Question about GPS
Navman 90i, the screen turn to charging mode when power on
The screen change to charging mode as soon as the device is connected to outside power supply (car,main or computer) So while travelling, when the battery of the device is low and recharging, the map completely disappear from the screen and just showing the charging mode.
    Sergeant:
    Champion:
  • 373 Answers
Just a quick question
did you try turning it back on again when it is in the charging mode?
see if that works
Posted on Feb 04, 2009
Reset with no disc etc
SAT NAV - RESET PROCEDURES FOR GARMIN, NAVMAN, TOM TOM
Updated 08/05/2014 05.01 PM
Reset Procedures for Garmin, Navman, Tom Tom
Garmin Master Reset NB: This will erase all way points or favourites and will restore your unit to the default factory settings.
Nuvi® 2xx, 2x5, 5xx, 6xx, or 7xx.
  1. Start with the unit OFF and unplugged from power.
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil.
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON.
  4. Release the power button when the device powers ON.
  5. You will see a new message: Do you really want to erase all user data?
  6. Remove your finger from the touch screen when this message displays.
  7. Touch Yes.
The device will automatically reset. Please follow the on-screen prompts on the n?vi and when completed, place your device in an area with a clear view of the sky until it acquires satellites.
Nuvi® 8xx or 5000.
  1. Turn the device OFF (you will need to remove the battery from a nuvi 8xx).
  2. Turn the device back ON (you will need to install the battery into the nuvi 8xx).
  3. When you see a progress bar on the screen of the unit, quickly place your fingertip, or the eraser end of a pencil, in the bottom right corner of the touch screen.
  4. Hold the bottom right corner of the touch screen until a message says, "Do you really want to erase all user data?"
  5. Release the touch screen and touch Yes.
  6. The unit will now restart.
  7. Follow the onscreen prompts to set up the nuvi.
Navman S30/50/70/S80/90i.
  1. To reset your device, hold down the power button for at least 10 seconds and the device will power off.
  2. Press and hold the power button to turn the device back on.
For other models, please visit this link, select model and search for 'reset'.
TomTom
  1. Soft reset - select your model.
  2. Reinstall TomTom application.
  3. Format internal memory or memory card.
Apr 01, 2015 | Navman S30 3D Portable GPS Automobile...
Screen is showing computer, usb connection, navman which are joined together by a serious of dots with the computer screen to usb connection showing green lights
The F20 Desktop Software and Service pack on the CD's from navman do not work, as you have seen. The solution is to go to the navman website and download this Service Pack
Be sure your f20 is connected to the USB cable and turned on displaying the USB Connection screen. Leave it on during the entire process.
Once downloaded, run this self extracting file and let it install automatically. After it is installed and ran.....you will see the same error again of failure to connect.
At this point you must reinstall the driver manually. Right click on your "My Computer icon, Select Devices, then properties on the navman. You should see a yellow "?" next to a statement "Unknown Device" in the USB devices. Click on the "Reinstall Driver" and select a specific location or the Have Disk button. The USB driver is now located in C:\program files\Navman\f20servicepack\USB directory.
You should get a button that now says Okay at the bottom, click onto it and allow the MS program to update the drivers. You should see the device screen change and say "This device is operating properly". You can then close the windows and run the F20 desktop program. It should connect then.
Jul 06, 2008 | Navman GPS
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
IS THERE ANYONE OUT THERE WHO COULD HELP ME????? I have had a Navman N20 but I have a problem. The power button at the top doesn't turn it on or off. When I charge it the light comes on amber but hasn't...
You need to hold the power button for about 5 seconds to turn it on. If that does not turn it on. Then you need to run a check on some of the components of the device. You start with the battery, then charger and the device seem to be working fine, because when you plug it in, the device amber lights come on. It is supposed to turn green when it is fully charged, but it seems like the battery is not holding a charge, that is why it is not turning green.
Test another well charged battery inside the device to see if it will power on and work properly, if it does, then it means all you have to do is to replace the battery, but if it does not power it on, then it means there is an internal problem with the unit.
Try to connect it to a computer to see if it will detect it. Once it detects it, try to charge in on there for some time to see if it will hold a charge there.
If it is properly charged, it will be able to power on fully. Also check the device on the computer to see if the software and files are still on the unit. That should also assist you in solving the problem.
Hope this information helped you.
Jan 05, 2011 | Navman iCN 520 GPS Receiver
Mi navman my55 wont turn on unless it is connected to the car power supply it is reading the batt is full and wont turn on even if connected to computer or power plug
my navman 55 has developed a problem it will not arrow down on any screen and the touch screen has been hard to operate from new
Aug 04, 2010 | GPS
My navman won't charge or turn on, any ideas?
screen shows computer to navman all the time
Jul 25, 2010 | Navman F20 GPS Receiver
Hi I am using Navman S30 car navigator. It has been giving me problems now. Every time I connect its charger, it turns on and gets stuck on the usb connection screen. I have changed its charger but I am...
Open your usb cable with a sharp knife; you'll find four different coloured cables inside: leave the red and black cable intact; cut the other two. Close your cable with some tape.
Your navman won't go into usb mode again, but it will charge your device
Dec 23, 2009 | Navman S30 Car GPS Receiver
NAVMAN ICN310 CANNOT GET SIGNAL IN MY HOME OUTSIDE HOME TAKES 30 MINUTES OR MORE TO GET SIGNAL
It's not unusual to lose signal indoors , in fact most portable /car devices receive very little, if any, signal indoors.
I have a Navman ICN510 running TomTom 6.0 software , instead of the standard Navcar CE program. I believe it connects much faster.
Below is a support forum for modding Navman GPS units.
It will teach you how to change the software on your navman & also help with any other problems. It was very helpfull to me !!
Click here for the Naman Forums !!!!
Jun 04, 2008 | Navman GPS
Navman N40i Not charging in car
Does the car charger cord plug into the cradle? or just straight into the unit (despite resting on the cradle) ? Do you know if anything else charges via the car charger?
Mar 15, 2008 | Navman NavPix N40i GPS Receiver
GPS Logo
118 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
