Question about HP Computers & Internet
Cant connect to internet
Machine is reading a router when none exist
  • 596 Answers
Go into your network connections, delete the 'ghost' router and restart your pc. This should take care of the issue. By the way, do you have a wireless adaptor installed? If you do and it's on, it may be reading all routers that are broadcasting nearby. Good Luck.
Posted on Feb 03, 2009
My router suddenly set a password i didnt set..i cant connect on my internet connection
Hi angelique624,
You can reset your router settings by pressing the reset button behind the router.
CAUTION: All your existing settings that allow you to access internet will be erased.
If you don't know the setting ask your Internet Service Provider to provide you with the same.
Hope this information was helpful.
Thank you for using fixya.
Nov 22, 2010 | Belkin Computers & Internet
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
Acer aspire 7520 cant connect to LAN ( local only)
Hardwired to modem or router?
Router = check connection to router
(had a router die on me last fall - not AC supply)
IP should be 192.168.1.xx or 192.168.2.xx
(is standard)
Reset Router = reset hole on back - hold for 10 sec
Modem= same directions as router
(most modems work like single port routers)
(do reset of cable modem, I've had that prob too)
Using PPOE connection = check log on info
Took most of my home network apart to find it was the modem causing the problem - should've started there.
Apr 04, 2010 | Acer Aspire 7520-5185 Laptop
Cant connect wii to internet
The unit can connect to the Internet by utilizing its 802.11b/g Wi-Fi, which is built in, for wireless connections or via a USB-to-Ethernet adaptor for DSL connections.
For your wireless connection or Wi-Fi, the 802.11b Wi-Fi has a data rate of 11 Mbits per second and has an indoor range of 30m or approximately 98 ft. The 802.11g has the same indoor range, however the data rate is at 54 Mbits per second. If you have an existing wireless connection or are in a Wi-Fi hotspot, the unit will connect to your wireless connection automatically out of the box. If you do not have a wireless network, however, you will need to have your wireless network subscription done or set-up first. Once you have wireless Internet access, you then search for your access point, put in your security settings and you’re good to go. It would also be advisable to have a wireless router for this so that you won’t have to shuttle the connection between your PC and your Wii. wi-fi-usb-connector.thumbnail.jpgAnother option would be to connect your Wii via the Nintendo Wi-Fi USB Connector. This accessory allows Nintendo Wii users who do not have an existing Wi-Fi connection or a compatible Wi-Fi network to create one through their broadband or DSL connected computer. This is inserted into your existing computer’s USB port and the Wi-Fi USB Connector acts as a wireless access point for the Wii. This allows the user access to the internet and to play Wi-Fi Connection games from Nintendo Online.
nintendo-wii-lan-adapter.thumbnail.jpgFor your DSL connection, however, you will need to have quite a few things. You can use a WII LAN adapter to connect your Wii to your DSL modem. You can also use a router so that you can use your PC and your Wii at the same time. With the LAN Adapter though, to use or plug in the Wii, you must disconnect your PC. This can be quite tedious since you will have to plug in and out your PC and your Wii every time you need to use one or the other. A LAN Adapter is fairly cheap, but if you get a router, your PC and your Wii can go online at the same time, saving you the hassle of connecting one or the other when you need them. You can then hook up the existing ethernet cords to the back of the router and connect it to the Wii via a USB 2.0 cord.
i hope this helps
Nov 05, 2009 | Nintendo Wii Console
I'm trying to set up a wireless network for the first time... can anyone walk me through it??
connect the Modem to the WAN or Internet port of the router then wired the computer to any LAN port of the router.
Open IE and type the IP address of the router
Login to the router
Example if its Dlink
IP is 192.168.0.1
user: admin
pass: none
If linksys: 192.168.1.1
user: none
pass: admin
Then run the setup wizard!
if you cant find the password click here:
www.routerpasswords.com
Apr 28, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Can't connect to internet wired or wireless with wbr-2310
Disable the IPV6 and use the IPV4 then try accessing the configuration page of the router and configure the Internet Settings
Jan 27, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Http://192.168.1.1 is not working anymore? i cant set up the router
you can not access the internet - maybe you will not read this..
Definately reset your router - and setup as you did previously.
Omit setting passwords until you have full confidence in the router and your own settings.
Aug 17, 2008 | NetGear WGR614 Wireless Router
I cant figure out my password
You can reset the router, There is a reset button when you press and hold it will change the settings to factory default, so you can use default password.
Good Luck
Jun 20, 2008 | Arris Wireless G Broadband Router (wr850g)
Cant connect my router
what is the source of your connection thru telepon line or a broadband connection or DSL?i need to know this........
Jul 16, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Computers & Internet Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
