Some times it get switch off completely and cannot receive calls or messages. Then we need to take out battery and reset to use. 2, 3 times it happened last 3 weeks after purchase.
SOURCE: problem with my samsung SGH-j600 phone
My touch sensative buttons have stopped working is their any way of fixing this problem??
SOURCE: samsung j700
you can try to enter 0000 or 00000000, if it will not work you can contact your service provider and ask assistance to get the code for the phone
For Chevrolet only, the shift lever is in FIRST (1) or SECOND (2) gear. The EBCM receives a class 2 message from the powertrain control module (PCM) indicating the gear position.
For Pontiac and Oldsmobile only, the body control module (BCM) detects that the traction control switch is pressed (signal circuit is low). The EBCM receives a class 2 message from the BCM indicating the switch status.
The BCM detects that the park brake is engaged (signal circuit is low) and that the engine is on. The EBCM receives a class 2 message from the BCM indicating the park brake status.
The PCM detects certain malfunctions and is unable to perform torque reduction requests from the EBCM. The EBCM receives a class 2 message from the PCM indicating that traction control cannot be performed.
The EBCM detects a malfunction in the traction control system. The IPC receives class 2 messages from the EBCM requesting illumination of both the service vehicle soon and traction off indicators.
The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
With the light lit there are DTC'S - diagnostic trouble codes stored in the EBCM -
TRAC OFF
Traction Off: Refer to ABS Description and Operation in Antilock Brake System
