Question about Sony Ericsson W910i Cellular Phone
Hole in the back of phone
What is the hole in the back of my phone for, it has a small rubber plug in it and when you remove it, it looks like a small coaxle cable plug
Thats the speaker
Posted on Feb 03, 2009
Where can I find the back brake adjustment wheel on a 2001 hyundai accent
look for a small slot in the top of the backing plate ( plugged up with a rubber block). Inside there will be small notched wheel that screws a threaded bar . Because of the conditions of the backing plate some manufacturers put the hole in the drum behind the wheel meaning the wheel has to be removed first.
Jul 27, 2014 | 2001 Hyundai Accent
Tip
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After clearing the paper in all access doors (both front and back), the printer still gives the paper jam error. Also, if you have tried restarting the printer several times to no avail and the red light keeps blinking, here is the fix to what is most probably been causing the paper jam problem of Canon ImageClass MF3240.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
on Jan 07, 2010 | Office Equipment & Supplies
What do you remove to have access to spark plugs
Tools you will need before you start1. 1/4" ratchet2. 1/4" extention3. 10 mm socket, 1/4" drive4. small flat bladed screwdriver5. 3/8" ratchet6. 3/8" long extention7. 5/8" spark plug socket, 3/8 " drive8. air compressor with blow gun or can of compressed air9. long needle nose pliers10. 1/4" internal diameter rubber hose 8 inches long11. wire coat hanger12. neverseez lubricantProcedure1. Remove the two 10 mm cap nuts on the top plastic housing over the engine2. Remove the two fasteners on the back of the housing and remove the plastic cover3. You will see four plastic blocks with four wire clips on each block. These blocks are individual coils for each sparkplug.4. Use compressed air to blow out debris around the blocks5. Use the small flat bladed screwdriver to carefully lift up on the tab that holds the electrical connector onto the block and slide the wire clip off the block.6. Remove the 10 mm bolt that holds the plastic block onto the engine. Use the needle pliers to firmly grasp the plastic screw and pull straight up to remove it
7. Loosen the 10 mm nut on end of the plastic rail that holds the wiring harness for the blocks so that the round plastic washer on the bottom of the block will not break when you pull off the block8. Carefully pull the plastic block out of the engine. There is a 4 inch tube attached to the block that extends into the engine to the spark plug. It will take some twisting and pulling but you must be careful not to catch the back part of the round plastic washer that you cannot see, on the bottom of the plastic wiring harness.9. The spark plug is at the bottom of the 4 inch hole.10. Blow compressed air down the hole to remove debris11. Use a 5/8 sparkplug socket with a rubber collar on the 3/8" extention to remove the spark plug. The rubber collar will hold onto the spark plug as it is removed.12. The NGK website recommends making sure the spark plugs have the correct gap .044 but the spark plug box says not to adust the gap because you might damage the needle point iridium tip. The new spark plug has a protective cardboard tube that is removed.13. Spark plugs can stick inside aluminum heads and break off when you try remove them, leaving only the threads of the plug inside the engine which will necessitate removing the head to remove broken spark plug. Putting neverseez on the threads of the new spark plug will prevent that in future spark plug changes14. Now comes an interesting choice. You can use the rubber tube over the neck of the spark plug to slowly drop it down the hole and hand tighten it or you can use the spark plug socket with the rubber collar. If you use the spark plug socket, the rubber collar will stick to the plug and you will pull off the extention, leaving the socket in the hole. A pair of long needlenose pliers will reach into the hole and remove the socket, but the rubber collar may remain on the plug and you will have to bend a piece of coathanger with a short 90 degree tip to reach into the hole and pull out the rubber collar. The rubber collar is there to prevent you from cocking a regular 5/8" deep socket at an angle which will break off the neck of the sparkplug, necessitating another 10 dollars and another trip to the auto parts store.15. After the spark plug is hand tight, give it 1/2 turn more.16. Replace the square block, being sure that the black silicone gasket on the bottom of the round plastic washer does not get bound up on the engine post where the 10 mm bolt goes. Tighten the bolt17. replace the electrical clip.18. Go to the next spark plug and repeat the procedure.19. After the last spark plug is done, be sure to retighten the 10 mm nut on the wiring harness rail20. Replace the plastic cover over the engine and you are done
Nov 09, 2011 | Toyota Cars & Trucks
Where are the Spark Plugs located in a 2004 Lincoln Navigator?
Hello, first how many miles do you have on this Lincoln? On that 4.6 L V8 engine they do have spark plugs but each plug has it's own spark coil located on a long rubber plug. You will see four little coils on each side of the engine. There will wires going in to the individual coils. There will be a bracket the holds the coils in place with a small 9 or 10 mm nut. Remove the nut, and gently pull on eac coil. There Hello, first how many miles do you have on this Lincoln? If you have over 120 thousand miles on this engine then it might need new spark plugs. On that 4.6 L V8 engine they do have spark plugs but each plug has it's own spark plug coil. You will see four little coils on each side of the engine. There will wires going in to the individual coils. There will be a bracket the holds the coils in place with a small 9 or 10 mm nut. Remove the nut, and gently pull on each coil. There a long rubber plug that fit in each spark hole. These rubber plugs are about 4 1/2 to 5 inches long.
Before removing the plug use an air hose with 50 to 60 lbs of pressure to blow each spark plug hole out which might have foreign object in the hole. Why, if you remove the spark plugs, and there is foreign material in that plug hole. Guess what, that stuff will fall into the combustion camber.
Then you will really have some problem. How fix if stuff fall into the combustion camber.
Squirt small amount of oil in the combustion camber, unplug all the coils and clear out there plug hole. Now remove all the spark plugs. Now, you can crank the engine and will the little amount in that cylinder that has the junk in it. The oil will wet the foreign debrie, and blow it out the spark plug hole. Then use a clean rag with with some oil it with a long screw driver to clean that spark plug hole Be careful that don't push the foreign material back into the combustion camber. Do this several time with little amount of oil.
Now, you can install the new spark plugs. On the spark plugs threads use some anti-shiz grease. Why squirt oil into the combustion camber? The oil is used to seal the rings on the piston to increase the cylinder compression. Just a small amount goes a long ways. GB...stewbison
a long rubber plug that fit in each spark hole. There rubber plug are about 4 1/2 to 5 inchs long.
Before removing the plug use an air hose with 50 to 60 lbs of pressure to blow each spark plug hole out which might foreign object in the hole. Why, if you remove the spark plugs, and there is foreign material in that plug hole. Guess what, that suff will fall into the combustion camber.
Squirk small of oil in the combustion camber, unplug all the coils and clear out there plug hole. Now remove all the spartk plugs. Now, you can crank the engine and will the little amount in that cylinder that has the junk in it. The oil will wet the foreign debrie and blow it out the spark plug hole. Do this serveral time with little amount of oil.
Now, you install the new spark plugs. On the spark plugs threads use some anti-shiz grease.
Sep 12, 2011 | 2004 Lincoln Navigator
Cycle stops and F35 displays flashing
I blew mine out with compressed air and it worked, You have to take the cover off and remove the small rubber hose. Then blow out the hose and blow into the small hole on the sensor. It is easy to remove from the machine, 3 screws in the back then remove the rubber hose, twist the unit so the bottom is facing the back of the washer and it pops right out, then remove the wire plug.
Oct 16, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
Need rubber foot for frigidaire professional series gas stove iron grill. My stove has three grills, each grill having 4 rubber (rivit-looking) feet. Apparently the missing foot, as small as it is,...
I just had my stove serviced today. You can purchase a foot kit for $30. The part # is 5304475129. http://www.mdappliance.com/ELX-5304475129.html. I could not find a place that only sold the rubber feet. Clean any debris from the hole that the rubber feet goes into. Add a small amount of the high temperature adhesive in the hole. Insert the rubber feet back in. The rubber feet has a pin point hole in the middle. Insert a paperclip in the hole and stretch out the sides of the rubber feet, so the sides stick to the adhesive. Place the grates back onto the stove and let it sit for 2 hours. Good luck.
Feb 06, 2010 | Kitchen Ranges
I been using Nokia E51 and my switch on/off button is all dead because of pressing it too hard all the time, It's completely no button. Is there any other ways to Switch on the phone.?? My phone is all...
If the black rubber cover of the button is blocking you to the small switch inside, you have to remove the rubber first until you can see the small on/off switch inside the hole. Make a small block (approximately 3mm x 3mm x 8mm) out of a pencil eraser (or hard rubber). Place and fit the rubber inside the hole so that part of the rubber touch the switch. Now you can turn the phone by pressing the rubber.
Jan 14, 2010 | Nokia E51 Smartphone
How to remove rear brake drums on 2002 frod escape
Behind the brake mounting plate there is a small hole with a rubber plug on the top portion.
Remove the plug. Look from the back of the vehicle and you will see a star wheel in the hole. Stick
a long skinny screw driver with a large blade and rotate it in the direction of risistance.(clockwise).
You will hear a spring poping noise. Rotate a few times and the drums will turn freely.
Then you can slide the drums off.
Jun 27, 2009 | 2002 Ford Escape
Key won't come out
u got 2 use a small screw driver right under key ther is a hole put srw driver in hole turn key back
Nov 02, 2008 | 1997 GMC Jimmy
Sony Ericsson W910i Cellular Phone Logo
80 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
