Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Audiosonic KMCTH68 Keeps turning itself off after 2 mins
I have a 68cm Audiosonic KMCTH68, having turned the set on and watching happily, after 2-3 ,mins the set turns itself off and remains on standby.
I am then unable to get the set to turn back on for at least an hour with just the standby light on. I can hear a slight ticking noise coming from the back of the set but no smell of burning or heat to indicate over heating.
Please anyone know what the problem is? :(\
CHEAP TV VIDEO REPAIRS
Can't be 100% sure but the most likely cause of the problem is bad solder connections in the switch mode power supply or on the vertical output IC, or anywhere on the main or picture tube circuit boards, due to age and switching on and off TV's develop bad solder connections when cold the connection is made and when it warms up due to heat expansion the connection breaks, you will need to be handy with a soldering iron, and discharge all power supplies with something like a 100 Watt globe before soldering or you may blow things up and do really serious damage, and be warned TV 's have very high voltages 360 volts DC in the SMPS primary and over 20,000 volts to the picture tube, so be careful.
Posted on Mar 09, 2009
I can,t find STANDBY mode to turn alarm off It is a audiosonic clock radio Model CAA-09168
How do you change the time on a Audiosonic CR06PL clock ...
www.fixya.com/support/t20010845-change_time_audiosonic_cr06pl
Sep 11, 2013 - ... radio? Normally there is a Time button and then a Minute - ClockRadios question. ... 2 Answers. SOURCE: Emerson Smartset Radio Model CKS2288. The Daylight Saving dates appear to be hard-coded per the manual:
Nov 05, 2015 | Audio Players & Recorders
Power surge knocked out power to my house. Was watching tv when it happened. Everything come back on, but now me tv keeps turning itself off and on repeatedly. It never really turns on.....
Hello, Unplug the tv from the wall and let set for 30 mins and then plug back in and try. If doesn't work you will have to take to repair shop or get a new one
Oct 25, 2015 | Sharp Aquos Televison & Video
My Audiosonic boombox will not come out of standby - has anyone got a manual ?
If it worked previously for years and now it won't come out of standby, don't make illusions that it is something you pressed or didn't press.
Anyway, I've been looking for a manual but couldn't find any. Maybe someone else...
Your vintage AudioSonic device is defective. It's on you to look for repair service to get a diagnosis and evaluate if you repair it or leave it on your living as a decorative convesation piece.
You might watch some videos about how to repair a boombox.
JVC RC M90 Boombox was repaired and quick demonstration
DIY How to Fix or repair Boombox radio Sharp
Sony boom box repair 2 HELP
Sep 08, 2015 | Audio Players & Recorders
My Audiosonic td2401 keeps turning itself off, have checked the internal clock and timer, sleep mode is set to off, any other advice on keeping it running for more than 5 hours before it turns itself
HI. If you are 100% sure that no timer is active, then I guess it is a thermal problem in the TV. There can be bad solderings, mostly in the horiz., or vertical powerstages, causing the TV to shut down after 5 hours. At least, this time should be different if the ambient t° from the set is higher or lower.
If the "turn off" time is always exactly 300 minutes, no second more or less, then there might still be a processor problem in the TV. Not easy to find. Also, these replacement micro-processors contain a
pre-programmed booting section where all characteristics and alignment data from your set are stored as a factory setting....
Huge problem, which can only be solved by an Audiosonic service center. Good luck.
Oct 02, 2014 | Televison & Video
Why does radio keeps turning itself off after 15 min.?
Half a dozen reasons... If it's exactly 15 min maybe a timer is set? If it's only when it's played loudly or when a bass part is played it could be the wires touching each other.
Jun 07, 2014 | Sharp Cd-dh950 Cd-dh950p 5-disc Compact...
Tv stuck in standby, red LED is on. How do i rectify this problem??
Could be an open internal fuse or power supply failure
Nov 21, 2017 | Televison & Video
TV turns on for about 2 min and then shuts off for 30 sec.
Check the standby timer. Or reset your HDTV to factory settings. Just turn on the TV. While holding down the RESET button on the remote control, press the power button on the TV. (The TV will turn itself off, then turn back on again). Release the RESET button..
Nov 06, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
117 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
