Question about Amana 23.1 cu. ft. Side-by-Side Freestanding Refrigerator SCD23V
Amana side by side red turn knob at the bottom what is it?
I have a Amana side by side model # scd23tw it has a red knob at the bottom that turns if you turn it 1/2 it turns off the fridge what is the knob and how should it be set?
    President:
  • Amana Master
  • 2,651 Answers
Thats the defrost timer. its merely a clock thatcycles the refrig in and out ofdefrost cycles,shouldnt be set to any particular place, it will free turn just a s as clock will
Posted on Feb 03, 2009
Amana fridg runs gets cold then won't come back on. And starts depfrosting
If this is "side by side" make sure that you haven't blocked the vents between the freezer and the refrigerator compartments with too much food. The refrigerator compartment is totally dependent on cold air from the freezer and if those vents are blocked, odd things begin to happen. Hope the solution is this simple.
Oct 06, 2014 | Amana Refrigerators
Knob on amana window air conditioner cracked and won't turn on
The knob has a metal post clutch sleeve on its stem. Place a flat bladed screw driver on a small piece of flat wood a 1/4 of an inch high. Lightly pry upwards it will slowly move up and off the shaft. Now if its just cracked, get a poly solvent glue kit wrap the out side of the knob with a couple of turns of the tape cut and adhere the wrapped knob with the tape. Turn on the solvent glue tool and coat the inside of the bottom of the knob being careful not to obscure the shaft inner sleeve. Partially fill the knob, turn on the UV light and cure the cement until hardened. Repeat this step until the knob is as hard as it can get. Any over flow just carefully trim and sand. Get some model paint enamel just give it a few coats and let adequately dry between coats
Nov 09, 2017 | Heating & Cooling
How do I change the water filter for ASD2522WRS
Your water filter is located underneath the freezer door, in the toe plate grille. you will see a knob, turn it counter clockwise one quarter turn. Sometimes its easier if you remove the toe plate grill first. Remove the filter from the housing, then remove the knob from the filter, place the knob on the new filter, remove the red cap on the other end, and with the "handle" of the knob pointing up and down, insert the filter, and twist it clockwise one quarter turn. Replace the toe grill if you removed it
Nov 09, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Freezer thaws then refreezes
I was going to suggest that maybe it is a self defrost issue not shutting off when it should but sine you mentioned this knob, it suggests a thermostat out of calibration - I can rule out circuit problems since you can manually turn on compressor by turning the knob to a cooler position - you will need to have it serviced and change the thermostat which is not cycling whne it's supposed to.
ALSO - do not refreeze foods in your freezer that have thawed ! Throw them away !!! Normal freezer temps should not be warmer than 10F, the normal temps are 0F, and optimal recommended temp -10F (for hard ice cream) and to allow better recovery in case of power failures.
Refrigerator section no warmer tan 40F.....optimal recommended 34F.
Oct 02, 2009 | Amana 22.6 cu. ft. Side-By-Side...
I need to know where to find the defrost timer on my amana fridge. this is the 22.6 cu. ft model #sqd26vw. Ive looked in the back and found the compressor but no defrost timer. specifically is it in the...
remove the grill at the bottom of the fridge there is a black box wth a knob sticking out you can turn in only one direction clockwise till you hear a click and the compressor and fan will cut off if running.
Jun 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Our Amana side-by-side model SXD524VW (Belgium supplied and installed)stopped working. Lights still work. Some light noise (compressor?) can be heard. But it is warming up. Icleaned all out. It was really...
HI thanks for your question. that little black box is the defrost timer. turn that knob till fridge starts up. and replace the defrost timer. thanks the appliance doc. please rate my answer. thanks
Oct 12, 2008 | Amana Refrigerators
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Kenmore refrigerator 26' side-by-side Model 596.52673200
on the amana rifg pull both knobs off
on the right side of control panel remove a 1/4 in screw
remove plastic panel now u can get too the part
Jun 10, 2008 | Amana ABB1927DE Bottom Freezer...
Amana Refer. runs all the time.
Have you ever cleaned the condenser coil in the back or under the bottom of the refrigerator. Dirty coil will cause this problem, also make sure the little fan motor in the back is working if it stops you can get the same condition. If not these two conditions you may be starting to have a refrigerant problem.
The unit gets low on refrigerant and just dosen't cool properly.
May 17, 2008 | Amana Refrigerators
Amana Bottom Freezer control knob
http://amana.com
go here and scroll to the bottom of the page and click on "sitemap"
and you will find help information.
Mar 17, 2008 | Amana ARB8057CSL Bottom Freezer...
Refrigerators Logo
353 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
