I have just been printing a few photos and they turned out great. Next one has a slight tinge of pink to it. They are all new colours!
This often happens to me when I am printing. Please help. I am almost going to give up printing my own photos.
Sherree
What camera are you using? Or is this a printer isue? because then this one is in the wrong category. If you are printing from a computer it would be great to know if all pictures are great on the screen.
follow this steps and fix it. God bless youVersion:1.0
StartHTML:0000000168
EndHTML:0000003236
StartFragment:0000000502
EndFragment:0000003219
1.
The batteries may need replacement. Somedigital
cameras continue
to function when their battery power is low, but produce grainy
photos with incorrect coloration. Make sure you aren't using Ni-Cd
rechargeable batteries, which are generally not recommended for
cameras. 2. For the best picture quality, make sure the
camera is set to its highest resolution. This may have been adjusted
by accident. The process for doing this varies greatly among
different digital cameras. Keep in mind that fewer photos will fit in
the camera's memory and it will probably take longer to transfer them
to the computer, at a higher resolution. 3.
Digital photography tends
to be more prone to blurring (caused by slight movement of the camera
while the photo is taken) than 35mm film, especially with very small
or lightweight digital cameras. To remedy this, try using a tripod
and/or the camera's timer, if it has one. Adjust the camera's shutter
speed if possible. 4. If colors are too pale, using an image
editing/viewing program (such as PictureWorks MediaCenter) to
increase the Saturation level may be helpful. If the camera has
produced colors which are entirely wrong (everything is in shades of
black and purple, for example), you can turn the saturation all the
way down so that it becomes a black & white photo. 5.
The lens may need cleaning. Make sure you use a cleaning material
which will not scratch the lens. If possible, refer to its manual for
specific cleaning instructions
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts. Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks Richard Scott Technical Support New Zealand
What you see on the screen is quite often not what prints. Sometimes the screen will not show a slight color anomoly. If your pictures were taken with a digital camera, this is quite common. Try the photo enhancement software that came with your camera, or alternately, your printer. They all supply the software because of color corrections that are at times necessary. Sometimes always. Hope that helps. Try the "Auto Correct" function that most photo correction software has. That should help!
Canon has a number of things you can check in their knowledgebase. Go here. Type "pink tint" in the search box and click Search. If you select the first item "tinted printing" you will get at least 21 things you can try (only 10 show up per screen).
You have to take the machine to service partner who can be found on the brother homepage of your country.(www.brother.com) The scanner needs calibration which can only be done by service personel.
Browns printing pink suggest the blue/yellow jets are clogged or not functioning.
If the uses head in cartridge type[that is with a sheet of contacts on the front of the cartridge- then take then out ,damp a tissue in some warm water an place on a plate or similar - then stand the cartriges in the damp tissue until the tissue turns colour - then replace the cartrdge.
If it is head in the printer
Then take a look here
www,fixyourownprinter.com
