Sometimes my bluray/DVD player works just fine. But sometimes, I put a disk in and I hear it spinning very loudly and my player software (I have both VLC and PowerDVD) just seem to load indefinitely. If I pop the disk out and reinsert it sometimes this fixes things, but I'm just wondering what I'm doing wrong in the first place or why it keeps acting up
SOURCE: universal remote code for samsung bluray dvd player
I have a Samsung blu-ray dvd player,non of the codes seem to work with my universal remote.
Help.
SOURCE: My DVD/CDROM is acting funny. DVDs play fine, CDs
1. Try to gently clean pickup lens with q tip and 70% or lower alcohol or vodka. Don't push down.
If didn't help:
2. Compressed air (gently) around pickup lens.
DON'T do a short bursts. Just press, hold and move around the lens.
SOURCE: DVD stuck, computer won't turn back on
If you look at the door of the CD/DVD tray/shelf, you should see a little hole. Stick a paper clip into the hole and it will pop out the CD/DVD tray/shelf and you can get your DVD back. I would call Gateway support to fix the rest of it. If it is still under warranty, they can send out a tech to fix it.
SOURCE: Movie 2012 BluRay loads menu but won't play on
Sony releases new firmware for the bdp-s350 ever so often to let it play newer movies. The last one can be downloaded from here firmware. Be sure to contact Sony with any problems so they can work on it for the next firmware. They are pretty good about updates as long as we let them know of any problems we are having.
If you are continuing to have problems let me know by sending me a message in the comments and I will go from there. I will get back to you as soon as possible.
Take it easy and hope I helped.
Hi there, this is a problem with ALL Bluray players, it is an annoying format problem, where "resume play "is not available on JAVA enabled Blurays, (BD-J).
JAVA content is usually the interactive menus and extra features on specific Blurays. These are essentially computer programs, so when you close them and re-open them they open from the beginning, (Just like on your computer, when you close a program).
All standard DVD's and non BD-J discs will resume play as expected, this is why some people think there is an intermittent fault, and others say that there model of player is working fine. Hope this helps.
Here is an link to SonyAsia's FAQ
