Question about ASUS Intel 440LX Chipset P2L97-DS Motherboard
Motherboard-soundcard problem. sound is coming but not proper.
I am unable get a clear audio output.
I am having intem-axus mother board.
    President:
  • 1,990 Answers
The Intel Website has the Drivers that You need to Upgrade available for Free Download. Please Rate My Response! Thanks!
Posted on Feb 03, 2009
My sound driver is installed,but i cant hear the sound ,,would yoou pls send me the giagram and the positition of sound ic in the board -K8mm-V
Hi.
Before you go to the motherboard on which maintenance possibilities to the on-motherboard sound card is very limited.
Start>Control Panel>Sounds and Audio Devices>Audio
Click the drop down menu and see if there is more than 1 device capable of taking control of the audio function. If more than 1, select the correct default Audio Output Device>Apply>ok>restart pc.
Then test sound again by playing music in Sample Music.
If no solution emerges and there is a hardware fault (unlikely) to the motherboard soundcard, then buy and install a cheap internal PCI soundcard to bypass the on-board sound card, install it, the drivers and then restart the pc.
Hope this helps.
Aug 02, 2011 | MSI K8MM-V Motherboard
My computer no sound after installing windows xp my mother board ECS P4VXAD
You need to install the driver : http://support.creative.com/downloads/download.aspx?nDownloadId=1843
or you can use your onboard soundcard from your motherboard (your motherboard already have onboard soundcard)
cheers
Feb 04, 2011 | Intel Creative Labs Sound Blaster 16 PCI...
I'm getting no sound through my speakers and getting code 28 in the error. I've checked the BIOS for the K8V-MX motherboard and it says the audio is enabled.
The error code you state suggests that the proper audio driver is not installed. You need to re-install the audio drivers.
Follow this link to download the audio drivers for your motherboard.
ASUS K8V-MX Motherboard (~26 MB)
Sep 22, 2009 | ASUS K8V-MX Motherboard
I have a Encore 5.1 Sound card and have installed it. My problem is that I don't get a normal sound input when I bring in the output of my cassette player into any of three ports I have in my pc, front,...
When you install the sound card drivers, they disable ALL motherboard sound functions, and enable them on the sound card, meaning you can do the same things, with better quality, you just need to connect everything to the soundcard or it won't work. SO then you cannot connect any sound to the front of the computer anymore, but a soundcard should have plenty of connections on the back side of the PC.
From what I understood from your story, you switched cassette players AND installed a sound card. If I were you I'd first install the sound card drivers, then try to play audio with the old cassette player, and see wether that works. If it does, your new cassette player has another (if at all) output than the old one. Then you'll just have to use the old one. If it does not work, your soundcard is the problem, which seems a bit odd. Soundcards are usually meant to do more than on-board sound, not less. I'd contact your manufacturer and ask wether it's normal this doesn't work, or that the card's broken.
I hope this helps,
Yannick.
May 13, 2009 | Encore (CRYSTAL4CH) Sound Card
Sound drivers
GO TO INTERNET ADDRESS BAR AND TYPE
THE MANIFACTURE BOARDNAME DOWNLOAD DRIVERS, SOUNDCARD DRIVERS, YOU MAY BE ABLE TO LOOK UP MERCURY MOTHER BOARDS MANIFACTURE
WWW.MOTHERBOARDX.COM
WWW.MOTHERBOARDS.COM
MOTHERBOARD DOWNLOAD DRIVERS
CANDYMANGANDY
Jan 27, 2009 | M-Audio FireWire 410 External Sound System
Audio Drivers
ok - what is your board number? usually it is printed on your motherboard. Eg. ga-7vm400am. it could be just numbers as well. When you get that, google it + sound drivers. you ought to find the link to download it. Alternatively you can try downloading everest, run it, and will it give you your soundcards model, google that and you will get your drivers. good luck
Jan 03, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Sound driver
Sorry pal. Machine is a DELL Inspiron 1721. No cable neither loudspeakers. I have no motherboard CD shipped with laptop. I already tried to install audio drivers from DELL Utilities & Drivers CD, but OS refuses to recognize that a soundcard is present.
Thanks anyway. It has to be solved by someone who's had the same problem and managed to work around it.
Apr 15, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Sound Driver Problem
please install the driver from othe CD or download it from internet if u require the link please reply
Jan 23, 2008 | Computers & Internet
ASUS Intel 440LX Chipset P2L97-DS Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
