Question about Janome MyLock 634D Mechanical Sewing Machine
Janome 634d not working
It was working just fine then the right needle broke. I replaced the needle, now it will not work. When you manually go to turn the knob on the side and not use the foot, it will not turn. it locks up. When you open up the front area to take a look there is a pin on the right that moves up and down for the upper looper thread. Well it looks like to me it is no longer moving up and down properly and that is the reason the knob on the side is not turning all the way. Does anyone know if this is something I can adjust myself or do I need to take it in?
Check the needle plate. I had this problem with mine and it turned out that the needle plate had cracked.
Posted on Feb 03, 2009
For rolled hemming how do I move the needle plate setting knob from S to R
If you dont have a manual then this page will allow to to download it for free. Pretty straightforward and easy to read
http://janome.com/siteassets/support/manuals/sergers/inst-book-634d.pdf
Feb 07, 2015 | Janome MyLock 634D Mechanical Sewing...
Why does the right needle keep breaking in myloc 634d
I agree with John Smeed It could be that the needle is bent or in the wrong way if it keeps on breaking it must be hitting the throat plate or it's timing may be out( a pro job) Also check the needle is in as high as it can go.
Apr 19, 2014 | Janome MyLock 634D Mechanical Sewing...
Neddles to suit janome mylock 134.
The needles required will be listed in your manual, if you don't have a manual then buy any needles recommended for sergers/overlockers. Or check on the Janome website.
Nov 23, 2013 | Janome MyLock 634D Mechanical Sewing...
Tension to loose and missing stitches
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
use a scrap piece of fabric to sew on as you adjust the tension
when the tension is to loose adjust one number higher till stitch
looks good
here's 2 links for a manual one is a hardcopy & the other is a
pdf downloadable--one is a different price from the other
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d.aspx
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d-download.aspx
Sep 08, 2012 | Janome MyLock 634D Mechanical Sewing...
New Home My Lock 134D Serger. The right needles keeps breaking. Yesterday I realize it is hitting the pressure foot. I have changed out the needle (size 14) about 7 or 8 times now. I have adjusted the...
check to see if the presser foot is loose
check to see if the needle is in backwards
if the presser foot is tight & needle is not in backwards then it could be a timming problem, since you said the needle is hitting the presser foot
please rate this with the thumbs in upper right hand corner
Aug 08, 2010 | Janome MyLock 634D Mechanical Sewing...
Replacement needle
Average size is number 14 flat sided
Oct 17, 2009 | Janome MyLock 634D Mechanical Sewing...
Janome left needle thread breaking CONSTANTLY
Sounds like a tension problem. Your machine should have two tension adjusters. One for each needle. The book that came with your machine will tell you how. Another possibility is a bent needle.
Feb 27, 2009 | Janome MyLock 634D Mechanical Sewing...
Janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Feb 25, 2009 | Janome MyLock 634D Mechanical Sewing...
Janome MyLock 634D Mechanical Sewing Machine Logo
173 people viewed this question
Top Janome Sewing Machines Experts
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
