Question about Haier XQBM22-C Top Load Washer
Brake stuck? My washer still does everything except agitate and spin. Water goes in and out. I'm guessing some sort of brake is stuck? Anything I can do myself?
  • fixyabart Apr 04, 2009
    First, thank you for your response.
    Haier XQBM22-C Top Load Washer. This is the make and model. I don't think they make this model anymore. Any other info for me?
    It's a Haier XQBM22-C Top Load Washer.
  • 686 Answers
You have a broken "drive motor to transmission coupling" go to www.repairclinic.com enter model number and see the part since you have not posted a model number, this is the best I can do for now.
Posted on Apr 04, 2009
  • James Chandler Apr 05, 2009
    looking at this site I'm positive you won't have a transmission on that. A new clutch for what you have at this site is probably not worth it (267.95 part number 1225830), and maybe the other part that might be bad is the pulsator (8.30 part number 1227613). I'm sorry I cannot be helpful. They do have an 800 number that you may be able to speak with someone about your washer. And all parts for this model are special order, I wish I could phisically see this machine it's intriguing. Once again i apologize. Good luck and I hope you find what you need.
Washer will not spin during the wash cycle but will spin at the spin cycle. it is a kenmore 90 series washer model 110. please help.
Hi, Most possible causes are:-
1.Make sure the lid is closed. There is a switch inside that completes the connection. Your washer may not spin or agitate if this connection is not completed. Make sure that the speed selector switch is not between speeds. Verify that the washer is not in a soak cycle. You can also reset the water level up or down to make sure that the water level control switch isn't stuck. If you hear a humming sound when the washer is full of water, you may have something stuck in the drain pump.
2.If one of these is not the problem, check the belt. The main drive motor has two distinct functions. The first function is to spin the basket; the second function is to reciprocate your agitator. Inside your washer's transmission is a crank type gear and connecting rods that are used to agitate the washer, with the spinning coming from the washer motor itself. This usually entails some sort of clutch mechanism. Some things to check if your washer is not agitating and/or spinning are:
3.If you notice weak or no agitation, the splines connecting the agitator to the drive shaft may be stripped and need to be replaced.
4.After a lot of use, belts can become worn or damaged. Replace any worn or damaged belts immediately. If you have a broken belt, replace it and check the pulley to make sure it's not seized.
5.Sometimes the drive pulley can wear out and it won't turn the drive belt. Look for wear marks, pits, or uneven spots. It's best to just replace it with a new pulley.
6.Many washers use a reversing motor. Sometimes it will continue to work in one direction even if it won't spin in the other direction. If your washer has a drive motor issue, you probably need to replace the motor with a new one.
7.The lid switch is a safety device that's there to protect you from sticking your hands into a spinning washer. If this switch goes bad, the washer will not work. You will have to replace it. It is inside the main housing for the washer, and located near the door frame.
8.The coupler connects the motor to the transmission. After lengthy use, this plastic and rubber coupler can wear out. If this happens, you need to replace it.
9.Transmission and clutch assemblies can cause agitator and spinning problems They are fairly complex.
Thanks! mannu_rakesh
Sep 11, 2009 | Washing Machines
Wont drain or spin
Regards, mannu_rakesh
Sep 11, 2009 | LG WFT1071TP Top Load Washer
Won't spin
Sep 08, 2009 | Washing Machines
GE Profile washer does not spin
Sep 02, 2009 | Washing Machines
Washer does not spin
Aug 22, 2009 | Washing Machines
Dont spin
Aug 08, 2009 | Maytag Neptune FAV6800A Top Load Washer
WASHER WON'T SPIN OR AGITATE
Fisher and Paykel pride 5.5. It is about 11 yrs old
Oct 04, 2008 | Washing Machines
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Haier XQBM22-C Top Load Washer Logo
97 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
