Question about Dell 2300MP Multimedia Projector
Dell 2400 MP projector lamp problem
I have a Dell 2400 MP projector. After about 2 years of
regular use, the lamp ceased to light up so I replaced it
with a new Dell lamp, but it still will not light up .
  • HSHHelpdesk Mar 16, 2009
    similar issue, only happens occasionally. checked bulb time - only 229 hours reported.
  • 31 Answers
Could be a heat, fan - sensor issue or a power supply issue. Regards Kevin Andreassend http://www.iceav.co.nz iceavtech@gmail.com
Posted on Sep 09, 2009
I have a Dell 2300MP DLP projector. It lights up for about a minute then the light goes out. Both the Temp and Lamp indicators are glowing after the light goes out. The fan is working. Will just replacing...
Looks like there is power supply problem as well as the lamp.
1 Clean all filters
2 Check out power supply (usually a few capasitors need to be replaced)
3 Wuld be a good idea to check the lamp in wokring projector, but if the "Lamp" light is constantly on it is more likely a faulty lamp as well.
Mar 01, 2011 | Dell 2300MP Multimedia Projector
Dell 3300 MP Projector
I think this is a lamp issue. Even though your lamp might have an advertised time of 3000 hrs from Dell, it can fail and dim a lot earlier than that. Often within 1000 hrs a projector lamp's brightness can be reduced by up to 40%. Projector lamps brightness and lamp life varies according to how you use your projector and the environment it is in. Our company sells projector lamps and has created a YouTube video to help people get the most out of their projector lamps. You can see the video below. If you decide to buy a new lamp we have the lamp you need in stock at Projector Lamp Experts.
Hope this helps..
Jul 15, 2010 | Dell 3300MP Multimedia Projector
How to get picture from computer to screen with a del 2400 projector
reset lamp hours, if that don't work, replace lamp. it that doesn't work, the power supply ballast needs to be replaced.
Jun 17, 2010 | Dell 2400MP DLP Projector
Dell 2300 MP turns on and the lamp turns on, but then the tempera
Ok you need to replace the thermo sensor on this now the thing is the replacment is not something "just anyone can do" Now what you can do is this you can take it into BEST BUY witch are EXPERTS to help you replace the sensor in this.
But for a end user to dig inside of this would not be wise. I would highly recommend a expert fix this due to the sensor. The sensor is on the ballast board.
I hope this FREE answer helps please do vote on it anyways and leave some feedback for us today!
Mar 05, 2010 | Dell 2300MP Multimedia Projector
Dell 2300 MP temp light flashes and projector turns off.
I am experiencing a similar problem with mine. It will cycle on and off without actually powering up fully and then after about the 4th or 5th time it will shut off completely and the lamp indicator light on top illuminates. i am reading in other blogs that this is a design flaw on this unit. let me know if you have found any fixes.
Jan 31, 2010 | Dell 2300MP Multimedia Projector
After installing the XL-2400 Lamp unit. This is the blub and housing. I turned the TV on and after a few moments the tv turned off and on the front of the tv where the power light is it is flashing red.
Please make sure lamp cover is reinstalled securely after replacement of lamp in TV.
If lamp cover is not fixed properly, TV wont power up and red light will start blinking.
Jul 16, 2009 | Sony (XL-2400) Projector Lamp for...
Xl 2400 bulb replacement
Go to
www.dlplampguide.com
and select your set model and watch the video which is a YouTube video. Shows entire bulb replacement start to finish.
Jul 07, 2008 | Sony (XL-2400) Projector Lamp for...
DELL 2300 MP NOT TURNING ON
Have the same problem here. Have two of these units. Took the bulb out of the one that had the Lamp light on, and put it in the other projector. The other projector worked perfectly. I have three bulbs, they all work in the one projector, they all cause Lamp Light in the other one. The manual states nothing about hard resetting the unit. Also note that, the fans do not power up instantly on power on, they come on about 5 seconds after pressing the power button.
Aug 30, 2007 | Dell 2300MP Replacement Projector Lamp -...
Dell 2300MP Multimedia Projector Logo
1,072 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
