Question about RCA D52W19 52" Rear Projection Television
Capacitors what kind of capacitors do i need to look for? radiosahck deosnt seem to have them. i can find the 2 35v ones but cant seem to find the 2200 16v. we already have the old ones off and it was the cp150 that is bubbled on top. its crazy these parts are sooo cheap but i cant find what i need and when i do they ask , are they radial,flux,electrolytic. i havent a clue.
  • tonyandangie Feb 06, 2009
    Thank you so much for helping.... I finally found some at allelectronics.com.they have everything and they are pretty cheap. the smaller ones(220uf 35v) were 25 cents each and the 2200uf 16v was 60 cents. i bought extras...just in case
  • RCA Master
  • 5,138 Answers
Acme Parts 1-800-575-9833
Posted on Feb 07, 2009
  • RCA Master
  • 8,617 Answers
They are radial electrolytic capacitors the 2200uf 16v can have a higher voltage but the 2200uf has to be exact, Basically a 2200uf 25v or 2200uf 35V will work without any problems. You can get replacements caps under the RCA parts category at the following link. They have a minimum order amount of 10.00 to qualify for free shipping.
http://servicemanuals.vstore.ca/
Posted on Feb 05, 2009
The ps2 deosnt seem to read the cd and comes up with message cant read and the screen shows browser configuration set up
Greetings,
Most likely, the problem is that your Cd is either too scratched or dirty. If its dirty, gently dab with rubbing alcohol and rub off with a kleenix or soft towel. If the Cd is scratched use a machine such as this to fix it.
Thank you for using FixYa! =) If I helped, please give me a rating.
Dec 10, 2010 | Sony PlayStation 2 (PS2) Console
It seems my Sunfire True Sub sig needs repair, but how to do it?
Capacitors either fail spectacularly or in a very subtle way. Every once in a while, they'll explode, in which case it's very easy to spot the one that needs to be replaced, but generally they fail internally, with no visible problems.
(very old units used a wet electrolyte, and the capacitors simply dried out inside)
If you are able to determine which cap is bad, you will definitely need soldering skills to replace it - no way around that.
Soldering isn't difficult to learn, but I can't help you over the internet. :) If there's a craigslist in your area, you might try posting to the "Wanted" section to see if someone can teach you how.
Best of luck to y
Jan 11, 2010 | Sunfire True Sub Signature Subwoofer
I did the capacitor fix to my FLM-3734B but now
Check that everything is pluged in and only use 105 degree c caps 85 degree ones will not last long. New caps can be bad with todays parts i see lots of new ones that are bad. I would replace ALL caps on a power supply board the heat kills them so they may need replacing every year or more if the set is on a good part of the day. The power supply is on to some extent all the time a set is plugged in. Watch the + and - on the caps put it in wrong and you may blow out other parts and for sure the new cap.
Nov 01, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
When i connect my gogear philips mp3 player to pc,it deosnt show?
1. When u connect ur mp3 to pc, try option for hidden folders. Enable show hidden folder option from the Tools --> Folder option --> show hidden folders.
2.If u want to delete the only folder, then open My computer. It will show drive with ur mp3 name, format that drive
Sep 10, 2009 | Apple iPod nano
I put music on my ipod shuffle and when i wanted to hear my music i cant hear nothing
ther is many things to be checked
1 check ur headphone or use another headphone and check whether it is working or not.
2 if step1 doesnt work then reset ur ipod through internet and checkout .
3 if the 2step deosnt work then there might be problem in the ipod take it to the nearest apple care centre and get the problem solved. u get one year warranty for ur product
Sep 05, 2009 | Apple iPod shuffle MP3 Player
No disk drive???
Check HDD in the bios.
Restart Laptop and keep ressing F2. In the bios screen you will see HDD or Primary IDE and value next to that representing it's size. If that is not detected in the bios you need to replace HDD
Jun 11, 2009 | Acer Aspire 5050-3242 Notebook
Tailgate wont open, micro switch sounds like its working, emergency open deosnt work either
there was a problem with these where the boot latch mechanism breaks internally so although the elctrics work the tailgate wont open result tailgate needs broken into best to speak to your local landrover dealer or specialist
Apr 29, 2009 | Land Rover Discovery Cars & Trucks
Cant find capacitor 302
there is a cluster of them, one is on the top edge. There are 5 that are the same size and rating 100MF.
Mar 16, 2009 | Akai LCT4216 42 in. LCD Television
RCA D52W19 52" Rear Projection Television Logo
173 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
