Question about Dell Inspiron 1521 Notebook
Internal hard disk drive not found - Dell Inspiron 1521 Notebook
    Genius:
  • 1,124 Answers
This is due a hard disk failure or setting changed on your bios. Insert the Win CD and check the status of your disk or use some utiluty program to check the hard drive.
Posted on Feb 03, 2009
Get message internal hard disk drive not
This may mean that your computer is trying to boot from a non-bootable drive. Try hitting f12 when you restart the computer and select which drive would have your OS on it. You want to change the boot sequence to diskette drive as your 1st choice. The order should be Diskette Drive, Internal HDD, USB storage Device, CD/DVD drive.
Apr 08, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
When i open my acer 4047 just displyd for setup key f2/f12 to pres,then i press f12 to reinstall new windows but there is i dont fine any hard drive?
Seeing as this is an approximately 8-year-old laptop, if you are getting a message that no hard drive is found, you have one of two issues.
Either your BIOS has reset itself and is not looking at your internal hard disk as the boot source and the message is not hard drive not found but boot disk not found .... OR ..... your hard drive has suffered a failure and needs replacement.
Jan 14, 2012 | Sony VAIO PCG-K25 Notebook
I get no internal hard disk found
You must check if the Hard drive is failure
see the Hard drive light - In front your laptop is led shoiw like a cilinder
Light Turns must turn on If is blinking light indicates hard drive
activity
To diagnostic your laptop fololow these step
1.- Turn on your laptop
Press key "F12
immediately.
Select Diagnostic
If Hard disk is not detected you need replace the hard disk driver
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Dell Inspiron 1525 Notebook
I have reseated the hard drive in my inspiron 1525 laptop and it still says internal hard disk drive not found. what can i do?
You might need to borrow another hard disk drive from your friend or relatives and try it on your laptop. If it still does not work, then we can assume that the laptop needs repair with the hard disk drive port.
Hope this helps in resolving the issue...
Sep 12, 2011 | Dell Inspiron 1525 Notebook
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Says internal hard disk drive not found, to resolve this issue, try to reseat the drive
The hard disk has died, you will have to replace it with a new one then reinstall Windows using the recovery disk.
Dec 10, 2010 | Dell Inspiron 1525 Notebook
As soon as I turn on my laptop a message says that the internal hard disk drive was not found and that I should reseat the drive.
Yes that is the first thing your should try.
When the computer cannot detect the hard disk or a boot disk then you get this error message. Please click on this link to determine the fault and solution to this problem :-
http://www.fixya.com/support/r6244569-no_bootable_device
Oct 18, 2010 | Dell Inspiron 1525 Notebook
My external hard drive is 300g,i formatted my internal hard drive and found that my external drive was also formatted and was only 3g.could someone help me please that's a lot of space lost
do you have a recovery disk for the internal hard drive? this is the disk that came with pc.your internal HD is important this have been wiped (you have no OS) . get your internal back in order........do you have a receipt that says you purchased a 300gb (not 3gb) take it back get your money or the right external... once you are able to use the pc double check the external hard drive
Feb 16, 2010 | Maxtor OneTouch II 300 GB Hard Drive
My toshiba lap top starts up as normal then the msg media test faiure and no bootable device whats wrong
The laptop isn't seeing the hard drive. It has either bounced loose (doubtful) or the hard drive is defective. You can open panels on laptop and find the hard drive, remove and then replace it and see if it reads. Failing this check to see if it's still on warranty or buy another one similar to yours.
Nov 27, 2009 | Computers & Internet
Dell Inspiron 1521 Notebook Logo
415 people viewed this question
Alun Cox
