Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
Bobbin winder does not work on Model 17651
Bobbin winder does not work on Kenmore 17651. Motor runs but does not spin bobbin
  • 69 Answers
You have to make sure that the handwheel is engaged by pushing it in. When you are through, you have to pull it out.
Posted on Feb 07, 2009
  • Ruth Peck Feb 07, 2009
    I'm sorry, got that backwards, to wind bobbin, pull it out, when through push it in....sorry!
My bobbin winder wont spin''? Kenmore model 1931
Here's a quick fix until you can get to a mechanic. Alternatively use the bobbin winder on another machine if you have one.
Oct 02, 2017 | Sewing Machines
Model 2142. Motor runs but why doesn't belt move for regular sewing?
Make sure the bobbin winder has not been activated. When the bobbin winder is activated, the needle bar is deactivated. The belt could also be stretched, damaged, or broken.
If it is a mechanical machine, how long has it been since a thorough cleaning and oiling?
It was working now it seems to be frozen the needle part wont move
Mar 06, 2016 | Kenmore Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ... > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
Jan 20, 2010 | Sewing Machines
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
Jun 12, 2009 | Sewing Machines
Bobbin winder broken
Hm, when was the last time the machine had a thorough clean and oil? These old machines tend to run forever, BUT they do need periodic TLC.
Wheel on right side that controls the needle up and down is very tight...
FWIW, there is a stand-alone bobbin winder called "Sidewinder" avlb at JoAnn's or Amazon for ~$30. It's a handy little gadget that lets you wind multiple bobbins without unthreading the machine--also saves wear n tear on your machine.
Dec 11, 2017 | Kenmore Sewing Machines
Bobbin Winder not working
sounds like the bobbin is not all the way down on the peg.
May 15, 2009 | Kenmore 11101 Mechanical Sewing Machine
Make sure that the hand wheel is engaged by pushing it in. To disengage, pull it out.
Feb 03, 2009 | Kenmore 15516 Mechanical Sewing Machine
You have to make sure that the hand wheel is engaged. To engage it, push it in, to disengage, pull it out.
Feb 03, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
The winding sound is the rubber O-ring against the spinning pulley (back of hand wheel) - do not let this continue, it will wear out the O-ring.
I had the same problem and I found the shaft bushing of the winder dry and needed lubed. Use oil or spray lithium grease and it should work fine. Spin the bobbin shaft by hand (not the hand wheel) to get it freed up after oiling.
You can oil from the top and should take off the side case to clean the excess oil from the O-ring. The shaft bushing is a tight fit and any dry oil will get sticky and prevent winding.
Jan 22, 2009 | Kenmore Sewing Machines
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
219 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
