Question about Pioneer Car Amplifier GM-5100T - 2CH 760 Watts Car Audio Amplifier
There is no sound coming from my 15's when my stereo is on
My 760 watt pioneer amp works fine and all the wiring is right, but when i turn my stereo on nothing comes out of my two 15's. Could it possibly be the rca jacks in my stereo?
  • oneluv1102 Feb 12, 2009
    i bought new rcas and a new remote and had radio and amp tested they both work but i get no sound out my subs still
  • Anonymous Mar 07, 2009
    I just bought this amp and the blue light comes on... i have the remote wire tapped in to my stereos remote wire.. is this correct? If so.. i still get no sound.. could it be the rca's on my stereo?
Check the voltage at the amplifier when on should Have 12V on PWR and Rem. Have seen situations where the amp powers but the voltage is low so the amp does not work...
Also check your Subwoofers make sure they are good. and the connections to the subs. The wire inside the box and to the amp.
Posted on Mar 19, 2009
    President:
  • 1,990 Answers
It is Either the RCA Jacks or the Blue Remote Lead Wire is Bad or Loose in the Harness inside the Dash. Please Rate My Response! Thanks!
Posted on Feb 03, 2009
Can I hook two 12in. Subs up with a 1100w amp. Sony explode, pioneer subs
Yes....hook one up to the left channel and one up to the right.....once everything is wired up.....keep gain down on amp and turn stereo on.....turn up stereo with amp gain down to right before high end speakers start to distort......then while its playing, turn amp gain up about 1/2 way. close your trunk and hop in drivers seat....sound gd????? You might have to adjust level on amp and bass on head unit to taste.....Be careful though....pioneer subs are only rated around 300 watts continuous.....dont want to blow them...gd luck....
Mar 20, 2012 | Pioneer Car Audio & Video
I have mine hooked up to two 12in pionners it worked fine and then after about a year everytime they hit it will blow the fuses
So maybe that amp isn't made to go or take that much amount of power. It is only a 760 watt so i would say you might want to think about upgrading. Also check your battery wire and your ground wire
Jan 20, 2010 | Pioneer GM-5300T Car Audio Amplifier
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
Hi i have 760w pioneer that i am selling but i dont think it works because the red light does not come on when the wires are connected..are they're special wires that should be used for it to be connected?...
IF THE WIRING WAS RIGHT, THOUGH THE WIRE SIZE HE USE TO CHECK WAS NOT PERFACT, IT SHOULD HAD COME ON FOR ATLIST AS TESTING RESULT, CHECK THE WIRING AGAIN, AND FUSE..HOPE IT WORKS
Oct 13, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Sub woofers and amp
first of all is the amp a four way amp? if so then you need to know what the watts of the subs are (you dont want to melt them) wire + and - of channels 1 and 2 to one sub and + and - of channel 3 and 4 to second sub, nice thick lead from battery positive (fused) to positive terminal on amp thick lead from a good earth point to negative terminal on amp run a set of rca leads down the opposte side to the positive wire to prevent interference, run thin wire from remote wire of radio to the remote terminal of amp, rca's are plugged in at stereo and at the am. may need a RCA splitter to be able to power all four channels
Good luck Davelee
Mar 24, 2009 | Car Audio & Video
I have a lightnig audio amp its 760 watts not sure whats wrong
Did it stopped working ?
check your main fuse line under the hood ?
you should have one ! replace it ?
know if it works fine out what ohms is your amp best plays at!
and connect the correct woofer ohms ..
for that power at the most two 8 inch woofers or one 12 ich thats pushing it!
Mar 09, 2009 | Lightning Audio Amplifier, B3.200.2 Car...
Support Question about RMS
you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
if you have any questions email me at thadoggma420@hotmail.com
Jan 22, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Hits intemittently
ive had problems kinda like this ... normaly its a crossed or reversed speaker wire check the positive and negitive wire into the speakers "they move sometimes when there is more air moving around the speaker"
second make sure you have the impedence correct "possitive to positive negitive to negitive'
hope this helps
Dec 21, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Pioneer Car Amplifier GM-5100T - 2CH 760 Watts Car Audio Amplifier Logo
271 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
