see if the Vacation switch is locked on your wall console. It is a switch on the top of the black wall button. If that is not the problem it sounds like you need to program your remotes. Drop down the plastic cover towards the back of the unit There is a learn button push that and a red LED will come start flashing press and hold the button on your remote until the LED stops flashing (solid red) press the button on your remote again and the light will go off. This will program a remote
Here is a copy of your manual
www.geniecompany.com/docs/GENIE%20EXCELERATOR-ENG.pdf
Oct 12, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
331 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
