Question about Garmin nuvi 260W GPS Receiver
NO DETAILED MAPS FOUND TO SUPPORT ROUTING
I GET THE ERROR MESSAGE THAT NO DETAILED MAPS SUPPORT ROUTING.
  • 20 Answers
You need to unlock the unit. I had the same problem with one that I have. Try this:
The No Detailed Maps Found That Support Routing message could be due to the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message No Detailed Maps Found That Support Routing disappears.
  • If you get a Can't Unlock Maps message following this error remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file.
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device.
Retrieving your unlock codes:
  1. Log into your myGarmin account: https://my.garmin.com/mygarmin/customers/myGarminHome.faces
  2. Select myMaps.
  3. Select Manage Maps.
  4. Select the device from the drop down menu.
  5. The unlock code is located under the "Maps installed on this device" section.
Creating an unlock code file:
  1. Plug your Garmin device into the USB port.
  2. Double-Click on My Computer or Computer located on the desktop.
  3. Double-Click on the Garmin or nüvi drive.
  4. Double-Click on the Garmin folder.
  5. Right-Click in a blank space in this window.
  6. Move your mouse over the word New.
  7. Select Text Document.
  8. Press Enter / Return on your keyboard.
  9. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad.
  10. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces before or after.
  11. Select File.
  12. Select Save As.
  13. Change the Save As Type to All Files.
  14. Type gmapprom.unl in all lower-case letters for the File name.
  15. Select Save.
  16. Close the Notepad window.
  17. Delete the New Text Document file.
  18. Disconnect the GPS device from your computer.
*nuvi x70 owners with transatlantic mapping will need to follow the Creating an unlock code file instuctions above for their U.S. mapping and then create another unlock file for their European maps:
  10. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces before or after.
  11. Select File.
  12. Select Save As.
  14. Type gmapprom1.unl in all lower-case letters for the File name.
  15. Select Save.
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen.
  2. Touch Settings.
  3. Touch Map.
  4. Touch Map Info.
  5. Select the checkbox next to the maps to be enabled on the device.
If you continue to receive the No Detailed Maps Found That Support Routing message after completing these steps please contact Garmin Support: http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Posted on Feb 03, 2009
Thank you! Finding and using the unlock code restored my Nuvi 260 from a paperweight to a GPS!!
Posted on Oct 02, 2011
    Problem Solver:
  • 5 Answers
I too had this problem with the Nuvi 260w. I tried loading the new 2010 map software two times with the same result - no detailed maps found.. Those two times, while the maps were installing, I walked away from the computer and returned later to find the installation window gone.
The third (and successful) time, I stayed at the computer the whole time it was installing the maps to the 260w. I didn't sit and watch the progress bar the whole time, but did other stuff on the computer, and returned to the status window every so often. It completed to 100% and at the end it indicated to click on the Finish button - this "Finish" notice was not there the previous two times when I left it alone. I then unplugged the Nuvi and all was fine, the new map was loaded, and all worked well.
So I'm thinking that the installation status window probably needs some type of activity on the computer to stay alive. I also noticed that the previous two times, the img file was smaller than the third time, so the installation to the GPS did not complete the first two times.
I hope this helps someone else with the same problem.
Posted on May 02, 2009
OAKside
SOURCE: GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
The downloaded map file (ex: "Garmin_RMU_CNNANT2010C.exe") contains all of North America, and you must select the correct subsection (ex: "Lower 49 States+PR") that you purchased, which is listed on your Garmin myMaps page (My.Garmin.com).
I am a GPS newbie as well and selected "all of North America" when installing my free nuvi 205 map update. A mistake that's too easy to make, esp. considering Garmin still has very little info about selecting the correct map subsection listed on their support site.
You do NOT need to re-download the huge map file, thankfully, but you must re-install (30+ min) to choose the correct map subsection.
"Bad on Garmin, IMHO for not making important details like that clear to us new owners." My thoughts exactly.
Posted on Apr 25, 2009
MY GARMIN NUVI 200W NOT WRONG AND SAY NODETAILED MAPS FOUND THAT SUPPORT ROUTING. THE NUVI CANNT BE USED WITHOUT THEM
Posted on Sep 22, 2008
SOURCE: garmin nuvi says, "no detailed maps found to support routing."
I am very sorry to hear that you are having problems with the unit. You
may need to switch the unit on and press and hold the centre of the
screen until the message ?No detailed maps? message disappears.
If your map detail is missing, then the map information may have been
disabled. To check to see if the mapping has been disabled, follow the
steps below:
From the Where to? and View Map page, touch the Spanner icon, settings
(Tools).
Touch Map.
Touch Map Info.
The unit should display the name of the map that is loaded to the unit.
The box in front of the map name should have a tick in it. If it does
not, touch the box to place a tick in it.
Then please test by searching for an address.
Posted on Apr 02, 2009
RPFinney
  • 385 Answers
SOURCE: Garmin nuvi 205 shows no detailed maps found that support routing
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
this resolves the problem for you.
Regards
Richard.
Posted on May 19, 2009
You can download new maps..........free......................but..........
I had this problem last year with my garmin 200 and when I called they said that I was out of the 60 day time window for a free map upgrade but they would give it to me anyway. They gave me detailed instructions on how to download a new map free of charge but they didnt explain which selection replaced what I already had on mine.
As a result, I downloaded the wrong maps and have much less detail. Even though its the "2009" version, its less acurate than my old maps were. But its worth a shot, better than paying for them.
Posted on Jun 20, 2009
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
No detailed maps found that support routing on my
This is a common problem. Your map unlock code has either been corrupted or is missing. Please see this link for more info on this problem:
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Aug 24, 2009 | Garmin nuvi 205 GPS Receiver
I get the message "no detailed maps can be found that support routing. The nuvi cannot be used without them." and I can not get to anything else on the garmin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  2. Select myMaps
Jul 18, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
When the "no detailed maps found that support routing" screen comes up it covers any of the icons, so I'm unable to do anything.
  2. Select myMaps
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
Screen with message.. " No detailed maps found that support routi
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Feb 06, 2009 | Garmin nuvi 350 GPS Receiver
No detailed maps found. Help! Please
my email address is ada @ ebucksmail.com.
Can u please help with my sons nuvi 200 that shows no detailed mapsfound. Thanks A Million, Ada.
Jan 22, 2009 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
3,497 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
