Question about Samsung LN-T3253H 32 in. LCD Television
Color issues Periodically our TV will have a purple grainy hue. Actors faces will have purple/green on them. We thought it might be the cable in our area, but it still does it when we are playing DVD's. We can't seem to get the problem taken care of.
  • 98 Answers
Need to check the T-con board & main board.
Normally possibility of T-con problem is 70%
Posted on Feb 08, 2009
Purple hue and no sound
Ur tv Tuner board,that the board where the incomming brocast signal cable connect to it.That the Tuner board,it defective.Replaced the Tuner board ur tv will functions normal again.
May 27, 2010 | Vizio SV470XVT 47 in. LCD TV
MY SONTY WEGA TRINITRON HAS A PURPLE HUE AT THE TOP OF THE SCREEN. ALSO THE CHANNEL DISPLAY WHICH IS NORMALLY GREEN ON COLOR IS NOW A RED COLOR
This kind of problem occurs if tv screen got hit by some thing that damage internally and its irreparable, second possible cause is magnetic field nearby screen, please check any speaker or some thing that has magnet inside around tv, remove it from tv to fix purple hue at top of screen.
Unplug tv from AC wall socket for 20-25 minutes, replug back in and turn it On, this will demagnetize screen to cure the problem.
Apr 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Pioneer Elite Plasma TV 2-yrs old loses color randomly.
Would need model number to search properly. On some sets a capacitor "C2601" of Y-Drive assembly contacts the audio bracket and it is damaged, can cause a abnormal picture.
Sep 08, 2009 | Pioneer PDP-5070HD 50 in. Plasma...
Intermitant color bursts of red, green, purple
Kevin,
for the color problem,most likely you do have problem with loose contact of components from C-board ( small board connected at the back of CRT "picture tube" which drives every color and size of the screen)if you have knowledge with soldering electronic component parts, resolder this board and also check main board for possible loose contact.
cheers,
mark
Feb 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Akai LCT2701TD
Unplug your TV for a while and see fi you are getting the same issues after you plug it in. If it works after, then you have an overheating issue with the power supply or main board.
Let me know if you need further assistance.
Oct 30, 2008 | Akai LCT2701TD Television
Red tint is gone
It sounds like the red cable on your component input is bad, one way to check this is press menu and see if the menu bars and letters are the right color. if they are then you may have a cable issue, if they are bad you may have a bad DG board in the unit. This will probably require a service technician. Hope this helps
Apr 03, 2008 | Panasonic TC-32LX20 32 in. HD-Ready LCD...
Screen color is purple
if you have access to another monitor use if to verify the monitor is the problem and not the video card of the computer.
does the monitor allow you to adjust color and tint(hue) because the tint or hue control changes the overall color from green to purple. or the color control circuit has failed leaving you stuc with a purple screen.
Dec 26, 2007 | Dell E176FP 17" LCD Monitor
Samsung TXN3275HF 32" tv - purple picture
Chuck the TV - probably It depends on the repair facilities available where you live. In big urban areas the cost of staffing a repair shop is such it can cost nearly as much per hour just to look at an item is it does to buy the next one-plus you get all the latest features.
May 21, 2007 | Samsung TXN3275HF 32" TV
W3000
It's repairable, sounds like the main board, but try some other cables and sources to see if the same thing happens
Oct 29, 2006 | Dell W3000 30 in. HD-Ready LCD Television
Samsung LN-T3253H 32 in. LCD Television Logo
203 people viewed this question
Henry  Thomas
Henry Thomas
