TV locked in VHS Mode
I have a GE 13" television with the VHS on the bottom; tv works great; remote doesn't want to work even with new batteries....I had a Video in the machine and removed it after I had the new AT&T Universe cable installed. Now my TV is stuck in the VHS mode and I can't get the TV back on--blue screen. Any ideas?
  • 8 more comments
  • julie_chambe Feb 03, 2009
    I tried the buttons on the front of the tv, but none of them seem to unlock it...any suggestions? the remote is rattling--something's loose inside so getting new batteries didn't work.
    i'll try and get a new remote...i think you're right about that...this is an older tv, but like i said, it works beautifully! thanks so much!
    where can i buy a remote for a GE television? remember, this model is at least 10 years old. Thank you!
    it's a Model 13TVR62. Thanks!
    You Rock!~ Thank you so much!
    I bought a universal remote and now i can't seem to get it to program right...Help!!!
  • julie_chambe Feb 04, 2009
    i purchased the RCA Universal Remote -- will control three devices, but of course, i have only two. RCR3273. I got it to turn the tv on and off and then nothing....i think erased that and i'm back to square one. frustrating.
    ok. thanks!
    well, it's now flipping back and forth fron the tv and the vcr; the picture is fuzzy and i tried to put the tv station on "3" for cable and it jumps to VCR 1 or 2, no channel 3. weird.
    President:
  • 1,214 Answers
You should be able to access all menus from the buttons on the front of the TV. If not, then you need to see if you can find a remote that works, and program to work with your TV.
You don't know at this point if the remote works, but assume it doesn't because you can not get any function to work. The VHS tape should have nothing to do with it.
Reply back if you would like to pursue a dialog on the repair of this unit.
Posted on Feb 03, 2009
  • 5 more comments
  • Mark Egan Feb 03, 2009
    They make generic remotes that can be programmed for a range of TV's.
    If you give your model number, I'll see if I can find one.
    Here's a copy of your manual -
    http://www.fixya.com/support/p237108-ge_...
    It looks like any generic remote will work. You will just need to program the code into it, which will be found on/in the remotes paperwork.
    Thanks! And be sure to rate me on FixYa!
    Hope that you would reward me with a FixYa, and remember, I'll be here to help you more unless I get tied up on the road.
  • Mark Egan Feb 04, 2009
    Which one did you buy
    Did you try to program it for any other devices that you may have in your house, to make sure you know how to program it right, and in the event there is something wrong with the GE TV?
    OK. Sit back, take a deep breath. Close your eyes and think of your happy place for 5 minutes.
    Now, reprogram the control using the codes given in the instruction. If there are several codes, try them all to see if you can gain full functionality.
    If you don't, take the control back and get a different brand. You might also try programming the TV portion of the remote using TV codes, then use the DVD or VCR part of the control, and program using those codes that are given for those devices elsewhere in the code booklet.
    Let me know how you come out.
    Let me know.
    OK. It's not the remote that is causing that. Can you get into any setup menus for the TV?
Remote sensor not working on TV. Tried the original and several other remotes and none are working. Used new batteries.
pls. check tv is in chaild Lock mode / LOCK mode.
so check tv panal key use . is working ? NO then tv is in chield lock mode. see user's menual and set chaild lock trun off.
chek with new remot cantrol if not work then problum is tv set
[1] see tv frant panel on IR [simbol] clear with cloth smuthly [dust free]
if not working Remot cantrol then problum is inside tv .pls check tv by nr. tech.
Oct 30, 2009 | Televison & Video
Cannot get TV/VHS unit to work.
sounds like the vcr lock feature is on,
hold down the rec/time button for 7 secounds during the power on mode.
ushally goes off within 24hrs if the time is set. but seems maybe thats a issue.
try that see what happens.
and if possible give the model number of the unit please.
Quasar is made by panasonic and their guides and manuals can be found there as well..
I found this manual hoping it was close to yours take a look and let me know.
http://service.us.panasonic.com/OPERMANPDF/VV1308.PDF
Aug 11, 2008 | Quasar VV-1302 13 in. TV/VCR Combo
TV/av mode
no there isnt u have to get a new remote. The GE remote is cheap and the code is 0157. its the only code for that remote that works properly
Feb 20, 2009 | Durabrand BH1304D 13" TV
No picture
I have the same TV. My best guess is that the remote may need new batteries. It might also be necessary to reset the TV codes for the remote (even it's the one that came with the TV).
Nov 09, 2008 | GE 31GT720 31" TV
TV code for Emerson EWC 1301 TV/VCR Combo
how do use revmote to program tv vhs thank you11
Jun 15, 2008 | Emerson EWC1304 13 in. TV/VCR Combo
Symphonic 13"" TV
the code is 044, TV/VCR TV mode. Sylvania codes work for Symphonic
Mar 29, 2008 | Symphonic SC3913 13 in. Combo
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
PROGRAMING REMOTE TO TV
This is a comon problem, look up your code again, but notice combo, look at just the tv, now the vhs, try all of these codes
Jan 06, 2008 | Panasonic PV-C1322 13 in. TV/VCR Combo
Remote no longer works
the manual for this remote can be found on this site
http://www.fixya.com/support/p237065-ge_rm24930_remote_control/manual-11900/page-2
unfortunately i do not have a code list for this remote, but you should be able to use the code search function to get everything working again.
hope this helps,
trin
Nov 17, 2007 | GE RM24930 Remote Control
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
