Question about Epson Stylus Photo R300 InkJet Printer
Out of ink, but I can't tell which cartridge...
How do I tell which ink cartridge needs replacing.
  • lynn_jake Feb 03, 2009
    Thanks so much......   THanks    Thanks   thanks...
    You solved my problem.   I need Black ink..
    Sniper:
  • 61 Answers
Control Panel>Printers
Right click your printer>Properties>Maintainence>View Printer Status
Ink Details Menu
Posted on Feb 03, 2009
Ink light is on. which cartridge needs to be replaced
The printer's indicator lights tell you when to obtain a replacement ink cartridge by flashing when ink is low, and when to replace an empty ink cartridge by remaining on when ink is depleted. The LCD panel also displays INK LOW or INK OUT.
Even if only one ink cartridge is empty, the printer cannot continue to print.
Nov 24, 2014 | HP DeskJet 960c InkJet Printer
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
Where do the ink cartriges on a brother mfc 5460cn fo
Your machine is equipped with an ink dot
counter. The ink dot counter automatically
monitors the level of ink in each of the 4
cartridges. When the machine detects an ink
cartridge is running out of ink, the machine
will tell you with a message on the LCD.
The LCD will tell you which ink cartridge is low
or needs replacing. Be sure to follow the LCD
prompts to replace the ink cartridges in the
correct order.
Even though the machine tells you that an ink
cartridge is empty, there will be a small
amount of ink left in the ink cartridge. It is
necessary to keep some ink in the ink
cartridge to prevent air from drying out and
damaging the print head assembly.
a Open the ink cartridge cover.
If one or more ink cartridges are empty,
for example Black, the LCD shows
Ink Empty Black and
Replace Ink.
b Pull the lock release lever down and
take out the ink cartridge for the color
shown on the LCD.
c Open the new ink cartridge bag for the
color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1).
Note
If the protective yellow caps come off
when you open the bag, the cartridge will
not be damaged.
e Each color has its own correct position.
Insert the ink cartridge in the direction of
the arrow on the label.
f Lift each lock release lever and push it
until it clicks, and then close the ink
cartridge cover.
g If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example,
Did You Change Blck?) For each
new cartridge you installed, press 1
(Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge
you installed is not a brand new one, be
sure to press 2 (No).
If you wait until the LCD shows
Near Empty and Ink Empty, the
machine will automatically.
Find this on page 113 of the manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002135/cv_mfc5460_usaeng_usr_a.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 04, 2010 | Brother MFC-5460CN All-In-One InkJet...
Tells me ink needs replaced even after putting in new ink.
check your new ink catridge and look for a mini green electronic chip if that is damaged the printer shouldn`t recognize the catridge
May 16, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
The printer keeps messaging ink on sseveral colours is low but it is not. Have even tried new cartridges but no difference, same message . Seems to be misreading ink level
Some printers need special software (that shipped with the printer) to "tell" the printer that the ink-cartridge has been replaced, and that the ink-levels need to be fully "reset".
Apr 23, 2010 | Computers & Internet
I have a Brother MFC5460CN...I can't find the owners manual and I can't figure out where the ink cartridges are? I need to replace them
I found this on the Web site. You can download the manual for yourself. Just click on the link below. If you find this information helpful, pls rate me.
http://www.retrevo.com/d/ds/progress?doc=9adbcf37695f2981dab6cde6d0fdb2d1
Replacing the ink cartridges B
Your machine is equipped with an ink dot counter. The ink dot counter automatically
monitors the level of ink in each of the 4 cartridges. When the machine detects an ink cartridge is running out of ink, the machine will tell you with a message on the LCD. The LCD will tell you which ink cartridge is low or needs replacing. Be sure to follow the LCD prompts to replace the ink cartridges in the correct order.
Even though the machine tells you that an ink cartridge is empty, there will be a small amount of ink left in the ink cartridge. It is necessary to keep some ink in the ink cartridge to prevent air from drying out and damaging the print head assembly.
a Open the ink cartridge cover. If one or more ink cartridges are empty,
for example Black, the LCD shows Ink Empty Black and Replace Ink.
b Pull the lock release lever down and take out the ink cartridge for the color
shown on the LCD.
C Open the new ink cartridge bag for the color shown on the LCD, and then take
d Remove the protective yellow cap (1). Each color has its own correct position.
Insert the ink cartridge in the direction of the arrow on the label.
f Lift each lock release lever and push it until it clicks, and then close the ink
cartridge cover.
G If you replaced an ink cartridge, the LCD
new one. (For example, Did You Change Blck?) For each
new cartridge you installed, press 1 (Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge you installed is not a brand new one, be
sure to press 2 (No). If you wait until the LCD shows
Note
If the LCD shows No Cartridge after
you install the ink cartridges, check that
the ink cartridges are installed properly.
Pls rate met. Thanks and Good Luck.....
Feb 05, 2010 | Brother MFC-5460CN InkJet Printer
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Feb 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Jun 27, 2008 | Brother Multi-Function Center MFC-3360c...
My Epsn Stylus PHOTO R300 says I need to replace an ink catridge however it does not tell me which one is out of ink. How do I find out which one to buy?
If an ink cartridge is empty, the red error light will remain solid. You can check the status of the of the ink cartridges by looking at the icons on the control panel. Press the down arrow button to scroll down to MORE OPTIONS. The level of ink will be shown on the screen and the ink that will be out will have cross on it.
Please follow the steps below to replace one or more cartridges.
***NOTE***
-You cannot print if any ink cartridge is expended.
-Leave the empty cartridge installed in the printer until you have obtained a replacement.
-To ensure good results on your printouts, we recommend using Genuine Epson Ink cartridges. Epson does not recommend the use of refilled inks or 3rd party ink cartridges.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
1. Make sure the printer is powered on, and not printing.
2. Open the printer cover.
3. Do one of the following:
3a. If the red error light is on (cartridge is empty) press the MAINTENANCE BUTTON.
3b. If the red error light is flashing (cartridge is low) press the MAINTENANCE BUTTON. You will now see the Cartridge Replacement highlighted in Advanced Settings. Select OK.
3c. If the error light is off (outdated cartridge), press the DOWN ARROW MENU button to choose MORE OPTIONS. Press OK, then select INK CARTRIDGE REPLACEMENT.
4. You will now see a message on the display telling you that the ink cartridge replacement will begin. Press OK to continue. The print head will move to the replacement position.
5. Open the cartridge cover. Press in the tab on the back of the cartridge, and lift the cartridge out of the printer. Dispose of it carefully.
6. Unwrap the new ink cartridge. DO NOT touch the green circuit boards, or remove ANY labels.
7. Lower the cartridge into the holder, with the green circuit board facing the front. Gently push the cartridge down until it is firmly seated.
8. If you need to replace another ink cartridge, repeat steps 5-7 above.
9. Close the cartridge cover. Press the front corner of the cartridge cover forward to lock the cover into place.
10. Press OK, and close the printer cover. The printer will begin charging the ink delivery system. Once charging is complete, press OK to finish.
May 23, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
