I think some duct work came off. How do I get to it?
Verrrrry carefully. You can start by removing the glove box to look underneath the panel and see what is happening. It is unlikely that something came loose, instead it is likely that you have a leaky or unhooked vacuum hose that operates the dampers to make the air come out the top or bottom vents. The hoses are about a 1/4 in. diameter and fit on nipples attached to the dampers.
Good luck.
NO HEAT ON FLOOR VENTS
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These
will help.
Thanks.
As
These will help.
Thanks.
