Question about Wacom Cintiq 12WX Interactive Pen Display Monitor
Problem with Cintiq 12wx
I can't seem to get my cintiq to act as a dual monitor. It only responds as a tablet for my primary monitor. I can't find any solutions online.
    New Friend:
I had the same issue and it took me a couple of hours to find the solution, until I stumble upon this blog:
http://www.tomrichmond.com/blog/tag/wacom/
I have a Macbook Pro and use the DVI Cable. Here is this the solution:
"First, you need to change the tablet's focus from the Cintiq screen to the main desktop screen. This is easy to do, just open System Preferences>Wacom Tablet. Make sure you have highlighted the "Cintiq 12wx" on the "Tablet" window across the top part of the preference window, and then click on "Calibration". Change "Monitor" from "Cintiq (2)" to whatever your main display (1) is. What will happen now is that the Cintiq will act like a regular Wacom tablet and moving around on it will move the cursor on your main screen. Do not panic, this is expected. Now open System Preferences>Displays. You will see a window pop up on both monitors. The main one will be a little different, as it will have "Arrangement" and "Options" as choices not on the other box. Click "Arrangement" and drag the white menu bar from the left display square to the top of the right one. A red border appears on the display that is actively selected as the main desktop as you do this.
The result will be that now your menu bar and dock will be on your Cintiq, and the pen will again function correctly on the screen. Hide the dock if it's in your way. Again, this is a personal preference on may part and does not affect the functions of the Cintiq in any way."
Hope it helps!
Posted on Mar 17, 2013
    Champion:
  • 293 Answers
Hi...there Jenn!
Go to your toolbar bottom r/h side, look for VGA Display Icon. Open it and look for dual monitor setup. It's might be what you has been looking for... If not, read your cintiq user guide... Have a nice day!
Posted on Feb 03, 2009
Cintiq monitor suddenly won't sync
http://www.conceptart.org/forums/showthread.php/201556-Cintiq-12wx-No-Sync-quot-Message
Oct 10, 2017 | Wacom Cintiq 15X Graphic Tablet
My Cintiq 12wx is suddenly yellow-tinted
Did this problem get fixed? I am having the same issue :(
Sep 04, 2012 | Wacom Cintiq 12WX Interactive Pen Display...
Wacom cintiq 12wx calibration
I had a similar issue using the 12wx with a 15" MacbookPro Retina. Screen displayed the desktop way too much to the left. I found that the refresh rate of 59.8 hertz seemed to not be compatible despite it automatically being set. After changing this to 74.9 Hertz, the desktop is now properly centered on the Wacom screen and can be calibrated now. Not sure if this applies to Windows machines but perhaps something to keep in mind.
Jun 09, 2012 | Wacom Cintiq 12WX Interactive Pen Display...
Silver Cirlces when pen touches tablet
The solution is simple to your silver circle happening every time you click the screen. Go to Start>Control Panel and double click Pen and Input Devices. Click on the second tab in the Pen and Input Devices (Pointer Options) and uncheck all four of those top boxes. Voila! No more silver circles when you click!
If your tablet is acting buggy, try installing the latest driver from the Wacom.com website.
Dec 23, 2009 | Wacom Cintiq 12WX Interactive Pen Display...
I just got a cintiq 12wx and when I plugged it in it worked immediately with my intuos 3 driver but had a message in the middle of the screen. uninstalled the driver and installed latest wacom cintiq...
I had this same problem and just had to go into my system preferences on the imac and select display and then select/check the mirror monitors and now it is on sync-hope that helps! After I did that though my color is off on the cintiq so I am looking for suggestions on how to fix it as the calibration did not fix the problem.
Nov 07, 2009 | Wacom Cintiq 15X Graphic Tablet
Cintiq 12wx
I had a similar problem with my cintiq 12WX - i have managed to sort this problem.
The way i did it was by going into CONTROL PANEL (please note i am using XP windows), then into DISPLAY, then into the last tab on the right aka SETTINGS. Once in SETTINGS go into the ADVANCED section, then click on the DISPLAY tab. In here you should have 3 things - monitor, panel and tv. The tv bit is irrelevant. Look at the MONITOR and PANEL tabs, if your wacom IS set up correctly when you click on the button (it is a circle with a line inside it) on the title (it will either be greeny/turquoise or red). If it is red, click it and the same button on the panel title will turn green aswell. Below the pictures of a computer and a laptop there should be 2 buttons that are the same for each. Currently, my almost working cintiq is set to having the button with two squares on it under the heading of 'MONITOR' and the button with a circle is on under the section entitled PANEL.
If this doesn't work I dont know what to suggest.
Hope this helps.
M
(p.s. you may have to improvise with the settings in the display bit to get it to work).
Mar 18, 2009 | Wacom Cintiq 12WX Interactive Pen Display...
Hi, having problems with my cintiq 12wx. It is only working as a tablet right now. Using my pen on the cintiq, and it just moves the cursor on my other monitor. I can't transfer anything from my monitor to...
Hey guys,
I have posted the solution to this problem (or my version of a solution) elsewhere on this site - but here it is again, just for you!
I had a similar problem with my cintiq 12WX!
Hope this helps.
M
Feb 03, 2009 | Wacom Cintiq 12WX Interactive Pen Display...
Wacom Cintiq 12WX Interactive Pen Display Monitor Logo
1,762 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
