Question about Sentry Fireproof Safe
S3877 Sentry safe will not open, get green light but lever
I have had this safe for 5 years and never had a problem, today I put in the 5 digit code and it accepted and went green, heard the normal click noise yet the lever would not open, it was thought it never opened.
I am confused because the everything works like normal but the lever will not turn now as though it is bad. I replaced the batteries and it did not help. The code still works and it goes green yet it will not open.
Please advise...Thank you
-Paul
  • Anonymous Feb 14, 2009
    I have the same problem
It sounds like the selinoid went bad or stuck this pulls the plunger down to release the handle, you might be able to take out the key pad and determine the 2 wires that go to selinoid jumper them out with a nine volt battery good luck. p.s. this could ruin your safe, be carefull. bigds keys
Posted on Feb 04, 2009
Sentry safe reset instructions
You can get help here, but you will need to prove ownership... http://www.sentrysafe.com/CustomerCare/
Jul 14, 2014 | Home Security
I have a Sentry safe S3877 the batteries were replaced with new it still gives the error beeps for batteries need to be replaced the safe will not open, how can I get the safe to open?
A1 Locksmith Burlingame CA Once you get the error light that means you are entering a user code that was deleted when the batteries went dead . Simply replace the batteries then use the master code in your owners manual to open the safe. Reprogram new user code instructions bottom of this page.
Apr 17, 2013 | Sentry Fireproof Safe
How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sep 23, 2012 | Sentry Fireproof Safe
Somehow can open my sentry s3877 with the keypad.
A Safe and Vault Tech Will confirm that once you change the batteries the user code will erase and you will now have to enter the factory default that is in the owners manual and then use the programing instructions to program a new user code.
Jan 07, 2010 | Sentry Fireproof Safe
My combination to s3877 works, but key button is pressed by accident and I can't find the keys to unpop it. How do I get it open. Light turns green after inputting the code, but level is unmovable.
You will need to contact customer service (either in the UK or US) for the replacement keys - without the keys you can't get into the safe. The key barrel is a secondary lock and needs to be unlocked before you can use the digital or dial combination.
Dec 14, 2009 | Sentry Fireproof Safe
Safe SENTRY S3877 can not open the door
The door lock could be jammed try shacking briskly to losen lid and latch! akso it may have reset itself and the combo is no good no more and back to the origanal setting it had when you bought it ! ( if its a 911 you can put a screwdriver in where key goes and turn hard counter clockwise)
Good Luck!
Jan 02, 2009 | Sentry Fireproof Safe
Factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Nov 23, 2008 | Sentry Fireproof Safe
Changing the code on my Sentry Safe S3877
how to change the on sentry safe s3877
Sep 29, 2008 | Sentry Fireproof Safe
Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Mar 29, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
1,280 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
