Question about Adobe Photoshop 7.0 for PC
My photoshop 7.0 will not load the program files
My photoshop 7.0 says " an error occurred during the move data process: -115 " I need help!
J
  • Kristin
    Kristin May 11, 2010
    What do you mean by "Program files" like programs like games off the computer or programs coming with the Photoshop program?
  • 323 Answers
I would advise to run photoshop 7.0 installation with the "run as administrator" command.
If you don't know what I mean.
You right click the exe file and it will give you an option to install as an administrator.
Posted on Feb 04, 2009
Photoshop file info data cannot be read. How to fix it?
hi,
when you have your document opened, look every layer to find little yellow triangle(s), witch means that there is a problem with this(those) layer(s), it can be (more often) the text layers that have fonts that you don't have installed, or a reference file that has been moved from original path.
hope you'll solve that !
cheers
mich
May 07, 2015 | Adobe Photoshop 7.0 for PC
CHECKSUM CANNOT MOVE COMPUTER FROM A BLUE SCREEN
In order to understand what a checksum error is, it is important to first learn what a checksum is. A checksum is a redundancy check during a computer's start up process, which makes sure that the computer's data is intact and unhampered. The data is scanned and tested for accuracy, either based on how well it relates to data elsewhere or based on previous data that was stored on the same computer. Essentially, all of the bits of data in a particular document or file are added up and a number or hash is created. This number or hash can then be compared to the number or hash generated from the same file on another person's computer or at a previous time on the same computer.
When does a Checksum Error Occur?
Although a checksum error can occur at any time while a computer is comparing data, it is most commonly present during a computer's startup procedure. During a computer's start up processes, the BIOS settings, which are stored in a CMOS memory chip, are computed and then checked against the previous value. If the computed values do not match exactly, the computer warns the user with a checksum error message that the data may have been changed or corrupted between start up cycles. All BIOS programs present a different error and therefore will either continue with booting or refuse to boot until the problem is corrected.
Depending on the type and the severity of the error generated, there may be one of a variety of ways to rectify the issue. The most common cause of a checksum error during the startup process is a faulty battery that is not providing sufficient power to the motherboard when the computer is off. However, motherboard malfunctions and viruses can also contribute to checksum errors.
Other Types of Checksum Errors
Another type of checksum error may occur with any program at any time. It is usual for many programs to now provide checksum information when that program is downloaded. Using a checksum program or MD5 hash checker, a user can quickly compare the checksum of a downloaded program with the checksum that the software developer provides. This is a common way to make sure that users are downloading the proper program and that no data was corrupted during the download process. Checksum errors originating from download errors can easily be corrected by re-downloading the problematic program.
if you have a windows disk you might try doing a repair from disk
Apr 14, 2013 | Dell Inspiron Computers & Internet
While adobe photoshop 7.0 installation, error -115 is coming. Can you please assist me regarding this installation problem.
The probable causes could be due to Data for CD not transfering during the installation.
Here some options you can try,
1. Infected PCs. (Scan PC for virus & malwares)
2. Dirty or bad CD installer. (Use another CD)
3. HDD space for the installation.(Remove some of your data for space allocations)
4. Security Programs running in the background. (Disabled any Security Programs before installations)
5. Too many junk files in your "temp" folder. (Use the CCleaner to clean up your PC and reinstall the program.)
Hope it helps & good luck.
May 13, 2011 | Adobe Photoshop 7.0 for PC
The program will not load , error message not enouph memory
Hold the CTRL key down while this software is starting. This process will prompt you to recover the catalog. If you don't see this pop window then try it again as timing this right will ensure you see the window.
If your catalog cannot be recovered then rename the hidden file psa.prf - This file can located under your user profile folder:
Windows 2000 / Windows XP - C:\Documents and Settings\[username]Application Data\Adobe\Photoshop Elements\3.0\Organizer
Vista or Windows 7 - C:\Users\[username]Application Data\Adobe\Photoshop Elements\3.0\Organizer
Jan 28, 2011 | Adobe Photoshop Elements 3.0 plus Premiere...
After shutting down the computer a few times when transfer file from PC to CAXE3702T0, all of a sudden, blue screen and when the Window 7 boot up again, it said the CAXE3702T0 has CRC problem. I tried...
CRC or Cyclic Redundancy Check is a process that helps in identifying any errors that might occur during the data transmission process. Data is usually transmitted in small blocks, and a CRC value is assigned to each block and transmitted along with it. This CRC value is verified at the destination to ensure that it matches the CRC value transmitted from the source. A CRC error occurs when the two values (source and destination) do not match and the test fails. The main benefit of CRC is that it helps you ensure that data you have received or downloaded is not damaged or corrupt.
Causes of CRC Errors
CRC errors can occur due to many different types of problems. Some of these problems are:
  1. Damage to file during the transmission process.
  2. A problem occurred when the file was being sent.
  3. Problems with the device that is accessing or opening the file.
  4. Problems with the file itself.
Jan 14, 2011 | Cavalry Storage (CAXE3702T0) USB Hard...
MY SIERRA 3D HOME PROGRAM THAT USED TO WORK NOW SHOWS THIS WHILE TRYING TO DOWNLOAD, ONLY GETS TO ABOUT 98% COMPLETE WHEN THIS SHOWS UP AND WON'T FINISH INSTALLING. A ERROR OCCURED DURING THE MOVE DATA...
Clean the disc, take contact salution or what I do use men's cologn on the disc side and use a lens cloth or a non abrasive cloth to clean the disc and try installing it again. If that doesnt work, check for scratches and that could be the reason it wont install.
DrakeTech
Dec 30, 2009 | Sierra Custom Home 3D (63002)
Photoshop 7.0 installation fails with the error message: "An error occurred during the move data process : -106" Upon install process it makes it to about 1% then gives the following error code....
one problem that could cause this error is lack of administrator rights,
right button click the setup.exe or whatever it called and select run as administrator,
Or if it's Vista try the compatiblity help , right button click the app, select properties and select run as XP service pack2 etc
Regards
gewiz.co.uk
Nov 30, 2009 | Computers & Internet
ERROR CODE 106
restore your system to previous date where its working fine then check
Nov 05, 2008 | Adobe Photoshop 7.0 for PC
Installing error code -106
I suggest go to Start/Settings/Control Panel/Add remove programs.
Check and see if the program is in list and remove it. While in control panel go to system/Device Drivers check non have a yellow mark on them if so reinstall drivers or upgrade Reboot and try again.
Jul 22, 2008 | Computers & Internet
what this suggests is that the files cannot be transfered to the hard drive because of either you havent the latest version of .net http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&DisplayLang=en, or you are low on hard drive space or afaulty disc. download from the above link first, then if still not installing try copying all the installation files across to your pc and try again, but check you have enough hard drive space.
Aug 24, 2007 | Adobe Photoshop 7.0 for PC
Adobe Photoshop 7.0 for PC Logo
123 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
