Some providers configure this modem to lock you out of settings. It would appear you should take it up with them.
Was this helpful?
Yes
No
Solution #2
posted on Aug 01, 2007
Pasty - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
In , Kompu Kid spewed forth:
So WHAT have you tried so far? Have you read the MANUAL for the modem?
-- I always finish what I sta
Was this helpful?
Yes
No
Solution #3
M0nica L - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Do you want to explain how malware on the computer can affect the DSL light on the modem?
For the OP's information, if the DSL light is flashing red, it means an ADSL sync signal is not detected.
-- Cheers Oldus Fartus
Was this helpful?
Yes
No
Solution #4
Cornish - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
According to the manual, the 4100 is ethernet only, the 4200 usb/ethernet. There are 4 LEDs on the 4100, pwr, dsl, & enet. The 4200 also has a usb led.
Only one of those can turn red - the pwr when the POST fails or during POST after powerup or reboot.
If you are seeing the pwr light turn red under some other circumstances, then there must be a PS powersupply problem, like a loose connxn, causing it to POST because it lost its power and got it back.
Now where did that beer go?
-- Mike Easter
Was this helpful?
Yes
No
Solution #5
Cato - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
What was the last red light you saw that meant "normal"?
You can look at the http interface, but you can't run the advanced diagnostics.
She's paying someone for her DSL connectivity -- it would seem they would be responsible for troubleshooting whether it is the modem or the dsl service.
Siemens doesn't seem to want to make an online manual available, only a scanty .pdf brochure.
Aha. I found it #
But I haven't read it. I'm gonna have a beer instead.
I think that might be its authentication process.
You can reset or power off/on to reset.
-- Mike Easter
Was this helpful?
Yes
No
Solution #7
LiZzIe - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
No. Red is bad. Green is good. Check the system for malware. Inquire about firmware upgrades for the modem. Do not install them unless you contact the technical support for her DSL service first.
no internet light..every thing else working..i reset...unplugged and plugged up every thing the...
(More)
no internet light..every thing else working..i reset...unplugged and plugged up every thing the right way....im thinkin its somthing to do with at&t
internet explorer flashed turning off your comp.to install new up dates when finished no service...
(More)
internet explorer flashed turning off your comp.to install new up dates when finished no service flashed, lights not working on modem are ethernet, internet and aactivity
Beginning from start internet I have the same password, but in last months he is suddenly become...
(More)
Beginning from start internet I have the same password, but in last months he is suddenly become invalid. Right now again. I can't used to e-mail, etc. Early AT&T help through http:/192.168.0.1/
i just tried to connect to xbox live and it said my router/modems MTU was set lower than 1364 and i...
(More)
i just tried to connect to xbox live and it said my router/modems MTU was set lower than 1364 and i was wondering how to change that
