Question about Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum
Windtunnel shuts off after a few minutes of use.
Turn off and reatart after about 10-15 minutes. Then it will run for about another 10 minutes and shuts off again. I was going to replace the sensor but don't know where it is or how to replace it. Can you help?
  • 1 more comment
  • dankrenicki Feb 03, 2009
    I have a Hoover wind tunnel 6200 and it continuely shuts off . I hate it !! Ive try to dis able the switch help me please?!?!?!?!
  • dankrenicki May 11, 2010
    WD40 Thats it?!?!?!??! Did you take the motor apart too. Or just spary it inside??? Can i disable the sensor??Please Help?!?!?
  • Mark Egan May 11, 2010
    It sounds like you have an excessive vacuum leak. Have you confirmed that the unit is properly assembled (including all filters) and is not leaking?
    Problem Solver:
  • 8 Answers
Yes i think i can help. all new hoovers have a thermal motor senser that turns the motor off wen it heats up to a certain point mine hade the same problem so i toke it apart and the bering in the motor was worn and heating up and tripping the senser if u have wd40 put some on the bering and be shure to wipe excess wd40 off so it doesnt get in the wires.
Posted on Feb 22, 2009
SOURCE:
Mach 4.7 runs for 2.5 minutes and shuts off
Did you use it to vacuum up fine materials like powder? If you cleaned the filters, but they are original to the machine, replace them. Try changing the bag to a fresh one as well. Beyond that, check how freely the brush turns. If it doesn't turn freely that can but excess load on the motor, if its covered in threads, remove those.
Aug 01, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5780-900 Windtunnel a month 1/2 old just started stopping when it is running and wont turn back on for a few hours why?
The motor has a thermal protection sensor on it. So your motor may be going bad, it is pulling to many amps for some reason, could be a clog somewhere or a bad bearing in the motor.
Feb 21, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Hoover Windtunnel shuts down after 15 minutes
Might be that its not exausting enough heat & stutting its self down..
Try cleaning all the filters & the hepa filter..
This will increase air flow & maybe fix the issue..
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover windtunnel..runs fine for 5 minutes then stops?
OK - sounds like your machine has a blockage somewhere. Follow manufacturer's instructions for clearing blockages and all should be well. If you no longer have the manual, you can download it from the Hoover website.
Mar 08, 2009 | Hoover U6630-900 WindTunnel Bagless...
MY CLEANER CUTS OFF
Check that the bag is not full, check that is not a broken contact in one of the wires.
Jul 13, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Deluxe windtunnel by hoover
Check for a clog in the hose or the dirt inlet by the brush roll. When there is a blockage, the thermo protector will shut the motor off to protect it. That protector could be bad, or a problem with the motor. Is the brush roll turning freely and or is it froze up and won't move.
May 25, 2008 | Hoover Windtunnel Deluxe U54219RM Vacuum
MY CLEANER CUTS OFF
My Hoover S3639 on/off switch stopped working. I don't hear the 'click' any more. I removed the top of the vacuum but can't determine how to replace the switch.
Aug 18, 2007 | Hoover S3639 WindTunnel Bagged Canister...
Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum Logo
369 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
