Question about Zenith B32A24Z 32" TV
PICTURE COMES ON THEN BLOOMS FADES
THE PICTURE COMES ON OKAY ,THEN FADES OUT OF FOCUS , BLOOMS. COULD THAT BE A POWER BOARD FAILURE?
    Sergeant:
    Champion:
  • 318 Answers
The problem is onthe power supply,
one of the semi- conductor is heating up
Posted on Apr 24, 2009
My VIzio E550i-B2 TV has no picture and no sound. Do I need a new power supply board?
What does the power indicator on the front of the set do when the on button is pushed?
Nov 29, 2017 | Vizio Televison & Video
Vizio e370vle has sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Dec 22, 2014 | Vizio Televison & Video
Sanyo dp42849 picture is slow
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 22, 2017 | Sanyo DP42849 42 in. HDTV
Tv says fan 2 going out ! Picture is starting to fad away!
If the picture faded away on the order of 10-20 seconds (and if it comes back, also comes up to full brightness in same time frame - possibly with the persuasion of some careful whacking) AND with NO other significant changes such as size, focus, etc., then take a look in the back of the tube for the filament to be lit - the orange glow near the CRT socket. If there is none, then you probably have a bad solder connection on the circuit board on the neck of the CRT. Look for fine cracks around pins on that board. Try prodding it with an insulating stick to see if the picture comes back. Resolder if necessary. Dirty or corroded CRT pins/socket contacts can also do this - remove, inspect, clean, and replace the neck board. It is probably not a bad CRT as the filaments are usually wired in parallel and all would not likely go bad at the same time.
However, if only a single color fades in and out, then a bad connection inside the CRT is a distinct possibility - look for only one of the filament's glow to be coming and going. This is probably not worth fixing.
If the picture faded away with other symptoms, then there is probably a fault in the video amplifier/output one of its power supplies - still probably a loose connection if you are able to get it back by whacking.
Good luck
May 26, 2010 | Televison & Video
Seeing a double picture when i use the touch focus feature, it comes up an error.
Convergence board failure no autofocus, This is a common failure on projection tv's. Change the convergence board or the STK's on that board and or associated burnt resistors in that area.
Mar 13, 2010 | Toshiba 57H81 57" Rear Projection...
My 42PC1DA is just under 3 years. It has been
Normally, it causes by failure of power supply board.
Aug 18, 2009 | LG 42PG20 42 in. Plasma HDTV
Screen fades to white
Most probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver IC thus you could only see white display. A replacement of LCD panel is the best solution. best regards
May 25, 2009 | Chi Mei Corporation 736A (Silver Black) 17...
Picture fades to black then reappears and repeats fades to black .
Is the sound ok. Yust the Picture. If both dissapear replace power supply board. That is the main big board with the most heatsinks on it. Main power gos from a switch board to main power supply.
Nov 21, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Zenith B32A24Z 32" TV Logo
134 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
