Question about Samsung DLP HL-P5663W 56" TV
White strobing lights showing on screen
After 1 hr of tv being on a flashing white lights start to appear on screen.almost like a flickering whitenlight. changed light bulb adn still happening. starting to see color going to red and green. could this be my color wheel going or is it a ballast problem. shut down tv and everthing ok until tv runs for a few min. no indicator led lights on or flashing.
  • 1 more comment
  • gdm27 Feb 03, 2009
    have not replaced anything but the lght
  • gdm27 Feb 04, 2009
    im getting a great picture starting up and after i shut it down strobing goes away. could it still be my color wheel causing the white strobing effect on screen or something else
  • Kevin Wertz
    Kevin Wertz Mar 19, 2012
    gdm27 I am having the same problem with my Samsung DLP HLN-467W. Can you let me know what the resolution was?
    Guru:
  • 829 Answers
One of two things, if you have a lot of use on the set or if it's on every day for a long period of time you probably have a worn out picture tube. If this is the case it would far exceed the price of a new set to repair, if a picture tube could even be found for it.
The other thing could be open transistors on the CRT circuit board. Based on it's age, it's probably not worth repairing unless it's a very large set 32" or 36" .
Posted on Feb 04, 2009
    Master:
  • 848 Answers
Hi
Color wheel need to be replaced . It is very expensive repair .
    Sergeant:
  • 326 Answers
Yes its the colour wheel problem.and needs to be replaced to make it proper.
    Genius:
  • 1,269 Answers
Did you recently change some internal components like resistor and the STK chips?
Posted on Feb 03, 2009
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
My coby flatscreen comes on and works but strobes flashing light but works good just with strobing light ! whats going on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz,...
Vizio screen flashing
ok when mine did that i shut it off then on then off then on again four times then unpluged it and plugged it back in and waited for a few minutes and it was fine if that don't work then its most likely an internal problem and it would have to be fixed by a professional
Feb 05, 2014 | Televison & Video
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | ViewSonic N1930W 19 in. LCD TV
My lcd digital lifestyle tv is blinking like a strobe light.
Your back-lighting is failing. This is part of the LCD panel and can not be repaired without replacing it. Due to the cost of the panel, best advise would be to replace the TV. Sorry for the bad news... you should check into your warranty status.
Jun 28, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
FLICKERING BACK LIGHT
Sounds like you have an LCD tv with backlight problems. Check power board for domed capacitors and replace them. next check connections on the inverter boards. they are on the sides or just one side. Becareful there is high voltage output from these boards. If the cable from inverter board is not good to the screen you can get a strobing. the inverter boards may need replaced. or cales to screen may be bad. The panel also could be bad.
Mar 25, 2010 | Televison & Video
Philips Magnavox 42 inch plasma white strobe-like blinking
magnovox 42 inch pasma shows tv guide but does not show pciture.
Sep 23, 2009 | Televison & Video
Horizontal flashing color stripes.1/2 second intervals on pic
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 07, 2017 | LG 42PG20 42 in. Plasma HDTV
Flickering screen (likea strobe light)
one check your refresh rate in windows boot the pc into safe mode if flickering is gone then lower your refresh rate if not replace lcd inverter board.
May 16, 2009 | Gateway XHD3000 LCD TV
Headlights flicker almost like strobe lights
Take it to a dealer. You may even get him to laugh and show you how to turn it off.
Dec 25, 2008 | 1997 Chevrolet Suburban
Samsung DLP HL-P5663W 56" TV Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
