Question about Vizio GV42L 42 in. LCD Television
Problem whith the screen
The tv have a line in the screen
  • Anonymous Feb 18, 2009
    the line is black across the screen is the only thing the tv have
  • San_FranCA May 11, 2010
    as in one straight white horizontal line across a black screen? Can you give more details... like how it happened, sound, no sound etc...
    (BTW: there are no flyback transformer transistor to fail in LCD. This is what used to cause the white light across tube TVs)
    President:
  • Vizio Master
  • 1,779 Answers
This problem is either the LVDS plug that plugs into the lcd display, or the logic panel, or worse case scenario the lcd display is bad.
Posted on Feb 20, 2009
My screen locked up whith white and blue line through th screen
What is the brand name and model number to your TV? Provide more details; please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 03, 2015 | Televison & Video
I have lg du-42lz30 tv everything is fine but sometimes the picture is distorted whith lines
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 20, 2014 | Televison & Video
What is wrong whith nabi 2 that has sreen probloms
sounds like your screen broke. Nabi has 2 'scereens' a piece of glass on top, then the LCD screen below. The LCD screen can be broken by hitting or twisting it. It can also become more prone to breakage if you leave it out in excessive heat.
Nabi will fix the screen for about $60...
Jul 02, 2014 | Nabi 2
Vizeo 50 in lcd tv terns on screen gose whit and light blue whith line then truns off
Make sure screen is not broken, and if turns off then check power supply and see if bulging capacitors are in PS and replace.
Apr 29, 2011 | Vizio VA220E LCD TV
When I swicth my TV it go for less then five second without any thing heppen in the screen and go off again
same prop cannot sorce the proplem but mine a overload on the 12v line other than that good luck it apers to be a comon prop whith these but nec dont want to know it but will repair 250 quid
Apr 28, 2010 | NEC PlasmaSync 42MP2 42 in. Television
My tv quit with no picture or sound and only a white line
It's more than likely that the white line is from left to right, is that the case?
Apr 16, 2010 | Proton MM2701VT 27" TV
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
I have same tv but mine has sound but no image
see if the trc filament is light, if is not check the resistor that is serial whith the filament.
But the filament is light, turn a litlle the screen knob of the fly back transformer, may be you will see a horizontal line at midle of the screen, these mean vertical trouble.
Mar 05, 2010 | Philips Magnavox 27MS343S 27" TV
The tv picture looks like should be wachting it whith 3d glasse
This is a very common failure on Projection TV sets. Its called a convergence failure. Here are some common symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around objects on the screen.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Red line fault
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Aug 07, 2007 | Samsung HCN4226W 42" Rear Projection...
Vizio GV42L 42 in. LCD Television Logo
82 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
