Question about Panasonic KX-TG2356 Cordless Phone
How do you make a 3 way call
My son calls in and I want my wife to join the conversation from an outside line. How do  connect all 3 of us at the same time?
  • 360 Answers
You would need 3-way calling, a feature offered by your phone provider for a fee.
Please take the time to rate this solution
Thanks for using Fix Ya
Posted on Feb 03, 2009
My wife and I have identical Samsung GT S5230 phones. Both will pair with my Kia Ceed bluetooth. The head unit will accept 5 devices but both will not connect with the unit at the same time meaning we...
the issue with Bluetooth connections is that with two headsets and two phones, you have to have your firmware set up to handle ONLY ONE set per phone. This means that if you set it to ONLY accept YOUR headset on your phone, it should work regardless of any other Bluetooth capable devices in range. If there are two possible devices in range and the phone is set to accept either one, it does not know where to send the signal -- and as a security feature, it turns the Bluetooth off so in a crowd no one can use your phone, or listen in on your conversations.
Setting your Bluetooth to accept only one device (being your headset) should allow you to work in the car next to your wife, but will also limit you on which headset you can use -- if you accidentally grab your wife's headset as you are out the door on your way to work, it will not function until you open the channel again. I am not even sure if every Bluetooth capable phone has a function to limit their connectivity, but if this issue is bothering you a lot it might be worth a look in your Bluetooth settings).
Just as a test, and because it sparked my curiosity, I recommend trying this:
Be out of range for your wife's headset and make a phone call on your headset to someone who is willing to hold on the line while you do this. Then, while you are connected with your Bluetooth to your friend, sit in your car with your wife and her phone and Bluetooth. The connection to the headset on your phone should be locked in place from the beginning of the phone call, and so it should not cut out when your wife's Bluetooth headset comes into range of your phone. While this conversation with your friend is still going on on your headset, have your wife make a call on her headset if she can. Because there is only one Bluetooth device available (since yours is in use) she should be able to make the connection with her phone, in spite of it being in proximity to yours. Finally ... hang up your phone, and have your wife do the same. With both phones inactive, try placing a call from the Bluetooth on one of the phones -- the system may set your headset as the default device for your phone, and your wife's would do the same, and the issue should be rectified.
I make no guarantees that this will work ... I am not all that familiar with the complexities of the Bluetooth wireless system and whether or not you can set the system this way, but it is worth a shot. The system may be designed to prevent this type of back door approach, but it would seem reasonable that it could work. Best of luck to you!
May 26, 2011 | Car Audio & Video
How to join with my colleques during their conversation with outsiders?
They either have to let you in, or you have to have Executive Busy override installed on your class of service. Normally, they press the lit line button releases the privacy for about 5 or 10 seconds.
They can set up a conference call and include you, or you can dial a code to get into the call. It may or may not send a warning tone, by programming option.
Carl
May 13, 2011 | Panasonic KX-T7630 Corded Phone
I have a connection but it wont let me join any games on call of duty 4 whats wrong?
Try getting everyone together in one room. One person host the game and the others join in. If u need more info. contact me and me or my son will get u the rest of the info.
Feb 16, 2010 | Activision Call of Duty 4: Modern Warfare...
How do you 3 way call on the LG vu. when i call the third party with the other person on hold it wont let me join them.
  1. While on the first call, dial the 10-digit number of the second person.
  2. Press SEND; the first person is automatically put on hold while the call is made.
  3. When the 2nd person answers, press SEND to create a conference call.
  4. If the second person does not answer, press the SEND key twice to end the connection and go back to the first person.
  5. To end both conversations completely, press the END key.
Jun 15, 2009 | LG Vu Cellular Phone
Need to have 3 way conversation on Panasonic KX-T7730
Steps
  1. Call your friend.
  2. Tell them that you will connect your other friend.
  3. Press talk to put your first friend on hold.
  4. Dial your second friend's number.
  5. Press talk again.
  6. Wait for them to answer.
  7. When they have answered, press talk again to bring the first friend back on the line.
  8. You made a three way call!
Option 2
  1. You can press the button that says 'flash' on the phone.
  2. Then dial the number.
  3. Press flash again.
Option 3
  1. While on the phone dial a number and press call/talk.
  2. When the dialed number answers press the options button.
  3. Select merge/join/combine calls or press call/talk again
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Panasonic KX-T7730 Corded Phone
Nec 22b hf/disp aspirephone-bk
1. have the first call on the line (do NOT put on hold), (call 1 or 2)
2. press CONF key
3. dial 9 for an outside line and dial the number
4. press CONF **twice** to join calls.
Nov 10, 2008 | NEC Dterm DTP 16D-1 Corded Phone
'Invitation' on Call Of Duty
Is it via internet? Call you network proivder
Aug 14, 2008 | LG KU990 Viewty
Missed phone calls
I was having this problem and then realized I had entered my wife's cell number as an emergency number. When I removed it as an emergency number missed calls from her showed up.
Jun 18, 2008 | Samsung i760 Black Phone
Conference call (how to use)
With a call in progress, press CONFERENCE, dial the internal or external number (you may have to dial 9), then press CONFERENCE again. This will join the three together.
Note: for two external calls, your extension must have the ability to access more than one outside line.
Jan 23, 2008 | NEC Electra Professional ETW-16DC-2
RE TRU 9480-4 I have this system and it quit working
Sounds like it had not released from a conference call. Try pressing to off or hang-up buttom on these sets.
If this does not work try removing the batteries from those sets for atleast 5 minutes and then replace the batteries.
Conferencing
If you have more than one handset, up to four people can participate in a conference call. A four-way conference call consists of an outside line, two handsets, and the base speakerphone. You can easily join a call already in progress.
Press [/flash] or [] on the handset or [] on the base to join the call.
To hang up, return the handset to the cradle or press [] on the handset or [] on the base. The other party will still be connected to the call.
) 2) • • ) 2)
Dec 22, 2007 | Uniden TRU9480 Cordless Telephone
Panasonic KX-TG2356 Cordless Phone Logo
95 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
