Question about Mitsubishi HS-HD1100U DVHS VCR
The video is B&W-AUDIO ok
No manual (used uint)-can't find an external tracking switch
  • 4,234 Answers
This is not a tracking issue. There are capacitors on the head/drum assembly that are failing. This prevents the motor servo from keeping the heads spinning at the correct speed. This will show up as a loss of color. There should be 3 caps on the head/drum assembly that should be replcaed. Please note that they may be surface mounted caps which are more difficult to replace if you have not done it before.
Dan
Posted on Feb 06, 2009
Vinpower Digital Vinpower Digital Burner- manual
Please explain what this term means: "copying audio tracks from computer memory". In normal operating you don't copy audio tracks you burn them to the disk using a compatible burning software.
May 15, 2014 | Vinpower Digital Computers & Internet
Need a repair manual
Fixya has no repair manuals unless they are found doing a google search. Sorry but can't help with this.
Jul 16, 2012 | M-Audio Fast Track Pro External Sound...
IS THERE ANY WAY I COULD FIT AN EXTERNAL MIC TO MY D340E
No, the D340 does not have any provision for an external microphone. However, you can use a separate recorder and combine the audio and video tracks using video-editing software on a computer.
Apr 09, 2012 | JVC GR-D340 Mini DV Digital Camcorder
No video output on my supra lcd 42, audio is ok
Hi
Its input-output selector switching IC is faulty. this IC, an electronic switching device, that switches the internal and external audio vidw in-out and is controlled be main system control IC. When we select the function to internal or external, the signals goes through this IC according to the control pulsed generated by the main system control IC, with our command. In your set, the video section of this switching IC is OK, but audio switching section has damaged. It wont switches the video to out, but alright in case of internal video switching. So you can see picture either with AV of by air transmissions, but there will be no audio with AV.
Replace the IC is the only remedy to rectify this problem. It is really a skilled work, and you must have through knoledge in digital electroncis to do this work. It is besf for you to get it repaired by any experienced service technician. The IC won't cost more; and can be bought from most of the electonic sparepart shops at your town. OK.
Jul 15, 2011 | Televison & Video
How do I switch off the audio on the Panasonic NV-GS250 so I can record video footage with no sound.
I think this camera has manual audio control.
Use the menu system and set the audio to manual then turn down the audio completely.
Another option is to place a microphone jack into the external mic socket without a mic attached. This will mute the onboard mic.
Al
Feb 11, 2011 | Panasonic NV-GS250 Mini DV Digital...
No sound when I play back using an external micropohone however when I play back on the TV full sound. Any solution?
Microphones are input devices; they don't double as speakers. If you mean that a stand-alone set of speakers do not work, but the internal speakers of the tv do let you hear the audio track from the camera. Then I have a couple of different suggestions: 1) make sure the stand-alone speakers work with other input sources, 2) try a different cable (make sure it is connected properly).
Also how are you connecting to the different devices? The video camera has an HDMI port which will send audio and video to the TV on one cable. If you are using the RCA audio in both cases, then I suspect a problem with the external speakers.
If you mean that the audio track is clear on play-back when you use the built-in microphone during the recording and not heard if the external microphone, check the external mic for problems. Try it on another recording device. I can't rule out a jack failure without more information.
I hope this helps.
Jun 03, 2010 | JVC Everio GZ-HD7 Camcorder
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Oct 11, 2008 | HP Pavilion dv1000 Notebook
Problem finding tracks
Try bunring a cd at the slowest possible speed and see if it helps. Also I would try a different burning software than what you are using now. (Even if it is iTunes or Media Player and if your already using these try roxio or nero instead).
Dec 26, 2007 | American Audio DCD-PRO310
Mitsubishi HS-HD1100U DVHS VCR Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
