Question about LG 37LC7D 37 in. LCD HDTV
How to connect speakers to LCD
How do i connect my LG 37LC7D 37 in' to additional speakers?
  • ali the khan Mar 07, 2009
    i need help with lg2000 it only has a g=rgb output so i cnt connect the speakers to the tv but i can onli make the computer sound com from the tv THE TV HAS NO HEADPHONE SLOT plz help ASAP thnks
There is a sound or speaker out jack on the back of the tv, this must be sent to a reciever of some sorts. any older home sound system will do. use the audio in jacks or aux. jack and your on your way!!! its not that hard !!! just take your time and it will be so easy!!!!!!
Posted on Feb 03, 2009
No sound on lg 37lc7d 37 in lcd hdtv
Apparently something else has failed on the circuit board(s).
Nov 10, 2013 | LG 37LC7D 37 in. LCD HDTV
No sound on an lg 37lc7d tv?
Your main pcb could still have gotten damaged due to the defective caps. The reason you still have audio through the optical is because it is a digital signal only. It is not running through the audio amplifier on the main board. I would suspect either the main pcb or the speakers them self.
Mar 15, 2013 | LG 37LC7D 37 in. LCD HDTV
LG 37LC7D 37 in. HDTV LCD TV My screen seem to over heat, Goes blank, but TV is still on. then comes back on for a few seconds, then again blacks out
It sounds like a problem in the high voltage circuit. Had a similar TV set which had the same problem. When there's power leaking from the high voltage circuit, these TV's will tend to cycle on and off. Voltage leaks are mostly caused by accumulated dust for the most part.
Jan 31, 2011 | LG 37LC7D 37 in. LCD HDTV
Looking for a tv stand for LG 37LC7D 37 in.
I would suggest you check ebay, or shopjimmy.com.. there was one at shopjimmy.com but I am not sure if it is still available.
good luck!
Aug 25, 2010 | LG 37LC7D 37 in. LCD HDTV
LG 37LC7D 37-inch 720p LCD HDTV
Unplug it for about an hour to let it reset itself and try again, if it still has problem then you will have to open it up or take it to the repair shop. The power supply module will have to be looked at first to make sure all the voltages are present. Right now the 5vdc standby power supply is working and may be partially function processor.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 10, 2010 | LG 37LC7D 37 in. LCD HDTV
37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
Mar 04, 2009 | LG 37LC7D 37 in. LCD HDTV
37" lg television
sounds like u have a dead solder joint or loose connector. poor workmanship LG (formerly known as GOLDSTAR is known for)
Dec 05, 2008 | LG 37LC7D 37 in. LCD HDTV
LG 37LC7D 37 in. LCD HDTV Logo
2,068 people viewed this question
Computer Repairing
Computer Repairing
