Question about Canon PIXMA MP210 Photo All-In-One Printer
Pc does not recognise my mp210 printer
I installed from cd it worked well for 18 month . by accident i deleted scansoft omnipage se . reinstalation did not help , deleted the whole lot and re installed , negative result
.please tell me how to get my printer back on line
i get message , unknown device
  • lutz683 Feb 03, 2009
    i think i throw this pixma mp210 in the bin and get some other one
    no its not working , so where is my guaranteed solution
  • 106 Answers
You must repair your windows.... or your OS... then try it again
Posted on Feb 03, 2009
  • INHS INHS Feb 04, 2009
    hmmm. try to change your USB cable. maybe your USB cable is damaged.. then check your USB port in your pc if it is OK..
How do you use the scanner with a Macbook?
yes you can,
dont forget to install its driver first.
Mar 08, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Does the MX310 have OCR?
Yes according to Canon's support site found on the link below the MX310 does have OCR using the Scansoft OmniPage SE software bundled with the printer.
http://www.canon.co.uk/for_home/product_finder/multifunctionals/inkjet/pixma_mx310/index.asp?specs=1
Jun 29, 2010 | Canon MX310 Office All-In-One Printer
OmniPage Professional 16 fails to launch
uninstall the program, reboot and then reinstall it following the instructions and on-scree commands and prompts. if the result is the same, maybe consider changing the version of your os, maybe your os somewhat conflicts with the program. try using oem os'
Jun 02, 2010 | ScanSoft Nuance OmniPage 16 Professional...
I want to scan a paper and i want to save it as word so that i modify it. How can i do it?
It depends on if you have the full software installed. The MP160 documentation indicates it came wth ScanSoft OmniPage SE. Open MP Navigator and choose this program, you can output the scan as a text file. If you did a custom install, you may or may not have installed the program. If you omitted the program, do a new custom install.
OmniPage is an OCR program and will output to a number of formats (you will choose File, Save as) after scanning. Word can import RTF and most other choices as well as .doc files.
If you don't have the software disc, the software can be obtained from this URL:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Alternatively, there is a free OCR program (simpleOCR.com) that will do the same thing. However it doesn't handle text in columns (newspaper or magazines) very well.
I hope this helps.
Feb 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Omnipage not recognising Epson DX 4850 scanner (all in one)
Go to the Omnipage sight, they should post the scanners that have problems with their software. If you ahve the packaging, the guide should tell you or direct you a site that carries this information. Call Epson DX scanner or go on line to their site and query them about the problem, they should help. Go to the Contact Us. This should help you good luck
Jun 17, 2009 | ScanSoft OmniPage Pro 14
In trying to install OmniPage SE onto a new computer with the vista operating system, all goes well until I come to the installation of OmniScan SE. I get the message: "The wizard was interrupted before...
Unfortunately, Nuance most likely doesn't have a Vista patch to sort the problem with Omniscan.
The best advice I can give you is to remove Windows Vista from your system and install Windows XP.
Vista is riddled with bugs and incompatibilities with many software packages and has been replaced with Windows 7 which is due to be released soon.
Rather use windows XP until Windows 7 becomes available and save yourself many further headaches.
Let me know if you would like any further assistance.
Best regards,
Graemevm
Apr 28, 2009 | Canon ScanFile OCR Full Version for PC
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Re: Canon Pixma MP210 Installation problem
no the screen recognizes fax instead of a computer
Mar 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Cannot install omnipage se. wizard interupts process
When unistalled the previous Omnipage SE 4.0 and try to install new update vresion, an error message keep poping up saying a previous version of Omnipage is still installed in the computer and can not install the new version. No more trace is found for old version in Add/Remove screen. The problems are in the registry area. Just run regedit (export the registry as backup) and look for Scansoft under the software directory. Deleted all the Scansoft omnipage traces then restart the computer will solve the problem.
Nov 04, 2008 | Office Equipment & Supplies
Canon PIXMA MP210 Photo All-In-One Printer Logo
89 people viewed this question
old marine
old marine
