Question about Kenmore 22422 Top Load Washer
Tub won't agitate (or spin)
Working fine one day... and with the next load it wouldn't spin out the clothing... tried to see if it would agitate the wash, and it wouldn't. Tub won't move... center won't move. Any ideas?
  • 1 more comment
  • gtcampbell Feb 03, 2009
    model number 110-4121092 does not have a display. The motor sounds like it's running, but the agitator won't turn at all. Also, the tub won't spin on the spin-cycle to drain the water off the clothes. Hope you can help. Thank you.
  • gtcampbell Feb 06, 2009
    Hi Fixya. I had a repairman come in and told him about the solution on this web-site (regarding a timer). He laughed and said that he can't believe someone would suggest something like that (because that would be the last thing that would ever breakdown). Anyway, our problem was that the couplers had worn down. That's it...a $20.00 part.
    Even though you didn't get the prognosis right, I still appreciate you trying to help. Thanks again.
  • Carmen Mikulic May 11, 2010
    The reason it's not moving is because the motor may have seized. Can you clarify if you hear the motor running. Any lights on the display?
    Sergeant:
  • 409 Answers
That's great, that leaves me to believe that it's the timer. I would recommend replacing it.
Posted on Feb 04, 2009
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
Dec 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer won't spin. It stop and gave me a warning "UE". What is this mean. Please help me.
I have a LG LNC6753A71 the washer agitates drains rinses but won't spin. The motor runs but it won't spin.
May 01, 2011 | LG WM0642H Front Load
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Tub won't spin
Your direct drive coupling is broken. Follow the instruction in this video for repair.
Apr 21, 2009 | Kenmore 24032\24036 Top Load Washer
KENMORE WASHING MACHINE MODEL#110. 254872300 WONT SPIN
if your sure it will agitate?[because the pump is on the other side of the motor and will drain,but if coupler broken ,wont agitate or spin although it makes noise like its working.so if will truely agitate drive coupler fine and its going to be the clutch or that area unless somthing[clothing] is between the two tubs creating anough resistance to stop the tub from taking off.clutch pads will just slip on drive plate.hope that helps>God bless ,tom
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
WASHER AGITATES WHEN SUPPOSE TO SPIN
Faulty spin windings on motor. Regards Advisor
Sep 01, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 22422 Top Load Washer Logo
81 people viewed this question
Sal De
fordexpert
Robert Rankin
