Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Side by side freezer freezes then unfreezes
It is frozen and makes cubes then it unfreezes leaves water on floor then freezes again.
  • Frigidaire Master
  • 4,655 Answers
With the thermostat turned to its coldest setting can you hear or feel the compressor running? Can you find the defrost timer inside the refrigerator and turn it until the compressor stops, and then please let me know, the defrost time may be bad and sticking or slow leaving the refrigerator in defrost too long, let me know soon
Posted on Feb 03, 2009
Ice cube tray does not fill up water feeding tube is frozen.
The problem you are having is caused by water leaking past the=> MJX42111401 Water Inlet Valve Change the MJX42111401 Water Inlet Valve and this will solve the water freezing between ice harvest. On most refrigerators this part can be found on the back of refrigerator and near floor, Let me know if you have other questions, Thanks Sea Breeze
May 24, 2012 | LG LSC27910 (265 cu ft) Side by Side...
Model GSL22JFPHBS
Try to clean you condenser coils and also adjust the the fan behind the freezer panel inside...It must help you out!!...But basically did you reduce your Temperature in the Refridgerator to most possible minimum value??...Thank you...
Please Post back on how things turned or for further assistance...
Regards!!!...
Jul 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frozen freezer water line
Odds are your temperature is too cold in your freezer. If when you moved you just plugged in your freezer without adjusting your temperate for your new location you accidentally froze whatever water was coming into your freezer.
First you will need a cooler for whatever you have in your freezer, unless you have wonderful neighbors who will let you keep your food in their freezer for couple of days.
Take note to see what your freezer thermostat is set to. Turn off your freezer. Take out all the food. Keep the door open. This would be a great time to clean your freezer. Let the freezer thaw out for at least one day. Check the line to make sure there is no ice. Once everything has melted turn your freezer back on. Turn your freezer back on but this time set the thermostat to three or maybe 4 levels below what you had it set to before.
Finding Freezing level:
Fill an ice cube tray or small plastic cup with water. Put it in your freezer and come back in about three hours to see if has begun to freeze. If it has not begun to ice raise your thermostat to make you freezer colder by half or 1 level. Leave the ice tray or cup of water that you originally placed in the freezer but add another one. Come back in three hours to see if the water has frozen or has begun to freeze.
You want to leave the original water because you need to make sure the new water does not freeze solid as fast as the original water. If it does your freezer is too cold again.
Repeat "Finding Freezing level" until the water begins to freeze but does not freeze solid. Once your ice begins to free you can put your food back into the freezer. Wait a couple of hours more to see how much more your cubes freeze. If they are hollow or still watery in the center you should go up another half level and check on it the next day.
Once your cubes freeze solid you should be all set. If you don't get at least one tray of ice per day from your freezer you could go up another half level so your ice freezes faster.
Be careful about making your freezer colder because you might end up with the same problem you started with depending on how sesitive you thermostat is.
May 03, 2012 | Maytag MSD2578VEM (254 cu ft) Side by Side...
Water collecting under the freezer drawer, then freezing
We just had a similar problem with our Maytag side-by-side in the bottom of the freezer. Just as you described...sort of a glacier on the floor of the freezer that slowly melts toward the door. After several attempts to remove the ice, only to have it form again, my husband spoke with a helpful sales person in an appliance center. He said there's a drainage plug/line on the back that's supposed to funnel condensation to the evaporation tray underneath. It gets clogged and frozen. Sure enough...my husband pulled out the freezer, opened the visible line and it was all frozen and full of gunk. He had to use a hair dryer to thaw it out, then flushed it. It was amazing how much stuff came out of there. We've had no more problem since.
Apr 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice builds up in bottom of freezer and water leaks onto floor
Sounds like the evaporator drain duct has either blocked or frozen. When the appliance goes into its defrost cycle the water has no where to go apart from the floor of the freezer cavity. When the appliance starts again the water freezes until the cycle starts again.
Sep 22, 2009 | Jenn-Air JCD2389G Side by Side...
Freezer is not making ice, help?
Pour about 1/2 cup of water into icemaker . If it dumps the cubes after freezing , but doesn't refill with water , then replace the water inlet valve ( part that wall water line connects to on fridge ). If the icemaker does not dump and holds the frozen cubes , replace the icemaker . Also check the fill tube at the icemaker to make sure it is not frozen closed , due to a seeping water valve , and make sure the coils are clean beneath refrig of dust , lint , pet hair , etc.
Aug 28, 2009 | Frigidaire FRS26H5AS Side by Side...
No water from door dispenser
BAD WATER VALVE OR CHECK FOR CLOGGED FILTER
Jun 18, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Water line to water dispenser is freezing up inside the freezer
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 27, 2008 | GE GSL25JFPBS Side by Side Refrigerator
GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer Problem
The only thing I can think of is your icemaker heater is staying on. When your icemaker goes into a harvest mode, (dumping ice and then re-filling with water) there is a "U" shaped heater (located on the under side of the icemaker) that comes on to release the frozen cubes from the icemaker mold. If this heater is continuously hot, it will cause temperatures in the freezer to rise.
Oct 04, 2007 | Whirlpool GS6SHEXMB / GS6SHEXMQ /...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
157 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
