Question about Fuji FinePix S2 Pro Digital Camera
Best setting for indoor
Please help me out. I am new to the digital world. Looking to use stobe with the S2...is a custom setting the way to go or friends are telling me daylight. Please advise.
  • 24 Answers
There are three possible solutions for you:
1. Just use the Daylight (direct sun) white balance setting. Electronic flash is typically close to the direct sunlight setting for white balance. Advantages: it is simple. Disadvantages: if you are balancing electronic flash with ambient light, you are likely to have an odd mixture of lighting, with the ambient lighting tending toward red (if incandescent) or green (if flourescent).
2. Get a Wratten 85 color correction gel that you can cover your flash's head with, and use the Tungsten white balance setting. This will bring your flash output into line with existing incandescent light sources. Advantages: almost as simple as (1), and allows you to come close to matching a common indoor lighting situation. This will produce more natural-looking environmental shots if you balance the flash and incandescent ambient light contributions to the exposure. Disadvantages: large gel filters get expensive. You may be able to obtain something close to the Wratten 85 color correction filter from a theater supply house more cheaply. Roscolux #3408 is slightly weaker and #3411 is slightly stronger than the Wratten 85. If you have to balance flash with flourescent light sources, try a Roscolux in the cyan series leading to #4360. Some experimentation is likely to be required. The place I looked online offered the Roscolux in 20x24" sheets for about $7 per sheet, a bargain compared to the optical-grade Wratten filters.
3. Set a custom white balance. This is not too difficult, and it will definitely provide the best approximation to your desired white balance that you will obtain in the field. Advantages: this will allow you to reproduce white accurately even with mixed lighting sources. Combine with gel over flash of (2) for the very best approach to balanced flash/incandescent lighting situations. Disadvantages: requires a "white" target (can be a neutral gray photo card, for example) and some additional time before a photo session.
You can obtain some striking effects by purposely mixing color temperature light sources. But day in and day out, getting a balanced shot is a skill that it pays to cultivate.
Posted on Apr 07, 2009
Bought a generic clip watch from walmart with no manufacture's name on it. The back says MSP74582W batery CR1616 and then A126. Looking to find instructions on how to set alarm, date, and figure out...
Just got one, and haven't lost the instructions yet. First, the 4 buttons are:
S1 - at 4 - Lap/Rst
S2 - at 2 - St/Stp
S3 - at 8 - Mode
Light - at 10
Watch Control
Normal Display: Hour, Minute, Second
Push S1: Alarm time in Hours and Minutes
Push S2: Month, Date
S3: Change function
Alarm and Chime
In Normal Time Hold S1 and the alarm time will be displayed.
Press S2 once and Hourly chime will be on.
Press S2 twice and Alarm will be on.
Press S2 three times and Chime will be off.
Press S2 four times and Alarm will be off.
Press S1 and display will change to normal time immediately.
Setting Alarm Time
In normal time, hold S3 for about 3 seconds, the hour digit will flash and is advanced by pressing the S1 button. Then push the S2 button to change to minutes and change those by pressing the S1 button as above. Push S3 to return to normal time.
To silence the alarm, press S1.
May 15, 2011 | Watches
How to reset to factory settings , my fuji finepix s2 pro. the auto-focus function is not working. Camera can only be focused in the man mode. can you help?
Please try to download the manual in this website it can help you on how to reset the setting of your FUJI Fine Fix S2 PRO
http://downloads.fotosource.com/public/camera_manuals/Fuji/DigitalCameras/FinePixS2Pro.pdf
Thanks
May 09, 2011 | Fuji FinePix S2 Pro Digital Camera
When taking pictures outside the camera over exposes. Could i have pressed a button that would cause this to happen? when taking pictures indoors the camera takes awsome photos still, but when we go...
Sounds like you set either the aperture to a large small number (large aperture) or the shutter speed to a long value. If this is the case, it should be that in AUTO mode, things work fine, but one of C, M, Av or Tv (custom, manual, aperture priority, shutter priority) modes, the aperture or time are set to something that is good for indoors, but outdoors (where the light is brighter) too much light comes in.
It could also be that the ISO ("film" speed) is set too high for bright light. Again, in AUTO mode, the camera takes care of this setting.
Try each of the shooting modes and see which ones work. If Av is the one that is over-exposed, try making the aperture smaller. If Tv, make the shutter time shorter. If M, make both Aperture smaller and shutter time shorter.
Mar 02, 2011 | Canon PowerShot S2 IS Digital Camera
I am looking for the book that tell me how to work it
You can download it free from:
http://www.retrevo.com/support/Canon-S2-IS-Digital-Cameras-manual/id/200dj083/t/2/
Best of luck.
Jan 10, 2011 | Canon PowerShot S2 IS Digital Camera
What are the optimal settings for my digital camera? I have a brand new Canon PowerShot 12.1-Megapixel Digital ELPH camera, but I've been really disappointed in the quality of pictures it takes. For...
Small white circles usually means dust on the lens.  Remove the dust with a blowerbrush - not a tissue.
You are asking for a "1 size fits all" solution for your settings, and indoor and outdoor use really means different settings.  What you should be looking for is the "White Balance" setting - on Auto it will be about right, most of the time.  You should be able to switch between indoor/outdoor settings (but they may be called portrait and landscape, or similar) and you will have to look through the menus for this.
Mar 02, 2010 | Canon PowerShot 12.1-Megapixel Digital...
Canon S2 IS problem blank viewfinder and LCD
some cameras have the choice to take the picture by looking through the veiwfinder or on the LCD screen. check in the menu and set it to LCD if you want to use the LCD
Mar 21, 2009 | Canon PowerShot S2 IS Digital Camera
E 18 problem
I dont know what error E18 means, check cannon support for that, but welcome to the world of DISPOSABLE CAMERAS, I have replaced 3 cameras in 3 years, 2 because of lens and shutter issuses.
Jan 26, 2009 | Canon PowerShot S2 IS Digital Camera
Canon S2 is washed out pictures
Just when I thought my camera was fixed I started experiencing the same problem with my S2 IS. Don't know if it is any help to finding the solution but the camera works fine outdoors when used in video mode.
Aug 15, 2008 | Canon PowerShot S2 IS Digital Camera
Too much light in pictures
chack the white ballance and the EV +/- setting if possible set white balance to auto and EV to 0 (zero) or adjust the iso setting
Apr 21, 2008 | Canon PowerShot S2 IS Digital Camera
Dakota atomic wrist watch sold by National geographic
s1 is the top button and s2 is the bottem button
Feb 20, 2008 | Dakota 2786-6 Wristwatch
Fuji FinePix S2 Pro Digital Camera Logo
146 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
