Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My tv want power on what do i need to do
What can i do to get it to work
  • Sonny Berry
    Sonny Berry May 11, 2010
    Does the power indicator flash three times then go out when you press power?
  • RCA Master
  • 5,138 Answers
CK capacitors cp150,cp114,cp120 If cp150 is puffed up on top replace all 3 capaciors Values of caps 2200uf and Two 220uf 35v
Posted on Feb 09, 2009
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
Can not turn on TV since power outage yesterday.
You may have to ensure that the power outlet is ok. Try the TV on another power outlet. If it does not work, the TV might need servicing.
Aug 25, 2012 | Vizio M221NV 22-Inch Full HD 1080P LED LCD...
Hello my 47LD450C TV does not work right and the light does not turn red. I check the plug and cable tv with another TV all works except on my new TV 47LD450C. Need help please :)
Tries tv unplug,replug it back like an hour later.Tv now,should be resetting itself back to the factory.See,if tv will,work.Not,than the tv have power LED light indication flashes or totally dead and nothing on?Yes,than the tv power supply board is the causes and the problems.That the board,where the power a/c corb plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Televison & Video
Only the power on works . The rest of the remote controls and manual controls including volume no longer work
First, unplug the TV from the outlet, wait a few seconds and reconnect the power, try the power and the rest of the TV functions, it could be that you need a new remote, if the TV keys(located on the TV itself) do not operate still , then you will need the TV checked out by a qualified tech, in this cases the key,microprocessor or the power supply boards could be at fault, not all of them, but one of the three.
Mar 10, 2010 | Televison & Video
Pops power supply fuse when I plug it in
Check to fuse box to see if the fuse is working properly. Next, see if the TV "pops" the power supply when pluged into a different outlet in a different power supply area. If the TV works without poping the fuse, the fuse with the original outlet needs replacing. If both outlets "pop", either the electrical system needs checking. Or if this is a new problem that started when you first tried the TV, the TV could be wanting more power than the electrical system will allow. Check the power requiremnets in the TV manual.
Jul 28, 2009 | Recoton Advent Advent TS2066A TV
Zenith remote will not work tv, need code
hello here is how you get your remote to work...make sure tv is on
step 1.hold down code search button till you see the red light
step2. let go of code search button and hit TV once light should blink
step3. press and release the power button while pointong a TV u ((may have to press the power button several times)) once the Tv powers off press the enter button once
step4. press tv button and hit power
May 16, 2009 | Zenith DBZN-311 Remote Control
RCA 32 in TV no picture no sound just a beeping noise TV power is on
the tv has one part of the power supply working this is needed to have the microcontroller ready to work. But the tv needs more than that for work im talking 'bout the high voltage power supply who is now damaged. the parts required depends on the diagnosis in the bench but at least two are needed. the cost of this repair of course depends in how many parts are going to be replaced, but i concider this repair kind of average in this technology.
Apr 13, 2009 | RCA 32V524T TV
Tv wont turn on, i got it last april, it worked eversince,
First off, try a power drain:
Unplug the TV's power cable so it is not grounded to the house.  Then press and hold the TV's own power button in for a minute.  Plug the TV back in and see if it works. If it sill won't work, are there any visible LED lights you can see in the back of the TV?  You need to determine if the TV's power supply is shot or the TV's mainboard.  Service would likely be required if the TV still won't turn on.
Mar 24, 2009 | Sylvania LD-320SS8 32 in. LCD TV/DVD Combo
Hughes box wont power on.
Sorry it took so long to reply to your request for help.This Direct TV box has had a component failure. You will need to call Direct TV and have them replace the box. You can call Direct TV Customer Support at this telephone number 1-888-667-7463. Tell them that you are having a problem with Direct TV box and need a replacement. I hope this information help you solve your problem with the Direct TV box failure. Thank you for using FixYa and have a nice day!
Oct 21, 2008 | RCA DIRECTV Satellite Remote Control
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
