Question about Lexmark X4270 All-In-One InkJet Printer
Printer will fax out, Will not copy
Try to print test page but only get test page failed to print. Operation could not be completed. error (0x00000006)
  • Lexmark Master
  • 684 Answers
In this case go ahead and Uninstall the software from the Computer...... Download the following Link: http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0 Just go to this Link and select ur Product..... Download the drivers from here and install the Printer..... Thanku
Posted on Feb 05, 2009
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I cannot Fax in and out...error 49 turn off and on. After i turn on the printer another error show that "power failed to recover Fax setting restore"....please Help~
Try the following: got to the menu (the wrench) and with the arrows look for service, press ok and look for restore defaults. After that unplug the fax line (this is very important). Go to the hp website and download the firmware update and run it (while updating dont to anything to the printer, no print, copy, fax.) when that is completed try to fax again this should resolve it.
Jul 25, 2010 | HP LaserJet M1522nf Multifunction Printer...
Dell printer 922 will not print with vista just gives error message ''test page failed to print. operation could not be completed (error ox000000006)
Some older printers are not compatable with Vista, I have VMware virtual machine running so that xp drivers can be used to print with printers that don't have Vista drivers.
Oct 13, 2009 | Office Equipment & Supplies
Same problem
press the setup button and scroll down to tools.
in tools there should be an option that says run fax test.
that would give you a printed page as to which part of the hardware of the printer or the fax line failed.
What your error code means is(look below)
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jun 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Printer won't print
Try this Issue When trying to copy, print, or receive a fax, the following error message appears on the product control panel display. Ink System Failure. Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc19aYYYY NOTE: The Y in the error message represents any digit, 0 - 9, or any character, A - F. Solution To resolve the issue, use the following steps. Step one: Remove the cartridges Make sure that the product is turned on and then disconnect the USB cable from the back of the product. Open the product cover and remove the cartridges. Close the cover and wait for a message to insert the cartridges to appear on the control panel display. Disconnect the power cord from the back of the product. Disconnect the power cord from the wall outlet and wait for one minute. Step two: Reinstall the cartridges Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on. Open the product cover and reinstall the cartridges. Close the cover and print a calibration page, if prompted. Print a self test report to make sure that the product can print. Reconnect the USB cable between the product and the computer. Try to print a document from an application on the computer.
Jun 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printing error
From your start menu, go to printers and faxes area. When this opens do you see your printer listed? Is it greyed out at all or maybe listed as offline? How are you connected tot he computer? Network, USB, or parallel port connection? If you see your printer listed and it has no other duplicate listings, right click the printer and go to properties, then choose the Ports tab. Verify here that the port selected witha check mark corresponds with your connection method. Example: If you are connected through USB, your selected port should say USB. Sometimes DOT4 ports will work for USB connections too. If you see this option, you can select it and hit apply to try it out. Try to print a test page after each applied change. Also, make sure that print jobs haven't built up in your queue by double-clicking your printer icon. If there is a queue of failed print jobs, select them and cancel. This might take a moment to complete. If your printer icon is greyed out, right-click it and un-choose the work-offline option and try it.
Mar 27, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Ink system failure
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer prints partial page and then stops
We have had the same problem. I have found that if I close all windows not being used on the computer, then try to print the document again the entire document prints. This happens on an older computer we have that doesn't have alot of RAM.
Dec 04, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
MFC 440-CN out of memory error, fax memory is full I cn't send any more faxes, I called Brother tech support they told me that there is no way to clear the memory, that I had to leave the printer unplugged...
Try this :
To resolve this situation do the following:
1. If another operation is in progress (example: receiving a fax,
printing, etc), press STOP/EXIT, wait until it's completed and then try
again.
2. Clear the machines memory. This can be done by turning off Advanced
Fax Operations.
a. Press MENU.
b. Press the UP OR DOWN ARROW key to choose Fax.
c. Press OK.
d. Press the UP OR DOWN ARROW key to choose Advanced Fax Operation.
e. Press OK.
f Press the UP OR DOWN ARROW key to choose Fwd/Page/Store.
g. Press OK.
h. Press the UP OR DOWN ARROW to choose Off.
i. Press OK.
j. Press STOP/EXIT.
If received faxes are left in your machine's memory when you change the
Advanced Fax Operations and a backup copy has already been printed, the
LCD will ask:
Erase All Fax?
Yes - Press 1
No - Press 2
Advanced Fax Operations and a backup copy has not yet been printed, the
LCD will ask:
Print All Fax?
Yes - Press 1
No - Press 2
# If you press 1, faxes in the memory will be erased or printed before
the setting changes.
# If you press 2, faxes in the memory will not be erased or printed and
the setting will be unchanged.
k. Try your operation again.
Good luck...
Nov 11, 2008 | Brother Office Equipment & Supplies
Scanner error
usually this means that the scanner electronics has failed. If you can print from the control panel try printing out a configuration page and let us know what the error codes are.
Mar 25, 2008 | HP LaserJet 3380 All-In-One Printer
Lexmark X4270 All-In-One InkJet Printer Logo
406 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
