Question about Canon ImageRUNNER 1670F Copier
Canon D860 - I get a solid black line when I use paper feeder.
This problem began after a paper started into the document feeder and I stopped it. After this I began to get a solid line when I use the document paper feeder. I do not get this line when I manually place the document on the glass and copy it that way. Is there a way to correct this problem?
I'm pretty sure you might have solved this problem already, but this might help others.
Make sure that the platen glass is clean near the right side of the machine, where the document is scanned when going through the document scanner. Remember, when placing a document on the glass to copy it that way, you would place it on the glass on the left side of the machine. When scanning through the ADF, the scanning unit itself moves to the right side of glass and scans the document as it moves through.
We had the same issue and found out that there was a little spec of dirt on the glass. After cleaning it, the problem was solved.
Posted on Jul 21, 2009
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
Canon imageCLASS D860, starts fine feeds paper through toner end then stops half way through. Sytem shows paper jam, but paper just stops moving. I can open it and lift paper out. paper wt. 20
try cleaning the pick-up and feed rollers with alcohol and see if that takes care of the problem. if it does for a short time that you need to replace those rollers
Feb 19, 2011 | Canon imageCLASS D860 All-In-One Laser...
Shadow along edge of my SHARP DM-3551 copier's copies
Run a page with the cover or document feeder open. Just a solid black page. If the shadow runs completely edge to edge on the paper, your problem is in the drum unit or less likely the fiser.. If the there is a clean edge delete, then the problem is either dirty scanner mirrors or the laser. It is far less likely in the optical/laser system but still likely. I tend to believe the problem is in the drum unit.
Mar 12, 2010 | Canon imageCLASS D860 All-In-One Laser...
Line appears on copies when using the automatic feeder.
You have a piece of dirt or whiteout on the scanner glass. When the paper is moving by, it creates a "Line" if the paper is sitting still on the glass, it may be a dot or it may even use a different glass alltogether for ADF vs Paltten scanning.
Jun 09, 2009 | Canon imageCLASS D860 All-In-One Laser...
My canon MP830 produces a thin vertical black line on documents fed through the document feeder to be copied or faxed. This only happens using the document feeder.
The expert told me to run a porous piece of paper through the adf 10 to 15 times. I used a piece of Avery textured paper for notecards that I had. The problem was solved after about 5 runs through.
Mar 19, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Line on ADF feeder
Clean the narrow piece of glass inside the machine next to the large glass.
Oct 21, 2008 | Canon imageCLASS D860 All-In-One Laser...
Black lines
There is a small strip of glass that the document feeder uses. Once you clean off the section, the lines will go away. Even a tiny speck will cause that to happen.
Aug 14, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Nov 06, 2007 | Canon imageCLASS D860 All-In-One Laser...
Canon ImageRUNNER 1670F Copier Logo
191 people viewed this question
old marine
old marine
