Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
SONY TV PROBLEM
SONY KP46WT500 PICTURE TURN DIFFERENT COLORS BRIGHT THEN SHUTS DOWN
  • Anonymous Apr 27, 2009
    tv turns on fine for about 10 seconds then picture turns to red and shuts off
  • citikitchen Apr 27, 2009
    picture turns red then shuts off?
  • Sony Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
    Scholar:
  • 41 Answers
Does the light flash 8 times after it shuts down? Take a look at the site Jean posted, it sounds like the problem that this site will help you fix.
Posted on Mar 13, 2009
    Scholar:
  • 29 Answers
Http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
This blog covers many makes and models with many issues solved, just with that one solution
Give it a try, it's free and simple :D
Had a similar problem , fallowed the directions in that
blog....and it was fixed in 10 min :D
The Guy Ken, who posted it is a GOD !!!!!
Hope the blog helps you and anyone with this or similar
problems !
Jean
Posted on Mar 12, 2009
I'm trying to cut off the timer on a sony t.v.RM-Y909 so I can turn my t.v. on with the remote control.
The RM-Y909 works for the KP46WT500, among other TVs. For the KP46WT500: to reset Timer 1 or Timer 2, you need to access the timer sub-menu. With the TV on, press Menu. Use the Joystick on the remote to select the Timer icon (looks like a clock) then press the center of the joystick (with the + with a circle at the center symbol). Use the joystick to select the timer you want to reset and then press Reset (on the left side at the bottom of the remote). Alternatively, you can just turn off the timer. The TV will remember the settings. Press Menu to exit the menus.
Sony has the manual on their product support page in the manuals tab: https://esupport.sony.com/US/p/model-home.pl?mdl=KP46WT500 . The direct link is https://docs.sony.com/release/KP46WT500.PDF . The Timer menu section is on page 57. I hope this helps.
Aug 31, 2015 | Sony Televison & Video
My sony kp-51ws510 color rear video projector tv when i turn it on it stays on for abt five seconds and then turns off and also the timer and standby light is flashing red
this model did have problems with bad picture tubes---screen goes bright red,green,blue and set shuts down.
set also does this to protect itself---when fails look to see if specific sequence of blinks
Apr 17, 2012 | Televison & Video
Sony tv keeps shutting itself off
HI,
If TV shows high bright light of either red, green or blue and shuts off then it got related color picture tube problem that will be replaced.
Bad picture tube replacement is job of qualified tech because it requires multiple adjustments after replacement. Please check with local tech for an estimate.
Hope this info will help you.
Thanks.
Dec 14, 2009 | Audio Players & Recorders
I have blue arched lines on my sony kp 57wv600 is there a fix for this
Those are retrace lines, the screen controls which are a technical control located under the front gray panel of your tv needs adjusted. This also could be an indication of a bigger problem, most common would be the focus block failing. it could also be of the picture tubes failing but this is not as common or possibly the crt driver ic's. There are specific diagnositc steps to preform to isolate the potental failure. this could lead to the tv going very bright then shutting down.
The first thing a tech is going to do is to adjust the screens and leave, somtimes this is enough, but sometimes it is not. if you want to try and adjust the screen i have an instruction set below, but i must warn you that there are high voltages present when attempting this adjustment and can be dangerous if you are un familure with tv repair.
Turn your color all the way down and the brightness in the middle, then find the focus block, it will be a block with 6 controls one row will say screen the other will say focus near the picture tubes, adjust the screen controls(one control for each color) until the picture has a good black and white look to it, then turn your color up and it should look fine. This is how i balance out the picture. But there is another method that allot of techs use, the other method is to adjust the brightness up until you see what is called retrace lines it is a jagged line going down the screen, once you see these lines back the adjustment down just until they disappear. Do this for all three colors. This method works but on an older set can throw the white balance off because of tube wear.
Aug 05, 2009 | Sony KP-57WV600 57" Rear Projection...
The picture is to bright
problem in high voltage area, consult an expert
Jun 02, 2009 | Emerson EWF2704 TV
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Mar 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Red and green colors not coming through in picture
Bad crt
Sony Picture tube recall
http://esupport.sony.com/perl/news-item.pl?news_id=24
Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700
Feb 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Red Screen
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
Sep 24, 2006 | Sony KP-57HW40 57" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
313 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
