Question about HP Scanjet G3010 Flatbed Scanner
Hp Scanjet G3010 will not scan hp software says its not available
Hp scanjet G3010 has been hooked up to windows pro XP sp3 and windows Business Vista sp1 with the same results (it was hooked up to the windows XP sp1 for a year and worked fine / took it off as I was not using it). I have downloaded basic drivers from Hp and used vuescan to scan documents same results. I have also downloaded drivers and full scanning software from hp with the same results. I have replaced the USB cable with a known working one same results same results. With the Hp full scanning software( and all software) and color document selected it goes through the process of asking where I want it saved (file and JPG format selected) after this is complete the scanner head comes moves out 1/2 inch and comes back to rest at home. I never get farther than this all I get is error messages saying the scanner is not available or it is not hooked up( I have waited as long as 20 minutes with the same results). No matter the combination of software, drivers or operating sys. I get the same error messages and/or results. I'm stuck HELP
  • spousby Feb 03, 2009
    I went to the Hp url you recommended. I agree it sounds like my problem. Every step until the self test worked fine. I did a "Perform a self test if possible to verify the basic standalone functionality of the device" and the first step passed (The scanning lamp will light up) second step passed (The carriage will return to the home position) the third step FAILED (The carriage will continuously move the full length of the scanning bed) the carriage did not move after step 2. I'm Leary about going any further
  • 4,655 Answers
This is an issue since Microsoft IE7 came out. HP got left in the dark on communicating with Microsoft computers . If your printer is still under warranty they will help you. The problem is HP and Microsoft are not working together and when this happens we all get a dance an song from everyone involved. I have wasted many hours talking to HP. I end up deleting the software and reinstalling to keep my computer working together with the printer.
Posted on Feb 03, 2009
  • 360 Answers
If you receive an error message similar to “Scanner initialization failed” or “Scanner not
found” when trying to use the scanner, use the following procedure:
1. Close the HP Photosmart software, if it is open.
2. Disconnect the cable that connects the scanner to the computer.
3. Turn the computer off, wait 60 seconds, and then turn the computer on again.
4. Reconnect the cable that connects the computer and the scanner.
– Make sure that the USB cable is connected to the back of the scanner correctly.
The USB symbol on the end of the cable (the connector) should be facing up.
When connected correctly, the USB connector will feel slightly loose. When
connected incorrectly, the USB plug will feel overly tight.
– Try connecting the USB cable to a different USB port on your computer.
  • 1,596 Answers
I have Had this same Problem Now I Just Use WINDOWS SCANING UTILITY
    President:
  • 1,214 Answers
Have you read the FAQ on HP's website for this printer about there being an issue with some USB drivers when using this printer and a wide range of motherboards?
Please see this -
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1849437&prodTypeId=15179&prodSeriesId=1849437&objectID=c01269063
Sounds like the problem you are having.
Let me know if this helps, or if it does not solve the problem, and I will keep looking. But the problem appears not to be a HP issue at all.
  • Mark Egan Feb 03, 2009
    Go to Device Manager and right click on any device that says USB. Then choose "Update Driver" and tell it to look at Windows Update.
    If any drivers are replaced, note the version numbers of both the old and new drivers, update, and run tests again.
    Let me know how this worked.
Scanjet 2200c under Windows 7
HP does not have a driver for this scanner with either Vista or Windows 7. One workaround is available in Windows 7 Pro or Ultimate. You can set up the XP mode and install the scanner within the virtual computer. Scanned files may need to be put on an external drive to transfer them between the two "computers".
I hope this helps.
Jan 10, 2010 | HP ScanJet 2200C Flatbed Scanner
Hi, HP Scanjet 2200c (Scanner) does it work for windows 7?
Hi dorine...
HP Scanjet 2200c drivers (xp/vista/win7/win8/mac) can be found at driverupdate us It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Oct 07, 2009 | HP ScanJet 2200C Flatbed Scanner
Similar problem trying to install HP Scanjet G3010 on Vista 32
Are you an Admin user on the computer?
What operating system are you using? XP, Vista, ???
Sep 09, 2009 | HP Scanjet G3010 Flatbed Scanner
HP Scanjet G3010 RE-INSTALL PROBLEM (WIN/XP)
hi hots2,
i ve been solving ur problem through live chat... when my power got cut.... pls respond to my omments to the chat.... u can go to ur "my profile" page and clik on the chat.... the entire transcript will be available.... though we might not be able to chat... we might still respond through comments...
thank you
May 04, 2009 | HP Scanjet G3010 Flatbed Scanner
Windows XP Pro Service Pack 2.0 not recognizing HP Scanjet 2300c
Check the cable and go to HP site and get the latest drivers
Mar 16, 2009 | HP Office Equipment & Supplies
HP Scanjet 5590 nothing showing in Scan to box
go to control panel and start using the scanner from their it may work
Jan 12, 2009 | HP Scanjet 5590 Flatbed Scanner
Windows Vista Driver for HP Scanjet 3200C
Help me I need vista 32 bit driver for my hp scanjet 3200c.
Thank you
Oct 24, 2008 | HP ScanJet 3200C Flatbed Scanner
Hp solution center can not find hp g3010 scanner
Hi
Try this Link out.
http://scanner.free-driver-download.com/HP/47616/HP-Scanjet-G3010-Photo-Scanner-Basic-Feature-Driver-1.1-Windows-XP(x32-x64)-Vista(x32-x64).html
You need to reinstall your scanner's driver.
Genius Guy
Oct 16, 2008 | Computers & Internet
HP Scanjet G3010 Flatbed Scanner Logo
124 people viewed this question
Ben Johnson
