The bottom of the agitator is agitating fine, but the top barely moves unless you push it to the side. The top of the agitator will not agitate without holding pressure to the side.
This is a problem with the parts that we called dog agitator. They are 4 pcs plastic parts that function as a lock on a ratchet handle drive.
the top agitator would turn one way and these dog agitators prevents it from going the other way.
To replace it, you have to remove the top softener dispenser, remove another plastic cover that covers the bolt from water. remove the bolt and you can pull the whole agitator out of the tub. Be careful on dismantling, it is tricky to put it back. Remember where every part goes.
On Regular Cycle: Machine sticks btwn Rinse and Spin. Will continue to spin until manually set on...
(More)
On Regular Cycle: Machine sticks btwn Rinse and Spin. Will continue to spin until manually set on Spin. Then it completes cycle. Have used Perm Press cycle and machine completes with no problem. We have a new timer but cannot figure out how to remove dial. Any help is appreciated. Thnx, KQ
