Question about Radio Shack Pro-2096 Base Scanner
Can't program I can't program a spefic frequency into my scanner. I don't went to buy the the win96 software. Is there anyway to do it manerally? If so how would I do it?
  • 120 Answers
First press manual, then the channel number you wish to program,then press pgm (or program),type in the frequency, press enter and its in there
Posted on Feb 13, 2009
My pro 2096 has no volume
  • You have to uses external software on this scanner.
  • Custom GRE/Radio Shack Frequency Table
  • Table 1 ---
  • With WIN96 software for the PRO 96/2096 scanner:
  1. Prompt "MULTI TABLES"
  2. Prompt "EXTENDED TRUNKING TABLES"
  3. Do not prompt any "STANDARD PLANS"
  4. "CH LOW" 8192 "CH HI" 12287 "BASE FREQ" 453.0250 "OFFSET" 8192 "STEP" 12.5
  5. "CH LOW 12288 "CH HI" 16383 "BASE FREQ" 450.0000 "OFFSET" 12288 "STEP" 6.25
  6. Clear all other trunking tables, and prompt "OK"
  7. Now save your file.
  • Custom Uniden Frequency Tables
  • Table 1 -
  • Base: 452.0000
  • Space: 12.5
  • Offset: 380
  • Table 2 -
  • Base: 460.0000
  • Space: 12.5
  • Offset: 570
  • If you have not done this then you will receive no audio on digital reception.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 06, 2011 | Radio Shack Pro-2096 Base Scanner
Pro-95 stopped scanning
Try to turn off unit and remove battery pack, then reinstall it after 10 mins and while its off press scan button for 5 seconds and turn it back on. it should automatically go to scan mode on WX
Apr 30, 2008 | Radio Shack Pro-95 Handheld Scanner
Unable to program
It is easiest to do with softwear, There are free versions that work great.
Apr 02, 2010 | Radio Shack Pro-2096 Base Scanner
We have a police digital scanner havent been able to receive the police frequency wonder if they have been changed? i dont want to have to pay for this service just need new frequency numbers if they have...
Your community's public service radio frequencies may have been rebanded. Rebanding was the result of services throughout the nation being moved in the 800Mhz band.
Complete rebanding details of this can be found here:
http://wiki.radioreference.com/index.php/Rebanding
The Pro-2096 scanner can be reprogrammed to receive your old services in the new band with software that is run on your computer and connected to the scanner. It is available for a small fee ($30). More information on this can be found below:
http://wiki.radioreference.com/index.php/Win96
Many scanners are not capable of upgrading, and were reduced to "paper weights". Consider yourself lucky that a $30 upgrade will restore the full functionality of the radio. A great deal of information on your scanner can be found here:
http://wiki.radioreference.com/index.php/Pro-2096
I hope this helps!
Sep 29, 2009 | Radio Shack Pro-2096 Base Scanner
Pro-96 Scanner Not Receiving Philadelphia Fire Department Radio
Well I would check up on their current frequency. They may have changed frequencies overnight. It does happen. Here is a handy website to check out. Look around and hope it helps you.
http://www.radioreference.com/apps/db/
Mar 03, 2009 | Radio Shack Pro-96 Scanner
Talkgroups and control channel problems?
No, you are not programming it wrong. The reason it is picking up all the active talkgroups is because the bank is "open". Hit manual like you are going to program a frequency in. Go to the particular bank in question and hit the function , 5. The display should say bank closed. This will "close" the bank and only allow the talkgroups you have programmed thru. To "open" the bank back up to recieve all frequencies do the same thing again. Function, 5. If you have any other questions email me at josephnshelby@aol.com and I will be glad to help.
Joey
Jul 22, 2008 | Radio Shack Pro-96 Scanner
Programming
No..you do not have to delete that programming. You can download the scanner using Win96 and then add or delete talkgroups and frequency data in Win96. Once this is complete, just upload it back to your scanner.
Word to the wise..you may want to save the results of your scanner download BEFORE modifying it. That way you can reload it if you make any mistakes while updating it.
Jul 06, 2008 | Radio Shack Pro-2096 Base Scanner
Scanner not working
Did you use a software program or have radio shack program the scanner for you? If so, check to make sure the banks were selected in the software to be enabled. I assume the your scanner shows 0123****** Now to manually select banks, simply press the number for the selected bank to both select and de-select as warrented. When you press 4, bank 4 will now be scanned. Also, should you press 1, bank 1 will not be scanned.
Feb 08, 2008 | Radio Shack Pro-96 Scanner
I have a pro 96 scanner that i just cant seem to program. how can i do it?
Call your local Radio Shack. They can either program it for you or suggest someone who can.
Dec 19, 2007 | Radio Shack Pro-96 Scanner
Programming
Go to Don Starr software link at:
http://starrsoft.com/software/win96/default.asp
The best $30 you will spend to make the Pro 96 sing for you.
Also use:
This site has all you need to get going and a direct download of frequencies and talk groups for trunked systems...
Cheers,,,Tom M sends
Oct 04, 2007 | Radio Shack Pro-96 Scanner
Radio Shack Pro-2096 Base Scanner Logo
83 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
