Question about Pioneer AVH-P5700DVD Car DVD Player
Avh p5700dvd ..Noisy distorted sound from RCA output
When i connect my rca to my amp it makes distorted sound..
  • 1 more comment
  • sleeziee Feb 06, 2009
    ooh ok thanks for the help... would you be able to fix it if i send it in to you? and how much would it cost me?
    ok that sounds good to me. as soon as i get the money i will be in contact with you. is 75 the price you want to fix it?
  • Anonymous Apr 28, 2009
    hey , i just recently rewired my amp and everything and hooked up power antenna and hooked it all back up and when i get i got this thumpin noise everytime i hook in the rca's ... take them out and noise is gone i replaced the wires 3 times still same problem .. u think that i have same problem as the other guy or do i have a diff problem ?
    President:
  • 624 Answers
This model of Pioneer has a common problem with a couple of fuses that are inside the unit mounted on the main circuit board that will blow. These are surface mounted fuses, and must be replaced with the same type of fuse. They are very small and white colored and require some good soldering skills and the proper soldering equipment do this job properly.
I work at an authorized Pioneer service center and have seen this problem many times. These units are very difficult to open up and work on. It is very easy to damage the ribbon cable that connects the flip out monitor to the main circuit board if not done perfectly.
What you can do as a work around for a short time, until you can get it in for repair, is this shortcut. It will restore your audio, but should not be considered a permanent fix.
At the amplifier (since it is easier to get at than the RCA cords coming out of the back of the Pioneer) you need to connect a jumper wire from the RCA ground on the jack to the power ground on the amplifier. The outer metal part of the RCA jack is the ground, the metal pin in the middle is the positive.
Remember, this is only a short term temporary work around and is not a permanent repair. You just need to supply the RCA output ground with a good ground.
The repair of replacing the surface mounted fuses can cost anywhere from $100 to $160, depending on the service center rates. Just don't wait too long, or play the amplifier too loud in the meantime.
Posted on Feb 05, 2009
  • Dave DeGain
    Dave DeGain Feb 06, 2009
    Yes I could fix it for you, but I am in Texas and you would need to ship it to me and pay for the repair before it was shipped back.
    I could probably do it for about $75 plus shipping back to you as long as this is the problem. Like I said before, it is a common problem with these, but it is possible that it could be something else, but that is unlikely.
    Let me know and I will tell you where to send it. I would also need the harness from the car so I could test it after it is repaired to be sure it is fixed. Otherwise, you would get it back untested and no guarantee that it works.
  • Dave DeGain
    Yes, $75 for the repair plus you will need to pay the shipping also.
Power but no sound help plz....
well here we go how do you have your pioneer radio connected .
did you run the radio speaker wire out to the factory speaker or did you have an amp connected to the rca output jacks.
1 well if the radio connect by the speaker wire out the
output chip in the radio is fried and needs repair ....
2. if u have a amp connected to power your speakers for sound
check the amp to make sure you have power and no lose connection or speaker wires disconnected.
3. it also possible that the rca jacks are fried too
I no by experience that pioneer loses ground on the audio output jack (rca) well what we did to fix it is..
take and 18 gauge wire stripe back about 1/2" to 1" of the insulation to expose the copper wire and wrap this around the metal casing of the rca jacks and then ground the wire to a ground point do this for both left and right rca jacks...
radiorepair@windowtintingin239.com
Oct 30, 2013 | Pioneer DEH-P3500 CD Player
Wiring diagram avh-p6300bt
i have a pioneer AVH-P6300BT but im not sure if i have i connected correctly with my amp. my speakers just dont seem to be pushing the power i know they can. so for starters which wire is the remote wire? i have the RCA's connected to the one that is labeled"Subwoofer output" is this correct? The wiring diagram also talks about connecting to the violet and violet/black wires for the subwoofers whats this for?
Apr 30, 2012 | Pioneer Car Audio & Video
Why does my pioneer deh-14ub only play bass through the RCA jacks
You need to go into the menu and check what the crossover levels are set for, you will find that the speakers are set to only reproduce the higher levels and not the bass.
Mar 06, 2012 | Pioneer AVH-P5700DVD Car DVD Player
Can i hook an ipod up through an aux cable that plugs in to the ipod . its the red and white aux cable and it plugs into the earphone place on an ipod
If you are talking about the cable I think you are, all you do is plug the red and white rca into the input of your choice on the back of your radio and the other end into your choice of audio output (anything with that size headphone port).
Sep 19, 2010 | Pioneer AVH-P5700DVD Car DVD Player
How to connect ipod to the Avh-p5700dvd
You should connect the cable to the audio in. You will then need to change input(source) on the radio to auxilary. Good Luck.
May 27, 2010 | Pioneer AVH-P5700DVD Car DVD Player
AVH-P5900DVD noise in RCA
there is diodes that you can change to stop the noice or even a capisitor but not fuses. if you look at the capsitors see if the tops of them are buldging or leaking. that is a sign of them being bad and will need to be replaced. the ones you want to look for will be right were the rca's come into the radio from the back.
Mar 11, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Help i need a wiring diagram for a pioneer avh-p5700dvd to connect to a wiring harness and a tr-7 output module
ftp://extra.abt.com/PDF_Files/avhp5700dvd_installation.pdf
This is the installation manual for the AVH-P5700DVD, including a wiring diagram for the wiring harness.
http://www.pac-audio.com/PACProductData/TR7/1_Instructions/tr-7_instructions_010505.pdf
This is the wiring diagram for the PAC TR-7 UNIVERSAL TRIGGER OUTPUT MODULE VIDEO BYPASS.
Jan 12, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Sound Distortion on Mlt1912
The hard way, if you have the skill, is to replace the speakers.  The bad news is that this probable won't fix it as it is likely that it is internal noise causing the distortion.
there is an easy solution that will probable work.  Using the audio output connection you could hook it up to a stereo system or boom box and use those for sound.   the only thing technical is making sute your cord has the right connectors/adapters on each end.  take a picutre or a good look at both devices audio connectors (output on the TV, input on the Stereo/boombox) and the salesman at your local electronics store should be able to help you find just what you need.
at a guess you will likely need an RCA female to RCA female cord or an RCA to stereo mini male.
hope this helps.
Long_Knight
Sep 02, 2008 | Memorex Televison & Video
Video ipod
you have to get an iPod cable that gives you RCA outputs. Just connect the RCA outputs from the iPod to the AUX inputs on the unit. I believe that should do it. Ebay sells the iPod cables, and most electronics stores should as well
Dec 22, 2007 | Pioneer AVH-P5700DVD Car DVD Player
Pioneer AVH-P5700DVD Car DVD Player Logo
641 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
