Question about RCA Universal Remote Control
Light does stay steady when holding down component key (TV)
The light does not stay lit like step 3 says for direct code entry.  can not do manually either.  why doesn't the remote indicator stay lit like the directions say it is supposed to?
  • 56 Answers
The eletronics could be bad
Posted on Feb 03, 2009
How do I program the remote to my tv
HI,
DIRECT CODE ENTRY
Step 1:Press and hold the device key (TV, VCR, SAT, etc) you wish to program. The illuminated ON/OFF key(*) turns on and remains on. If you release the device key at any time during theDirect Code Entryprocedure, the illuminated ON/OFF key blinks 4 times, and the process is exited.
Step 2:While holding down the device key, use the number keys (0-9) on the keypad to enter your equipment's code. While you are pressing the numbers, the illuminated ON/OFF key turns off.
FOR CODES CHE THE BELLOW ADDED LINK
Step 3:After the 4th number is entered, the illuminated ON/OFF key turns on. At this time, release the device key. If the illuminated ON/OFF key turns off, you have entered a valid code and have followed the correct procedure. If you enter a code that is not in the Code Lists or you do not follow all of the correct steps for Direct Code Entry, the illuminated ON/OFF key blinks 4 times when the component key is released - an indication that a programming error has occurred. In that case, repeat the process from Step 1 and try the next code in the list.
Step 4:To confirm that remote is programmed with the correct code for maximum functionality, test it. If some of the features of your equipment do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions as different codes can provide different levels of functionality.
* some models like the RCR450 have a LED indicator light in place of the illuminated ON/OFF key.
AUTO CODE SEARCH
If your component's brand is not listed in the code tables, or if you have tried all of the codes for your brand and the remote does not operate your component, try the Auto Code Search method below. The remote will cycle through all of the codes, in the event that your code is listed under another brand. TheAuto Code Searchmethod may take a long time because the remote searches through all of the codes in its memory for the code that operates your component. Therefore, if your brand appears in the code list you should try first theDirect Code Entrymethod described above.
Step 1:Manually turn on the device you want the remote to control (TV, VCR, DVD, cable box, etc.).
Step 2:Press and hold the device button (TV, VCR, DVD, etc.) you wish to program. The illuminated ON/OFF key turns on and remains on.
Step 3:While holding the component button down, press and hold the ON/OFF key. The illuminated ON/OFF key turns off.
Step 4:After holding down both keys for 3 seconds, the illuminated ON/OFF key turns back on.
Step 5:Release both keys. The illuminated ON/OFF key remains on.
Step 6:Press and release the PLAY button, then wait 5 seconds to see if your component turns off. If your component does not respond, continue to press the PLAY key every 5 seconds until your component turns off. Each time you press the PLAY key, the illuminated ON/OFF key blinks and a block of ten codes are sent to your component. This process continues until all of the codes have been searched. If your device has not turned off after all codes have been searched, the illuminated ON/OFF key blinks 4 times and turns off. The Auto Code Search Entry method is exited.
Step 7:When your equipment turns off, you know'll that the correct code is in the last block of 10 codes sent. Press and release the REVERSE key, Wait 2 seconds to see if your component turns on again. If your component does not respond, continue to press the REVERSE button every 2 seconds until your component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE key is pressed, the illuminated ON/OFF key blinks.
Note:If you accidentally press the REVERSE button after your device responds, press and release the FORWARD key. Wait 2 seconds to see if your component turns off again.
Step 8:Once your component turns on, you have found the correct code. You must save the new code by pressing and releasing the STOP key. The illuminated ON/OFF key turns off.
Important:You must press the STOP key to save the code or the correct code will not be stored!
MANUAL CODE ENTRY
Step 1:Manually turn on the component you want the remote to control and keep the remote pointed at it.
Step 2:Press and hold the component key (TV, VCR, DVD, etc.) you wish to program. The LED indicator light turns on and remains on.
Step 3:While holding the component key down, press and hold the ON/OFF key. The LED indicator light turns off.
Step 4:After holding down both keys for 3 seconds, the LED indicator light turns back on.
Step 5:Release both keys. The LED indicator light remains on.
Step 6:Press and release the ON/OFF key repeatedly until your component turns off. Each time you press the ON/OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
Because there are so many codes, you may have to press the ON/OFF key many times - possibly up to 200 times.
Step 7:Once you have found the correct code, you must save the new code by pressing and releasing the STOP key.
CODE RETRIEVAL
If you used one of the Code Search methods above to program your remote you may want to record the codes for future reference. Retrieving the actual code and writing it down will save you time if you ever need to program the remote again (when you change the batteries for example). If the codes are recorded, you can use the Direct Entry method to reprogram your remote to control your device, which is quick and easy.
Step 1:Press and hold the component key (TV, DVD, etc.) whose code you wish to retrieve. The illuminated ON/OFF key turns on.
Step 2:While holding the device key down, press and hold the INFO key. The illuminated ON/OFF key will turn off.
Step 3:After holding down both keys for 3 seconds, the illuminated ON/OFF key turns back on.
Step 4:Release both keys. The illuminated ON/OFF key remains lit.
Step 5:Starting with the number 1 key, press and release each number key on the keypad in the following order: 1 to 9, then 0. The number that causes the illuminated ON/OFF key to blink is the first number of the code.
Note:
TV codes begin with the number 1
VCR codes begin with the number 2
DVD codes begin with the number 3
Satellite receivers and cable boxes, codes begin with the number 5.
Step 6:Repeat step 5 until you have retrieved all 4 numbers in the code.
Step 7:After the fourth number is retrieved, the illuminated ON/OFF key blinks briefly, then turns off.
Note:To exit theCode RetrievalMode, press and release the "GO BACK" button at any time.
Electronics Equipment Repair Center RCA UNIVERSAL REMOTE 4 DIGIT CODE FOR...
Electronics Equipment Repair Center 3 DIGIT RCA UNIVERSAL REMOTE CODE FOR...
Electronics Equipment Repair Center RCA UNIVERSAL REMOTE CONTROL 3 DIGIT...
Jan 25, 2015 | RCA Televison & Video
How to program a rcr804bfdr to a sanyo tv
Programming the RCA RCR804BR or RCR804BFDR Series Remote Control
Programming with Direct Entry:
To program your remote to control up to four components, follow these steps:
  1. Manually turn on the component you wish to program the remote to operate.
  2. Find the four-digit code for your brand of TV, VCR, DVD, satellite receiver, cable box, or digital TV converter in the enclosed code lists.
  3. Press and hold the CODE SEARCH key until the indicator light turns on.
  4. Release the CODE SEARCH key.
  5. Press and release the TV, VCR or SAT·CBL·DTC key. The indicator light blinks and then remains lit. Note: DTC references digital TV converter. To program the DVD·AUX key: Press the DVD·AUX key. To control a DVD, press the VCR key. To control a TV, press the TV key. To control a satellite receiver, cable box, or digital TV converter, press the SAT·CBL·DTC key. The indicator light stops blinking and remains lit.
  6. Enter the four-digit code, using the numeric keypad. After the code is entered, the indicator light turns off. Note: If the indicator light blinks multiple times, you've entered an invalid code. Start from step 2 again.
  7. Aim the remote at the component and press the ON·OFF key. The component should turn off. Note: If your component does not respond, try all the codes for your brands. If the codes do not work or your brand is not listed, try the Code Search Method that follows.
Programming with Code Search:
If your TV, VCR, DVD, satellite receiver, cable box, or digital TV converter does not respond after you have tried all the codes for your brands, or if your brand is not listed, try searching for your code via the Code Search Entry Method. To program your remote via the Code Search Entry Method, follow these steps:
  2. Press and hold the CODE SEARCH key until the indicator light turns on.
  3. Release the CODE SEARCH key.
  4. Press and release the component key you wish the remote to control- TV, VCR or SAT·CBL·DTC key. The indicator light blinks once and remains lit. Important: Find the ENTER key on your remote (don't press it yet). You will need to press this key quickly in step 6 below. To program the DVD·AUX key: Press the DVD·AUX key, followed by the component key you wish the DVD·AUX key to control. For DVD, press the DVD·AUX key, followed by the VCR key. For an auxiliary component, press the DVD·AUX key, followed by the corresponding component key ( TV, VCR, SAT·CBL·DTC ).
  5. Press and release the ON·OFF key until the component turns off. Important: You may have to press the ON·OFF key up to 200 times.
  6. As soon as the component turns off, press the ENTER key within 4 sec- onds. The indicator light turns off. Note: If you wait longer than 4 seconds to press ENTER, the remote goes to the next code-you will need to start the code search from step 1 again.
Dec 24, 2014 | RCA Televison & Video
Step by step
What steps are you looking for? Also what is the problem? Also this may solve your issue
Copied from: voxrightnow
Programming the Remote:
Your universal remote can operate a variety of brands of components. In order for your universal remote to control your components, you need to program the remote with the codes that match the components (See Code List below). These codes enable the remote to communicate with your components. Each brand and each component has its own "language," and, by programming the correct codes into your remote, you tell the remote to "speak the same language" as your components.
There are two methods you can use to program your remote control to operate your components: Direct Code Entry and Manual Code Search and Entry. Most components can be programmed in one of these ways. Try them in the order listed.
In order to control combo TV/VCR or TV/DVD units, you must program both the TV key and the VCR•DVD key. Once programmed successfully, the TV key controls the TV functions on your unit, and the VCR•DVD key controls the VCR or DVD functions. There is a specific section in the Code List for combo units. The codes in this section should be tried first, using Direct Code Entry on the TV and VCR•DVD keys. If this is unsuccessful, follow the normal programming methods for both the TV and the VCR•DVD keys
Direct Code Entry:
To program your universal remote to control your components using the Direct Code Entry Method, follow the steps below.
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box).
2. Find the Code List below. Find the list for the component you wish to program. Find your component's brand. You will see a listing of four-digit codes for each brand. If your brand isn't listed, use the Manual Code Search method to program the remote control. (Refer to page 5 in the User Manual for Manual Code Search method, or scroll down in this Answer to the next section.)
3. Press and hold the component key (TV, VCR•DVD, SAT•CBL) you wish to program. The LED indicator light turns on and remains on. If you release the component key any time during the Direct Code Entry procedure, the LED indicator light blinks four times, and the process is exited.
4. While holding down the component key, consult the Code Lists for the four-digit code that corresponds to your component's brand and use the number keys (0-9) on the keypad to enter it. While you are pressing the numbers, the LED indicator light turns off.
5. After the fourth number is entered, the LED indicator light turns on. At this time, release the component key. If the LED indicator light turns off, you have entered a valid code and have followed the correct procedure
for Direct Code Entry. If you enter a code number that is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the LED indicator light blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 3 and try the next code listed. The last programmed code under that component key is retained. Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality.
Manual Code Search and Entry:
If your component's brand isn't listed in the Code Lists, or if you have tried all of the codes for your brand and the remote does not operate your component, try the Manual Code Search. This Code Search method cycles through all of the codes in the Code Lists in the event that your component's code is listed under another brand. The Manual Code Search method may take a long time because the remote searches through all of the codes in its memory for the code that operates your component. Therefore, if your brand is listed in the Code Lists, first try the Direct Code Entry method described on page 4 in the User's Manual also described above.
NOTE: To exit without saving any point in the Manual Code Search, press and release the GO BACK key.
Note: If you press an invalid key during the Manual Code Search, the remote does not respond and the LED indicator light does not blink. If you do not press a valid Manual Code Search key (TV, VCR•DVD, SAT•CBL, ON•OFF, GO BACK), the search times out after two minutes. When the search times out, the LED indicator light blinks four times and turns off. The last programmed code under that component key is retained.
2. If you are programming the remote to control your TV or satellite receiver, go directly to step 3. To program the remote to control a VCR or DVD follow the preprogramming method listed below.
Preprogramming the VCR/DVD Key
The VCR•DVD key can control only one component, either your VCR or your DVD. To program your remote to control either your DVD or your VCR, you must first put the remote in the proper programming mode. Follow these directions before proceeding to step 3.
a. Press and hold the VCR•DVD key. The LED indicator light turns on.
b. While holding down the VCR•DVD key, press and release the number 2 key on the keypad to control a VCR or the number 3 key to control a DVD. The LED indicator light turns off.
c. Release the VCR•DVD key. The LED indicator light blinks four times and then turns off. Your remote is now either in VCR or DVD Programming Mode, depending on which you chose. Proceed to step 3.
4. While holding the component key down, press and hold the ON•OFF key. The LED indicator light turns off.
5. After holding down both keys for three seconds, the LED indicator light turns back on.
6. Release both keys. The LED indicator light remains on. Throughout the programming of each key, be sure to keep the remote pointed at the
7. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component
turns off, you have found the correct code. (If it cycles through and the LED indicator light blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.) Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
8. Once you have found the correct code, you must save the new
code by pressing and releasing the STOP key. The LED indicator
light turns off. You must press the STOP key to save the code or the correct code will not be stored!
9. Once you press the STOP key, the code is stored.
Testing the Code for Maximum Functionality:
1. Once the code has been stored (see Manual Code Search and Entry Method above), use the remote to attempt to control a variety of the component's functions. If the code that has been stored controls the majority of the component's functions, programming is complete. If the
code stored does not give maximum functionality, you will want to try another code.
2. In that case, repeat the Manual Code Search and Entry Method from step 1. When the component turns off for the first time, do not press the STOP key, which would store the code. Instead, with the unit now off, continue to press the ON•OFF key repeatedly until the unit turns back on. Once the unit turns back on, you have found another code that operates the component. Press the STOP key.
3. Test the functionality again by attempting to control a variety of the component's functions. If the code that has been stored controls the majority of the component's functions, programming is complete. If the code stored does not give maximum functionality, you will want to try another code.
4. Repeat the Manual Code Search and Entry Method from step 1. Each time a code turns the component on or off, you have found a code that operates the remote and needs to be tested for maximum functionality. Continue through the code lists, cycling through the codes you have already tried, until you find one that offers maximum functionality.
Nov 10, 2012 | RCA RCR350 Remote Control
How to program emerson jumbo universal remote to jvc tv model dvd component
Click here to download the user manual to Jumbo remote controls. it will have all details.
The common proceedings are:
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jun 21, 2012 | Televison & Video
How do I program my no name universal remote without a setup key?
Do a code search method.
Apr 22, 2012 | Televison & Video
UR 2 Universal controller - don't work!
Direct Code Entry
    Code Search Method
Mar 22, 2012 | Televison & Video
I need a code for RCA remote RCR311STR for a Durabrand television model BH2004D.
In order for the 4 component universal remote to control your TV, you must program it with the TV code that matches your TV. These instructions explain the preferred method of programming the remote-the Direct Entry method.
  1. Manually turn on the TV.
  2. Locate the enclosed TV Code List. Find your brand of TV.
  3. Press and hold the CODE SEARCH key until the indicator light illuminates. Then release the CODE SEARCH key.
  4. Press and release the TV key. The indicator light blinks and then remains lit.
  5. Use the number keys to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3.
  6. Aim the remote at your TV and press the ON•OFF key. If your TV turns off, you have found the correct code.
  7. Write the code down for future reference.
  8. If your TV doesn't turn off, repeat steps 3-6 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote.
Program for VCR: In order for the 4 component universal remote to control your VCR, you must program it with the code that matches your VCR. These instructions explain the preferred method of programming the remote-the Direct Entry method.
  1. Manually turn on the VCR.
  2. Locate the enclosed VCR Code List. Find your brand in the VCR Codes.
  4. Press and release the VCR key. The indicator light blinks and then remains lit.
  5. Use the number keys on the remote to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3.
  6. Aim the remote at your VCR. Press the ON•OFF key. If your VCR turns off, you have found the correct code.
  8. If your VCR does not turn off, repeat steps 3-6 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote.
May 11, 2011 | RCA RCR311B Remote Control
How do I program my remote to my tv without the booklet
Hello
You can do it by code search method.
Try doing a search of the code library for your code by following these steps.
OK.
May 05, 2011 | RCA RCR311B Remote Control
I need a code for a rca and a coby remote controle
Sanyo. 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180
2. Press and hold the component key (TV, VCR·DVD, SAT·CBL) you
is exited.
3. While holding down the component key, enter the four-digit code that corresponds to your component’s brand. While you are pressing the numbers, the LED indicator light turns off.
5. After the fourth number is entered, the LED indicator light turns on. At this time, release the component key.If the LED indicator light turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry. If you enter a code number that
is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the LED indicator light blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 2 and try the next code listed.
Dec 01, 2009 | RCA Universal Remote Control
Enter codes for remote R55L8-RCR4358
There are 4 ways to program your remote:
-Brand Code search and entry
-Direct code entry
-Manual Code search and entry
-Auto Code search and entry
*ON TV/VCR(DVD) combos you must program each button individually and that button(ie. TV or VCR/DVD) will program that part of your device.
*the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
1.hold down the DVD-VCR button-->the red led will stay lit.
2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
4.The DVD-VCR button is now set to VCR mode-->program for VCR
BRAND CODE SEARCH ENTRY:
1. turn on device
2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
3. hold down the component button--> led should stay on
4. while holding component button, also hold power button--> the led will turn off, then after 3 seconds it will turn back on.
5. release both buttons--> led will stay on
6. enter brand code--> led blinks once
7. press power button repeatedly until component turns off-->each time you press the power key the remote sends a different code for that brand. led blinks once
8. if power on your device turns off press the stop button to save configuration-> led turns off
9. if the led blinks 4 times and turns off, you have reached the end of the codes for that brand, try using a different method to program your device.
DIRECT CODE ENTRY:
1. turn on the device
2. locate your device codes
3. hold component key down-->led lights up and stays lit
4. enter code while holding components key--> as first key is pressed the led turn off, then as 4th digit of key is pressed the led turns back on
5. release component key-->led turns off, try using your remote, if it doesn't have all of the functions you need, try a different code
6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
MANUAL SEARCH AND ENTRY:
1. turn on device
2. hold the component button--> led lights up and stays lit
3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
4. release both buttons--> led stays lit
5. push the power button a bunch of times until the device shuts off-> each time the power button is pressed a different code is sent to the device, the led blinks each time.
6. if the device turns off press the stop button to save your config.
7. if the led blinks 4 times you have reached the end of the code list, there are hundreds of codes, you may be pressing the power button for a while...
AUTO CODE SEARCH AND ENTRY:
1. repeat steps 1-4 of "manual search and entry"
2. press the "play" button--> led blinks 10 times, sending a code each time
3. continue pressing the play button until the device turns off
4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
5. if the led blinks 4 times you have run out of codes, try a different method.
Now if someone would please post the codes, or if someone knows the code for a durabrand DVD-1002...
Apr 09, 2008 | Televison & Video
Televison & Video Logo
52 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
