Question about Kenmore 24 in. 15079 Built-in Dishwasher
Dishes on top rack don't get clean
I have a Kenmore Elite Model 665 15922001 serial FK4501032
stock# 15922 and the Dishes on top rack don't get clean, can you please help??
  • 10,865 Answers
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Posted on Feb 03, 2009
I have a Kenmore built in dishwasher. Serial Number 15989990 Model 665. My dishes are not getting clean. Lots of residue on glasses on top rack and dishes streaked. Any ideas? We thought it might be the...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 06, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore elite model 665 17263402 The top rack is not cleaning the dishes. The bottom rack is cleaning fine. What is causing this and how can I fix it? Please help.
Dishwasher
How to Buy
heatman101
Jan 16, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My model # 665-16264402, Kenmore Elite. It's not cleaning the dishes on the top rack & barely on the bottom after even running it twice. It has an automatic filter so I know that's not it. Please...
Dishwasher
How to Buy
heatman101
Jan 01, 2011 | Kenmore 24 in. 16269 Built-in Dishwasher
Hello: I have a Kenmore Elite diswasher Model #665-16264402. It will not clean the dishes on the top rack much at all. To be honest it's not cleaning well on top or bottom! It has a built in filter,...
Hi, Colleen. Thanks for using fixya.com. I suspect the chopper may be plugged which would cause poor circulation and poor washing results. The chopper is located in the sump housing assembly and is #6 in the picture below. It is accessed by removing the lower spray arm and the filter assembly. Disassembly requires a T10 and T15 Torx screwdriver. Once disassembled, use the picture as a guide for locating the chopper and clean or replace as necessary. Part number is 8268383 and is available at www.appliancezone.com.
Jan 01, 2011 | Kenmore Dishwashers
Dishes not clean?
Check all the water jet orfices in the moving arm. Try cleaning without loading the top rack.
If cleans well, mostly the upper rack dishes not arranged properly.
I hope you are using the main wash detergents. Rinse aid is just to remove the stains after the main wash rinse.
Apr 01, 2010 | Dishwashers
The upper sprayarm flows water but does not turn. Therefore dishes in upper rack are not geting cleaned.
i have a kenmore elite dishwasher model 665.16059400, i need a lower spray arm nut, nobody can find this part, i've been to sears and also to their on line parts department 3 times and have come up empty, the last time i was assured that the nut would be included with a new spray arm if i ordered one, it was not,i know the spray arm was made by whirlpool, is there anyone out there who knows the solution to this simple problem? does whirlpool have a cross referance model number i can use to find this part
Apr 29, 2009 | Dishwashers
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
The top rack on my kenmore dishwasher is not cleaning the dishes!
check the inlet strainer at the bottom of the unit - and also the nozzles on the top are for clogs/sediment.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Kenmore Elite 45986 Front Load Washer
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Kenmore 24 in. 15079 Built-in Dishwasher Logo
612 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
