Question about Toshiba Advanced Port Replicator III (PA3314U-1PRP)
Dual monitors: DVI and VGA not supported simultaneously
I can use dual monitors with one being the internal screen, but I would like to have two external LCDs connected instead.
From what I've read online, it seems the Port Replicator II can't handle DVI and VGA simultaneously, but can I use the VGA on the laptop (Tecra M5) and the DVI on the port replicator?? NVIDIA should be able to handle it, I assume.
    Problem Solver:
  • 9 Answers
It looks like this a problem for the Port replicator III, not II, right? I'm not an expert on port replicators, but if you have even an ok video card, it should work fine even running all three...
Posted on Apr 24, 2009
2nd monitor does not work with DVI to VGA converter cable. My video card has VGA and DVi ouputs.
The problem could be in the adapter to the video card. There are different types of DVI connections. If the adapter does not have the proper set of pins then the card will not recognize that a monitor is connected at that port. Monitors themselves have no bearing on whether a single or dual monitor set up will work or not. Digital Visual Interface Follow this link, it may help you determine if the adapter you are using is correct for the graphics card.
Apr 22, 2014 | Acer ET.CV3WP.E05 LCD Monitor - V193WEJb...
What cable do I use to get a G0773 Graphics card (Dual VGA/Single Port) to work with a single Acer P215H Monitor?
check vga cable or VGa card for enhance of video for more tips sign in ghulam rabani
Oct 23, 2012 | Dell G0773 Video Card
I have HP Pro3000MT, and it has vga and dvi port. I want to use dual monitor for this pc. the monitor are HP LCD and it only has vga input. first i use vga port, secondly i use this dvi cable to connect to...
you need a dvi to vga adapter not a dvi to vga plug and you must also go into your graphics card setup catalyst control center if its ATI Nvidia Display manager for Nvidia if you boot the computer with it pluged in and you can see the boot screen on bolth displays then its an os thing just right click and select the display manager the activate all display's through the managers
Apr 01, 2011 | HP SmartBuy Pro 3000 MT Pent Dual Core...
Need help with a new video card I install in my dell precition 360 don have video
Hello there,
This is the supported Graphics Cards the computer you have can use
Graphics Support . . . . . . . . . . . . . . . . . . . . . . nVIDIA® Quadro 4 280 NVS 64MB DDR, AGP 8X, available in single or dual VGA and single or dual DVI
nVIDIA QuadroFX 500, 128MB DDR, AGP 8X, dual monitor (VGA and DVI or two VGA)
ATIæ Fire GLô X1, AGP 8X, 128MB, dual monitor (VGA and/or DVI)
3Dlabsæ Wildcat4ù 7110, AGP 8X, 256MB DDR, Dual monitor (VGA and/or DVI)(Desktop chassis only)
let me know the Model of the Video Card you are trying to install and we can start fixing the problem
Thank you don't forget to Rate
Jan 25, 2011 | Dell Computers & Internet
Hello! I have a processor intel pentium dual cpu e2160 @1.80 Ghz and for display a graphic card NVidia GeForce 7300SE/7200 GS, DAC Type Integrated RAMDAC 512 mb. I use my VGA monitor connected to the...
Hello ghinea18, sorry you can't do that because this will cause hardware conflict, that's why motherboard bios automatically disable integrated graphics if you install video card using pci express x16 slot - Nvidia GeForce 7300SE. do you know if your video card has dual vga or dual dvi connection?
You can try dual display, im not sure if this card supports dual monitors because nvidia online specs does not show full specs on 7300se series. \
Good Luck!
Nov 24, 2010 | Computers & Internet
Dual Screens with a VGA connection
The easiest way would be to purchase a video card that has 2 vga ports on it, allowing dual monitor support. Here is an example.
http://www.amazon.com/Matrox-G450-16MB-Dual-Video/dp/B00194CT5A
Dec 29, 2009 | Samsung 2333SW 23" Widescreen DVI LCD...
What dual video card is compatible with the M52?
The 256MB ATI Radeon HD 2400 XT Dual-VGA or Dual-DVI, TV-Out Graphics Card (43R1962)
The 128MB ATI RADEON X300 VGA, VGA PCI-e Dual Head Graphics Adapter (40Y8405)
The 64MB NVIDIA GeForce 6200 VGA PCI-e Dual Head ThinkCentre Graphics Adapter (73P2517)
The 256MB ATI Radeon X1300 Dual-VGA or Dual-DVI, TV-out PCI-Express Graphics Adapter (41U5028)
The 128MB ATI RADEON X300SE Dual-VGA or Dual-DVI Dual Head ThinkCentre and Lenovo PCI-e graphics adapter (41U4813)
The 128MB ATI RADEON X700 VGA, DVI-I, TV-Out PCI-e Dual Head ThinkCentre Graphics Adapter (73P2518)
All above are compatible with the ThinkCentre M52. Hope this helps, Best Regards, - md
Nov 10, 2009 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
Video card/dual monitor set up
If the card has dual monitor dvi out puts your set if not your going to need a new card
Apr 03, 2009 | Computers & Internet
Dell 410XPs + Dell 3007WFP monitor issues
Vinod,
That's quite strange as during system startup you should see the Dell POST logo as at that point the card is only running at VGA, and the monitor will support display at this resolution. If you connect with a normal single DVI cable the monitor should display at 1280x800 also.
Have you tried this? Also have you had this monitor working on another computer at all? What happens if you power up the 3007 with no video cable connected? It should cycle through the pixel test screens. If you are not getting that, and you are not getting the pre POST logo during powerup i suspect that it is a screen failure.
Aug 03, 2008 | Dell Dimension XPS PC Desktop
Switch to alternate 2 computers and dual monitors
What you probably want is a KVM (Keyboard, Video, Mouse) switch that supports dual monitors. It's a simple device that allows you to plug multiple computers into one set of monitors, keyboard, and mouse and switch between controlling them.
I don't know of any that support mixing analog and digital connections for the monitors, but using a VGA to DVI adapter for one of the monitors should solve that problem cheaply.
Dec 14, 2007 | Computers & Internet
Toshiba Advanced Port Replicator III (PA3314U-1PRP) Logo
2,134 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
